Old 25th October 2021, 00:37   #4541  |  Link
Yomiko
Originally Posted by Yomiko View Post
What's the reason for not allowing a GRAY plane extracted from an RGB clip resized to RGB because of its tagged matrix? It seems the matrix itself (if supported by VS) doesn't affect the output result.
Meanwhile GRAY clip with unspec matrix can be resampled. A bug?
Yomiko is offline   Reply With Quote
Old 25th October 2021, 10:41   #4542  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
No, gray clips are the Y in YUV so the same rules apply. You can resize unknown matrix YUV but you can't convert it to RGB.
Myrsloik is online now   Reply With Quote
Old 25th October 2021, 14:11   #4543  |  Link
Selur
Selur's Avatar
I'm on Ubuntu 20.04, I compiled and installed Vapoursynth R57.
I also compiled a bunch of filters to "/home/selur/opt/vapoursynth/lib/python3.8/site-packages"
paths seem to be correct:
echo $LD_LIBRARY_PATH
echo $PYTHONPATH
echo $PATH
/home/selur/.local/bin:/home/selur/opt/vapoursynth/bin:/home/selur/.local/bin:/home/selur/opt/vapoursynth/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
import vapoursynth as vs
core = vs.core
clip = core.std.BlankClip(format=vs.RGB24, color=[255, 255, 255])
clip = core.text.Text(clip, core.version())
clip.set_output()
works fine
explicit loading a library (libvslsmashsource.so):
core = vs.core
core.std.LoadPlugin('/home/selur/opt/vapoursynth/lib/vapoursynth/libvslsmashsource.so')
clip = core.lsmas.LWLibavSource(source="test.mov", format="YUV422P10", cache=0, fpsnum=30000, fpsden=1001, prefer_hw=0)
clip = core.resize.Point(clip, matrix_in_s="470bg",range_s="limited")
clip.set_output()
works fine too,
but using:
import sys
core = vs.core
sys.path.append('/home/selur/opt/vapoursynth/lib/vapoursynth')
clip.set_output()
doesn't.
It returns "Python exception: No attribute with the name lsmas exists. Did you mistype a plugin namespace?"
-> How can I tell Vapoursynth where to look for the libraries?
I though:
would do the trick, which it doesn't.
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 25th October 2021, 14:13   #4544  |  Link
Myrsloik
Myrsloik's Avatar
You're specifying the python search path, it's only used for import and similar python commands. You also shouldn't install filters in site-packages.
Old 25th October 2021, 14:18   #4545  |  Link
Selur
Selur's Avatar
Sorry, my mistake. Didn't put the iflters in the site-packages.
site-packages only contains vapoursynth.la and vapoursynth.so
all compiled filters are in "/home/selur/opt/vapoursynth/lib/vapoursynth/"
Okay, so is there a way to somehow to use my folder as "/home/selur/opt/vapoursynth/lib/vapoursynth/" source for autoloading?
Old 25th October 2021, 14:25   #4546  |  Link
Selur
Selur's Avatar
okay, forget it found it.
"$HOME/.config/vapoursynth/vapoursynth.conf "
with:
"SystemPluginDir=/home/selur/opt/vapoursynth/lib/vapoursynth"
works
Old 25th October 2021, 14:39   #4547  |  Link
Yomiko
Also this -> http://www.vapoursynth.com/doc/funct...llplugins.html
Old 25th October 2021, 14:56   #4548  |  Link
Selur
Selur's Avatar
Uhhh,.. didn't know "LoadAllPlugins"
Old 25th October 2021, 16:21   #4549  |  Link
_Al_
oh, was LoadAllPlugins introduced with new API release or does it work with older releases too?
_Al_ is offline   Reply With Quote
Old 26th October 2021, 06:03   #4550  |  Link
lansing
When creating filter, where do we put the xyvInit() initial function in API4 now? It was gone in the example filter. And in the createVideoFilter(), there are this two lines in the example script:
VSFilterDependency deps[] = {{d.node, rpStrictSpatial}};
vsapi->createVideoFilter(out, "Invert", vi, invertGetFrame, invertFree, fmParallel, deps, 1, data, core);
What is the VSFilterDependency and numDeps do? The documentation is lacking.
