Old 28th September 2017, 02:11   #2741  |  Link
lansing
I uploaded a sample profile and preset for the Neatvideo4 demo version here, it takes 2 arguments instead of 7 in the older version
sample profiles
sample script:
ProfilePath = r'sample_noise_profile.dnp'
PresetPath = r'sample_preset.nfp'
core.avs.LoadPlugin(r"VDubFilter.dll")
core.avs.LoadVirtualdubPlugin(r'NeatVideo4.vdf', 'NeatVideo', 1)
clip = core.ffms2.Source('abc.mp4')
clip = core.resize.Bicubic(clip, matrix_in_s="709", format=vs.COMPATBGR32)
clip = core.avs.NeatVideo_2(clip, ProfilePath, PresetPath)
Old 28th September 2017, 09:22   #2742  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Artofeel View Post
yeah, but I use pismo
like store thousands of images in one .pfo file
so I need new version of it due to some bugfixes
The bug has been located and the next pismo release should fix it.
Myrsloik is online now   Reply With Quote
Old 28th September 2017, 17:49   #2743  |  Link
Artofeel
Artofeel's Avatar
yes it's worked now
thanks to you and Joe
Artofeel is offline   Reply With Quote
Old 29th September 2017, 22:34   #2744  |  Link
Myrsloik
Myrsloik's Avatar
sample profiles
sample script:
Odd, seems to work correctly here the whole time. The processing it does is a simple level/color adjustment, right?
Even with a load of seeking. The demo doesn't have some odd frame processing limit?
Old 30th September 2017, 00:24   #2745  |  Link
lansing
It's a denoising filter.
I tested again on both version, seems like the problem only occurs in my older v3.6, doesn't happen in the newer demo v4, while both works fine when loading from avs+.
And I couldn't find an older v3 demo version for you to test on...so I guess I'll just have to update my software.
Old 30th September 2017, 15:38   #2746  |  Link
Myrsloik
Myrsloik's Avatar
R39-RC3
Should be final unless other issues are found. Test to see if all the issue you've reported actually are fixed. Will release it in a few days if no problems are found.
r39:
updated to zimg v2.6
updated pismo file mount runtime to build 188
added offline documentation to the installer
fixed clamping issues in levels filter
renamed the croprel function to crop, croprel will still be kept as an alias for for compatibility with existing scripts
fixed missing max value clamping for 9-15 bit input with convolution
optimized prewitt and sobel
removed the min and max arguments from sobel and prewitt because they interact very oddly with float formats
avisynth compatibility can now handle functions with multiple overloads
added float support to boxblur
removed subtext file size limit
fixed missing fps correction in avisource that would produce an error with some files
switched to nasm as the assembler
visual studio runtime detection is improved in the installer, it should no longer attempt re-installs when a newer version is present
minor optimization in vspipe, you can now output blankclip into the void much faster
memory will now be 64 byte aligned on systems with avx512 support
added swapn and dupn operators to expr
reverted the argument handling in levels, arguments no longer take a 3 plane list due it making no sense when combined with the planes argument
optimized levels, the integer version is now implemented with a lut and the floating point version is faster when gamma=1.0
improved get_outputs() in python (stuxcrystal)
format objects can now be cast to int which will return the format id (stuxcrystal)
added method to make it easier to query formats from python (stuxcrystal)
made it possible to install the python part as a module (stuxcrystal)
Old 30th September 2017, 17:00   #2747  |  Link
lansing
Loading RGB24 clip with avisource still has the upside down bug
Old 30th September 2017, 17:34   #2748  |  Link
LigH
LigH's Avatar
There are top-down and bottom-up DIB's, IIRC...
New German Gleitz board
Old 30th September 2017, 17:42   #2749  |  Link
Myrsloik
Myrsloik's Avatar
Right, I'll take a look at that too. Can't remember if I tried to flip things correctly or not in avisource...
Old 30th September 2017, 18:16   #2750  |  Link
Myrsloik
Myrsloik's Avatar
I need a sample to debug this. It should be doing the right thing already.
Old 30th September 2017, 18:27   #2751  |  Link
lansing
http://www.mediafire.com/file/r7lrydac2f6u8b4/rgb24.avi
Old 4th October 2017, 12:54   #2752  |  Link
DJATOM
DJATOM's Avatar
I have hard times compiling r38 (as well as master) on Debian 8: https://pastebin.com/X8YZ7bEm
Is gcc 4.9 too old for it?
DJATOM is offline   Reply With Quote
Old 4th October 2017, 13:07   #2753  |  Link
Myrsloik
Myrsloik's Avatar
Too old ffmpeg probably
Old 4th October 2017, 15:13   #2754  |  Link
DJATOM
DJATOM's Avatar
Managed to build and install VS using ffmpeg from git, thanks for suggestion.
Old 7th October 2017, 22:48   #2755  |  Link
Myrsloik
Myrsloik's Avatar
R39 released. Important changes listed here.
Old 8th October 2017, 04:13   #2756  |  Link
hydra3333
thank you.
Old 8th October 2017, 07:29   #2757  |  Link
hydra3333
Glorious changes:
r39:
OK, thank you.
Having previously rebuilt avisynth_compat.cpp a few times, I thought I'd give it a go again (the solution relied on yasm) . The updated build instructions say
Needs Visual Studio 2017 and vsnasm (https://github.com/ShiftMediaProject/VSNASM)
So I downloaded VSNASM. Following instructions, in it's readme,
The project provides a basic installer script that can automatically detect any installed Visual Studio 2013, 2015 or 2017 installation and then install the required components. To use this script simply run 'install_script.bat' from an elevated command prompt.
the 'install_script.bat' failed - it couldn't find vs2017 - so I will give the manual nasm install a go, unless you have other suggestions ?
Old 8th October 2017, 12:36   #2758  |  Link
Myrsloik
Myrsloik's Avatar
I think the trick is to run it from a vs2017 command prompt to make it find the proper install path
Old 8th October 2017, 14:09   #2759  |  Link
hydra3333
Updated VS2017, rebooted, did it -
c:\temp\VSNASM-master\install_script.bat"
Detected 64 bit system running 32 bit shell...
Existing Visual Studio environment detected...
Access is denied.
The system cannot find the file specified.
The system cannot find the path specified.
Installing build customisations...
Error: Failed to copy build customisations
   Ensure that this script is run in a shell with the necessary write privileges
Press any key to continue . . .
if it's not one thing it's another ....
So, tried under a standard admin cmd box again and it nearly worked.
Detected 64 bit system...
Visual Studio 2015 environment detected...
Error: Failed to get location of msbuild
FFS.
Old 8th October 2017, 14:18   #2760  |  Link
Myrsloik
Myrsloik's Avatar
Admin vs2017 prompt obviously
speed, vaporware, vapoursynth
