Old 1st April 2023, 13:48   #1  |  Link
Argaricolm
ImageSourceNV plugin
I'v made a plugin that uses nvjpeg api to decode jpeg source files and convert their color space to YUV444. That is CUDA accelerated.
You will need CUDA toolkit 12.2 (or 11.8) installed and MS C++ redistributables.
Usage:
ImageSourceNV("C:\Folder1\Folder2","jpg",1,34609,24000,1001)
1: Folder path without ending slash.
2: Files extension.
3: First frame.
4: Last frame (included).
5: FPS numerator.
6: FPS denumerator.
File names should be 6 numbers with leading zeroes (%06d).
Download link
Source included.
Update 1:
Added two new CUDA functions:
ConvertToRGBNV()
ConvertToYUVNV()
ConvertToRGBNV function converts YUV444 or YUV420 to RGB 32 bit (technically BGR in avisynth).
ConvertToYUVNV converts RGB32 to YUV420.
I'v made them because of the need to use RGB filters.
YUV<->RGB conversion is done with formula published on MS site.
Nvidia NPP functions use different formula, that makes incorrect (brighter) RGB results and also outputs BGR pixels in reversed order, that makes image flipped. So they were not used.
Update 07.07.2023:
Fixed one bug that caused last (bottom) row to be black line in convert RGV<->YUV functions.
Recompiled with CUDA 12.2.
Argaricolm is offline   Reply With Quote
Old 1st April 2023, 18:26   #2  |  Link
kedautinh12
your plugin for x86 or x64??
Old 1st April 2023, 18:32   #3  |  Link
Reel.Deel
It's x64.
@Argaricolm
Thank you for the plugin. Any chance of a CUDA 11.8 compile for us Windows 7 users?
Old 1st April 2023, 19:24   #4  |  Link
Selur
Selur's Avatar
A VapourSynth version would be nice.
Old 1st April 2023, 20:11   #5  |  Link
Reel.Deel
If you're reluctant to install the 3GB CUDA toolkit, you can the individual files also. According to DependencyWalker it only needs these two files:
Old 2nd April 2023, 00:22   #6  |  Link
Argaricolm
But these 2 dlls are surely have other dependencies...
Added CUDA 11.8 version. Redownload archive.
Old 2nd April 2023, 01:39   #7  |  Link
Reel.Deel
Tried out the 11.8 version but it seems that it requires nvjpeg from Cuda 12?
If not too much trouble, maybe a static build would be better.
Old 2nd April 2023, 14:21   #8  |  Link
Argaricolm
Fixed. Redownload.
Made static linking. But it links only C++ library functions. Cuda is still needed.
Old 2nd April 2023, 18:08   #9  |  Link
Reel.Deel
Fixed. Redownload.
Thanks for the update. I got it to run but the output is only a green image:
ImageSourceNV("E:\Images", "jpg", 1, 6, 24000, 1001)
Dimensions, frame count and frame rate are correct, though.
I did have to fetch two additional dependencies for cudart64_110.dll (api-ms-win-core-libraryloader-l1-2-0.dll and api-ms-win-security-systemfunctions-l1-1-0.dll). I'm not sure why they're missing or if they are meant for Win10.
Old 2nd April 2023, 21:37   #10  |  Link
Argaricolm
Image width & height are got using nvjpeg. So - it is working.
I'v tested it with 1048 height and working here.
What software are you using to open avs? And which version of avisynth?
Old 2nd April 2023, 22:28   #11  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
My main system is down so I can only remote guess from a replacement system below the specified abilities:
The given commandline does not specify spaces and wants to see 000000.jpg, 000001.jpg ?
And any green frame would usually be YUV samples decoded as 0,0,0 (invalid, btw.)
Old 3rd April 2023, 00:41   #12  |  Link
Argaricolm
Yes, it needs file names: 000001.jpg
6 numbers. Same as in input parameters.
It gets frame settings from first jpeg.
Old 3rd April 2023, 19:03   #13  |  Link
Reel.Deel
I'm using AviSynth 3.7.3 test 9 and tested with VDub2 and AvsPmod and both show the same result. Image is 4:2:0.
I also noticed that ImageSourceNV("E:\Images", "jpg") results in "ZeroDivisionError: float division by zero".
Old 4th April 2023, 14:50   #14  |  Link
Emulgator
Emulgator's Avatar
System up again, success.
Threw the cuda 11.8 .dlls into system32, used the 11.8 plugin version.
From non-subsampled .jpg source filter returns frames decoded to YV24, 23.976fps
returns the 1st frame 000001, then repeats the same frame until framecount.
returns frame 000000, then 000001, then 000002, then repeats 000002, then 000000.
(My bad: I had given some pictures with differing width/height, first 3 were portrait, then 000003 was landscape X-}
00000.jpg: No video
Now a folder renamed to 000000.jpg to 000200.jpg, all same dimensions 4608x3456, orientation landscape.
These 4:2:2-subsampled .jpgs result in chroma planes with half width,
so resizing would be necessary afterwards, or better: chromaspace signalling should match.
ImageSourceNV() returns all frames decoded with unresized chroma planes to YV24, 23.976fps.
With prefetch(16,200) 4k frames can be decoded almost in film speed (RTX3080 @ 15..30%).
Not bad for flipping through albums.
Old 4th April 2023, 18:29   #15  |  Link
Reel.Deel
I used the oldest versions available (cudart 11.4.108 / nvjpeg 11.5.2.120) and now it works for me. I will go back and see what is the latest version that works for me since I'm on Windows 7. I think the problem may be that the newest 11.8 cudart requires api-ms-win-core-libraryloader-l1-2-0.dll and api-ms-win-security-systemfunctions-l1-1-0.dll while the oldest one does not.
Edit: the latest cudart that does not require those additional dependencies is 11.6.55.
Old 4th April 2023, 23:13   #16  |  Link
Emulgator
Emulgator's Avatar
Thank you, good to know.