Old 26th October 2021, 10:27   #4551  |  Link
Myrsloik
Myrsloik's Avatar
1. You have a function that calls createVideoFilter(), put it there instead. Most filters are already written that way.
2. It's an array where you list all the nodes and in which order you will request frames from them to generate the output. StrictSpatial is obviously for spatial only filters, NoFrameReuse is for reordering filters of certain types (basically if you request all output frames once none of the input frames will be requested twice, trim, splice and similar fit into this category). General is for everything else.
NumDeps is simply how items are in the deps array.
Old 26th October 2021, 23:46   #4552  |  Link
lansing
Okay got it. Also can you add some example filter written in c++? Because when I got stuck with the c syntax, I couldn't find any other example because everybody was writing in c++. For example, I want to use the isConstantVideoFormat() from the VSHelper4.h, I included the header file in my c file #include "VSHelper4.h", but visual studio still couldn't recognize the function.
Old 27th October 2021, 00:08   #4553  |  Link
DJATOM
DJATOM's Avatar
Use vsh::yourCalledFunction.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 27th October 2021, 01:33   #4554  |  Link
lansing
using namespace is a c++ thing
Old 27th October 2021, 04:26   #4555  |  Link
WolframRhodium
vsh_yourCalledFunction
WolframRhodium is offline   Reply With Quote
Old 27th October 2021, 06:16   #4556  |  Link
lansing
Thanks, worked.
Now I ran into another problem trying to build the filter. The build succeeded, but the function didn't get register. Here is the xxxCreate function.
void VS_CC levelsCreate(const VSMap *in, VSMap *out, void *userData, VSCore *core, const VSAPI *vsapi) {
    LevelsData d;
    LevelsData *data;
    int err;
    d.node = vsapi->mapGetNode(in, "clip", 0, 0);
    d.vi = *vsapi->getVideoInfo(d.node);
    d.factor = vsapi->mapGetFloat(in, "factor", 0, &err);
    if (err) {
        d.factor = 100.0;
    // Comparing them directly?
    if (d.factor < 0.0 || d.factor > 100.0) {
        vsapi->mapSetError(out, "Levels: factor must be between 0 and 100 (inclusive)");
        vsapi->freeNode(d.node);
        return;
    if (!vsh_isConstantVideoFormat(&d.vi) || d.vi.format.sampleType != stInteger || d.vi.format.bitsPerSample != 8) {
        vsapi->mapSetError(out, "Levels: only constant format 8bit integer input supported");
        return;
    if (d.vi.width)
        d.vi.width += 256;
    if (d.vi.height)
        d.vi.height = MAX(256, d.vi.height);
    data = (LevelsData *)malloc(sizeof(d));
    *data = d;
    VSFilterDependency deps[] = { {d.node, rpStrictSpatial} };
    vsapi->createVideoFilter(out, "Levels", &d.vi, levelsGetFrame, levelsFree, fmParallel, deps, 1, data, core);
void VS_CC levelsCreate(const VSMap *in, VSMap *out, void *userData, VSCore *core, const VSAPI *vsapi);
VS_EXTERNAL_API(void) VapourSynthPluginInit2(VSPlugin* plugin, const VSPLUGINAPI* vspapi) {
    vspapi->configPlugin("com.nodame.histogram", "hist", "VapourSynth Histogram Plugin", VS_MAKE_VERSION(1, 0), VAPOURSYNTH_API_VERSION, 1, plugin);
    vspapi->registerFunction("Levels", "clip:clip;factor:float:opt;", "clip:vnode;", levelsCreate, NULL, plugin);
vsedit2 was able to read the plugin "hist", but not the function "Levels". What am I doing wrong?
Old 27th October 2021, 07:05   #4557  |  Link
Yomiko
Maybe clip:vnode in the signature.
But if the filter is only for vsedit2, I think having createVideoFilter(2) called in the filter chain should be sufficient.
Old 27th October 2021, 07:44   #4558  |  Link
lansing
Thank you, that is the problem. I was looking at the codes for hours and couldn't figure it out.
Old 27th October 2021, 11:37   #4559  |  Link
Myrsloik
Myrsloik's Avatar
Protip: if you misuse the api you'll get warnings for things like invalid argument strings if you run things from the commandline
Old 28th October 2021, 08:31   #4560  |  Link
lansing
What about debugging crashes. My test filter tested okay on vspipe --info but crashes on preview, what do I do?
speed, vaporware, vapoursynth
