Old 25th June 2022, 20:50   #4721  |  Link
Selur
Selur's Avatar
I get:
ry, ru, rv = core.std.SplitPlanes(rainbow)
ValueError: too many values to unpack (expected 3))
Here's where I use this:
from vapoursynth import core
import vapoursynth as vs
# requires:
# * BiFrost: https://github.com/dubhater/vapoursynth-bifrost
# * TemporalSoften: https://github.com/dubhater/vapoursynth-temporalsoften
#   I think this could be replaced by TemporalSoften2 https://github.com/dubhater/vapoursynth-temporalsoften2
# raidus = temporal radius
# th = threshold
def ChubbyRain2(clip: vs.VideoNode, th: int= 0, radius: int=3, show: bool=False, interlaced: bool=False):
  if interlaced:
    es = core.std.SeparateFields(clip=clip)
  else:
    res = clip
  y = core.std.ShufflePlanes(res, planes=0, colorfamily=vs.GRAY)
  u = core.std.ShufflePlanes(res, planes=1, colorfamily=vs.GRAY)
  v = core.std.ShufflePlanes(res, planes=2, colorfamily=vs.GRAY)
  uc = core.std.Convolution(u, [1,-2,1], mode = "v")
  vc = core.std.Convolution(v, [1,-2,1], mode = "v")
  ucc = core.std.Convolution(u, [1,2,1], planes=0, mode = "v")
  vcc = core.std.Convolution(v, [1,2,1], planes=0, mode = "v")
  cc = core.std.ShufflePlanes([y,ucc,vcc], planes=[0, 0, 0], colorfamily=vs.YUV)
  cc = core.bifrost.Bifrost(cc)
  cc = core.focus.TemporalSoften(cc, radius=radius,luma_threshold=0, chroma_threshold=255,scenechange=2 , mode=2)
  expr = "x y + " + str(th) + " > " + str(256 << (clip.format.bits_per_sample - 8)) + " 0 ?"
  rainbow = core.std.Expr([uc,vc],expr)
  rainbow = core.resize.Point(rainbow, res.width, res.height)
  ry = std.Maximum(ry)
  ru = core.std.BlankClip(ru, color=128 << (clip.format.bits_per_sample - 8))
  rv = core.std.BlankClip(rv, color=128 << (clip.format.bits_per_sample - 8) )
  rainbow = core.std.ShufflePlanes([ry,ru,rv], [0,0,0], vs.YUV)
  resfinal = core.std.MaskedMerge(res, cc, rainbow)
  if show:
    output = rainbow
  else:
    if interlaced:
      output = core.std.DoubleWeave(resfinal)
      output = core.std.SelectEvery(output, 2, 0)
    else:
      output = resfinal
  return output
Original AviSynth version: http://avisynth.nl/images/ChubbyRain2.avsi
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 25th June 2022, 22:28   #4722  |  Link
mastrboy
While I don't have a solution to your current issue, are you not missing the cnr2() function call? (http://avisynth.nl/index.php/Cnr2)
I doubt it would function the same without it?
(i have a tendency to drunk post)
mastrboy is offline   Reply With Quote
Old 26th June 2022, 05:13   #4723  |  Link
Selur
Selur's Avatar
@mastrboy: yes, you are right I missed the cnr2 call.
Okay, I see why the ValueError happens rainbow is Gray8
def ChubbyRain2(clip: vs.VideoNode, th: int=10, radius: int=3, show: bool=False, sft: int=10, interlaced: bool=False):
  if interlaced:
    res = core.std.SeparateFields(clip=clip)
  else:
    res = clip
  cc = core.cnr2.Cnr2(cc)
  cc = core.focus.TemporalSoften(cc, radius=radius, luma_threshold=0, chroma_threshold=sft, scenechange=2 , mode=2)
  #cc = core.focus2.TemporalSoften2(cc, radius=radius, luma_threshold=0, chroma_threshold=sft, scenechange=2 , mode=2)
  shift = (clip.format.bits_per_sample - 8)
  expr = "x y + " + str(th) + " > " + str(256 << shift) + " 0 ?"
  rainbowMask = core.std.Expr([uc,vc],expr)
  rainbowMask = core.resize.Point(rainbowMask, res.width, res.height)
  rainbowMask = core.std.Maximum(rainbowMask)
  resfinal = core.std.MaskedMerge(res, cc, rainbowMask)
  if show:
    output = rainbowMask
  else:
    if interlaced:
    else:
      output = resfinal
  return output
doesn't crash, but the output is kind of broken. :/ doh "th: int=0" -> "th: int=10"
Old 26th June 2022, 06:57   #4724  |  Link
ChaosKing
es = core.std.SeparateFields(clip=clip) should be res = ...
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 26th June 2022, 07:02   #4725  |  Link
Selur
Selur's Avatar
thanks, fixed.
Old 30th June 2022, 19:30   #4726  |  Link
Selur
Selur's Avatar
btw. does someone know an alternative to ExBlend for Vapoursynth, something that tries to fix blends and not 'just' try to drop the fields like sRestore, Cdeblend?
Old 30th June 2022, 23:08   #4727  |  Link
Julek
Julek's Avatar
https://github.com/dnjulek/jvsfunc/b...end.py#L16-L40
CPU: AMD 3700X | GPU: RTX 3070Ti | RAM: 32GB 3200MHz
Discord: @Julek#9391 || GitHub
Julek is offline   Reply With Quote
Old 1st July 2022, 15:45   #4728  |  Link
Selur
Selur's Avatar
Will try thanks. (sadly unlike exblend in Avisynth it doesn't seem to do anything for the clip, see exblend thread)
Old 3rd July 2022, 21:25   #4729  |  Link
ChaosKing
Will there be a binary for the R2 imwri release?
