Old 10th February 2020, 19:01   #3741  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by stax76 View Post
Hello Myrsloik, I've some questions...
Is there some documentation or sample code for DLL discovery and loading?
Do all setup variants add VS to the Path env var and apps can rely on that?
Do all setup variants register the VS location in the registry? If so which key(s)?
I believe Load-Time Dynamic Linking is possible and preferred, I'm mostly unsure about path discovery.
No. You read the location you need from the registry. HKLM/HKCU (depends on current user install mode) and then software\vapoursynth (or vapoursynth-32 for poor people) and the keys of interest are called VSScriptDLL and VapourSynthDLL. Simply use loadlibrary and call vsscript_getVSApi2() or getVapourSynthAPI() depending on which dll you use.
No. It's a user option and you can never depend on this.
Yes, see above. I guess portable doesn't but that's hardly a setup variant...
Myrsloik is offline   Reply With Quote
Old 22nd February 2020, 17:19   #3742  |  Link
stax76
stax76's Avatar
Made some simple wrapper library for AviSynth and VapourSynth, it was necessary because AviSynth has no C or COM interface...
https://github.com/staxrip/staxrip/t...er/FrameServer
https://github.com/staxrip/staxrip/b...FrameServer.vb
https://github.com/staxrip/staxrip/b...deoRenderer.vb
mpv.net - StaxRip - MediaInfo.NET - Get-MediaInfo - More
Old 23rd February 2020, 05:00   #3743  |  Link
amichaelt
Posts: n/a
What about avisynth_c.h?
Old 23rd February 2020, 06:26   #3744  |  Link
stax76
stax76's Avatar
I don't know, maybe I should try it, sample code would help. When I started the library I didn't know a lot about C/C++ (last project more than 10 years ago) and AviSynth, after completing it I know a little more. With the AviSynth part I had few issues, no problems with VapourSynth.
Old 23rd February 2020, 14:50   #3745  |  Link
DJATOM
DJATOM's Avatar
The way you're using frame fetching in VS is inefficient. In general you have to care about async frame requests on your end, otherwise it works like a single-threaded frameserver.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 23rd February 2020, 21:13   #3746  |  Link
Myrsloik
Myrsloik's Avatar
Using the avisynth C api is really iffy. If all you want is to evaluate a script and get frames out then writing your own C++ wrapper dll will be so much more reliable and also faster. Believe me, I've tried both ways long ago when developing yatta.
VapourSynth has a very straightforward C-api in comparison.
Old 23rd February 2020, 23:18   #3747  |  Link
_Al_
If trying to modify props and clip resolution is ridiculously small, it crashes, where no recovery is possible, it locks a PC.
rgb  = core.std.BlankClip(width=30, height=16, format=vs.RGB24)
rgb2 = rgb.std.PlaneStats(prop='PlaneStats')
PROP_NAME  = f'New_string_name_here'
def copy_prop(n,f):
   f_out = f[0].copy()
   f_out.props[PROP_NAME] = '{:.1f}'.format(f[1].props['PlaneStatsAverage']*100)
   return f_out
rgb = core.std.ModifyFrame(rgb, [rgb, rgb2], copy_prop)
_Al_ is offline   Reply With Quote
Old 24th February 2020, 00:31   #3748  |  Link
stax76
stax76's Avatar
For a GUI like staxrip it's totally fine, it's not used for encoding but only to access parameters and for a basic crop and preview dialog that doesn't support playback and HDR color handling but has mpv/mpc integration to take care of this. The GDI based WinForms rendering was ridiculously slow but it was addressed with a hardware accelerated Direct2D replacement. It does a vertical flip and converts to RGB32 in software via avs/vs. For best possible performance vertical flip and YV12 could be handled by Direct3D and like you told frames could be accessed asynchronously.
Old 29th February 2020, 15:22   #3749  |  Link
Myrsloik
Myrsloik's Avatar
def copy_prop(n,f):
   f_out = f[0].copy()
   return f_out
I can't reproduce this and need more information. CPU? OS? Number of threads? Does it happen every time?
Old 1st March 2020, 00:02   #3750  |  Link
Myrsloik
Myrsloik's Avatar
R49-RC1 is now available. All maintenance this time since I'm slowly working on the separate audio build.
Changes:
r49:
updated to python 3.8 on windows
updated visual studio 2019 runtime version
updated zimg and added support for spline64 resize method
fixed a savestring bug in avscompat (sekrit-twc)
interleave, selectevery and separate fields now have a modify_duration argument to determine if they modify frame durations and fps
addborders and crop now update the _fieldbased attribute properly when an odd number of lines are cut from the top
fixed add to path not working for single user installs
fixed compilation on non-x86 systems
fixed an infinite loop in the expr filter optimizer that was introduced in r48 (sekrit-twc)
Old 3rd March 2020, 07:44   #3751  |  Link
lansing
I don't know if this is a bug from vapoursynth or KNLMeansCL. KNLMeansCL requires input clip to be YUV444P10, but it still complains about it when I converted my clip to YUV444P10.
clip = core.resize.Bicubic(clip, format=vs.YUV444P10)
clip = core.knlm.KNLMeansCL(clip)
But then it works when I convert it to YUV444P8
Old 4th March 2020, 19:31   #3752  |  Link
Selur
Selur's Avatar
@lansing: read https://github.com/Khanattila/KNLMeansCL/issues/42
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 4th March 2020, 20:31   #3753  |  Link
lansing
Originally Posted by Selur View Post
Thanks, I'll follow up over there.
Old 19th March 2020, 21:21   #3754  |  Link
Myrsloik
Myrsloik's Avatar
R49-RC2 is out. Should be the final RC.
r49:
fixed transfer characteristics not being applied to gray format clips (sekrit-twc)
fixed vdecimate bugs when compiled on systems where char is unsigned by default
fixed a regression introduced in r48 in that could sometimes cause corrupt output from expr on cpus without sse4.1 (sekrit-twc)
Old 24th March 2020, 16:17   #3755  |  Link
poisondeathray
Can 2 python versions 3.x coexist ? 3.7.x and 3.8.x ? I ask because I need 3.7 for some other projects but would like to test new version of vapoursynth, and I'm assuming 3.8 is a requirement for r49-rc2 ?
Old 24th March 2020, 16:30   #3756  |  Link
Myrsloik
Myrsloik's Avatar
Yes, they can generally do that without any problems. However the python installer doesn't approve so you'll need to rename/delete the registry entries for the version you install first.
There's also always the portable version. Maybe that's easier.
Old 25th March 2020, 07:33   #3757  |  Link
feisty2
I'm Siri
feisty2's Avatar
@Myrsloik
auto y1 = vsapi->getReadPtr(x, 0);
auto x2 = vsapi->cloneFrameRef(x);
auto y2 = vsapi->getReadPtr(x2, 0);
say "x" is a frame ref, do "y1" and "y2" evaluate to the same value?
feisty2 is offline   Reply With Quote
Old 25th March 2020, 09:05   #3758  |  Link
Myrsloik
Myrsloik's Avatar
Originally Posted by feisty2 View Post
@Myrsloik
Yes, they point to the same underlying frame.
Old 26th March 2020, 14:58   #3759  |  Link
feisty2
I'm Siri
feisty2's Avatar
what is the lifetime of "in" and "out" in the "Create" function? If I create an std::string_view from propGetData(in, ...), does it have a global lifetime?
Old 26th March 2020, 15:25   #3760  |  Link
Myrsloik
Myrsloik's Avatar
They're only valid inside the create function and usually destroyed very quickly after.
speed, vaporware, vapoursynth