Old 4th July 2022, 15:26   #4730  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Done. Forgot to check back for the artifacts to grab binaries.
Myrsloik is offline   Reply With Quote
Old 7th July 2022, 17:20   #4731  |  Link
Selur
Selur's Avatar
Using BlankClip (http://www.vapoursynth.com/doc/funct...blankclip.html) there is a color parameter,
float[] color=<black>
is there some documentation about this? What range are these floats? I guess one should use three or four, right? Is the color selection etc. dependend of the used color space (type, sampling, bit depth)?
Old 7th July 2022, 17:43   #4732  |  Link
Myrsloik
Myrsloik's Avatar
They are 1:1 copied into the destination clip (rounded for int formats of obviously). Out of range values for the format throws an error. Number of planes values expected.
Old 7th July 2022, 18:07   #4733  |  Link
Selur
Selur's Avatar
Okay,.. so the best way if I got a rgb(50,205,50) color coding would be to first create a RGB24 clip with my values and then use for example:
clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P8, matrix_s="470bg", range_s="limited")
to convert to YUV420P8 if that is the color space I need, right?
Old 7th July 2022, 18:20   #4734  |  Link
Myrsloik
Myrsloik's Avatar
Yes. That's the easiest way.
Old 7th July 2022, 18:21   #4735  |  Link
Selur
Selur's Avatar
Okay, thanks.
Old 7th July 2022, 18:52   #4736  |  Link
Selur
Selur's Avatar
Using:
PHP Code:
# Imports
import os
import sys
# getting Vapoursynth core
core vs.core
# Import scripts folder
scriptPath 'i:/Hybrid/64bit/vsscripts'
sys.path.insert(0os.path.abspath(scriptPath))
# Loading Plugins
core.std.LoadPlugin(path="i:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll")
# Import scripts
import havsfunc
# source: 'G:\TestClips&Co\files\test.avi'
# current color space: YUV420P8, bit depth: 8, resolution: 640x352, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: progressive
# Loading source using FFMS2
clip core.ffms2.Source(source="G:/TestClips&Co/files/test.avi",cachefile="E:/Temp/avi_6c441f37d9750b62d59f16ecdbd59393_853323747.ffindex",format=vs.YUV420P8,alpha=False)
# Setting color matrix to 470bg.
clip core.std.SetFrameProps(clip_Matrix=5)
clip clip if not core.text.FrameProps(clip,'_Transfer') else core.std.SetFrameProps(clip_Transfer=5)
clip clip if not core.text.FrameProps(clip,'_Primaries') else core.std.SetFrameProps(clip_Primaries=5)
# Setting color range to TV (limited) range.
clip core.std.SetFrameProp(clip=clipprop="_ColorRange"intval=1)
# making sure frame rate is set to 25
clip core.std.AssumeFPS(clip=clipfpsnum=25fpsden=1)
## Starting left=60, top=60, right=50, bottom=50
clip core.resize.Bicubic(clip=clipformat=vs.YUV444P8range_s="limited"# convert clip to 4:4:4 to allow uneven positions
clipVline core.std.BlankClip(clip=clipwidth=1format=vs.RGB24color=[50,205,5]) # set color of vertical line
clipHline core.std.BlankClip(clip=clipheight=1,format=vs.RGB24color=[50,205,5]) # set color of horizontal line
clipVline core.resize.Bicubic(clip=clipVlineformat=vs.YUV444P8matrix_s="470bg"range_s="limited"# change color to that of clip
clipHline core.resize.Bicubic(clip=clipHlineformat=vs.YUV444P8matrix_s="470bg"range_s="limited"# change color to that of clip
#overlay vertical lines
clip havsfunc.Overlay(base=clipoverlay=clipVlinex=60)
clip havsfunc.Overlay(base=clipoverlay=clipVlinex=clip.width-50)
clip havsfunc.Overlay(base=clipoverlay=clipHliney=60)
#overlay horizontal lines
clip havsfunc.Overlay(base=clipoverlay=clipHliney=clip.height-50)
clip core.resize.Bicubic(clip=clipformat=vs.YUV420P8range_s="limited")
## Finished
# set output frame rate to 25fps
# Output
clip.set_output()
I basically get what I expected, but something seems to be amiss, since I see some pinkg lines
that should not be there,...
any idea where I go wrong?
Did I do something wrong or this a bug in overlay or somewhere else? (it's not much of an issue for my use case here, but seem to be wrong)
Cu Selur
Ps.: In case it's helps, I got the source clip I used in my google drive.
Old 7th July 2022, 20:02   #4737  |  Link
Julek
Julek's Avatar
Using:
Cu Selur
It's just chroma subsampling effect.
Old 7th July 2022, 20:10   #4738  |  Link
MonoS
Cu Selur
That's an artifact from doing chroma subsampling, 4:2:0 (YUV420Px) has a 1/4 resolution for chroma and using a bicubic kernel (which use some negative lobe IIRC) generate that purple line (if you invert your green to [155,50,250] you will in fact generate a faint green line), if you use a kernel without negative lobes such a bilinear one you can avoid that kind of artifact, but introducing a strong chroma contrast line like that i a subsampled pic will always introduce some artifact, leave in in 444 subsampling (or RGB) and you will avoid that.
MonoS is offline   Reply With Quote
Old 8th July 2022, 17:22   #4739  |  Link
Selur
Selur's Avatar
Okay, thanks for clearing that.
Old 20th July 2022, 03:16   #4740  |  Link
lansing
I have a problem with the R59 installer. I have both Python 3.8 and 3.9 installed with 3.9 being the default. But the installer is only able to detect 3.8. I tested R57 and it is able to see both python versions.
speed, vaporware, vapoursynth
