2nd May 2007, 00:15 | #321 | Link |
@Drecksoft
yeah i expirience the same problems :P http://forum.doom9.org/showthread.ph...708#post995708 the best result @ the moment is muxed into .ts/.mpg or.avi but .mp4/.mkv don't work without problems (mp4box,mp4creator,mkvmerge,avimuxgui,gdsmux,Xmuxer Pro) (frame skips, distored slices) it's very strange CoreAVC 1.3 playbacks H.264 .avi wrong it distores the video too but in another way ( i think that's one of the major bugs Betaboy talked about, because this also happens when connected to Sonics HD Demuxer)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 2nd May 2007 at 00:48. |
2nd May 2007, 12:23 | #324 | Link |
MKVToolNix author
I've had files which show distorted slices because they change the SEI and/or PPS contents in the middle of the stream (which, if I understand the specs correctly, is not allowed). mkvmerge removes all SEIs and PPSes from the bitstream and puts them into the CodecPrivate (which is according to the Matroska specs). I did plan to leave the changing SEIs intact but haven't gotten around to doing that.
Any chance someone could upload one of those files to my FTP server?
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. |
3rd May 2007, 20:27 | #326 | Link |
Mosu i have a small sample 642 MB that gives me headaches, PM me the ftp
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
3rd May 2007, 20:43 | #327 | Link |
MKVToolNix author
Cruncher: Read my signature
Latest MKVToolNix is v83.0 If I ever ask you to upload something, please use my file server. Last edited by Mosu; 3rd May 2007 at 20:52. |
3rd May 2007, 20:53 | #328 | Link |
MKVToolNix author
Yeah, upload the first 300 MB or so. If it's really completely from the beginning then even 50 MB should be enough.
3rd May 2007, 21:22 | #329 | Link |
oops
im allready uploading just take how much you need Mosu any idea what's wrong ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 9th May 2007 at 07:48. |
11th May 2007, 10:27 | #330 | Link |
MKVToolNix author
No, sorry.
12th May 2007, 03:11 | #331 | Link |
I found a bug!
When I put a shortcut to MKVMergeGUI into the sendto folder, and right-click an mkv file, select send to > mkvmerge gui, the process starts up but never shows a window, and uses 100% of the cpu. I figured it would be handy to just send files to it (same as 'open with'), it should work like dropping them on an empty mkvmergegui, right? xp pro sp2 |
13th May 2007, 00:49 | #332 | Link |
Latest version of Haali filter has many improvements but seems to have lost some compatibility with mkvmerge with matroska file containing VC1. I report this issue here because it seems to be relevant of another issue related to mkmerge:
When trying to merge two mkv with VC1 mkvtoolnix returns this message "'Error: The track number 1 from the file 'D:\Sample.mkv' cannot be appended to the track number 1 from the file 'D:\Sample.mkv' because the track parameters do not match.". There must certainly something wrong because the error is still there even one tries to merge one file with itself (which should have indentical track parameters!). The issue can be reproduced with this file: http://www.sendspace.com/file/dvkiyf To get the error message, the file just need to be appended to itself. |
13th May 2007, 10:12 | #333 | Link |
Emperor building empire
Can MKV change DAR signalling midstream...
I've been encoding a few seminars from Dr Kent Hovind's 'Creation Science Evangelism' for some christian friends...
The Intro is fine but the main feature needs cropping... I've encoded both pieces at 640x480 but they have different signalling... the main feature is actually 640x486 DAR. Pascal |
24th May 2007, 13:30 | #334 | Link |
Mosu could you please have a look at this thread
24th May 2007, 19:16 | #335 | Link |
Is it possible to "attached" hard coded subs to specific audio tracks?
This one DVD I have has four sets of subs: two are full dialog, and the other two are titles only (onscreen text translations for the foriegn language tracks). On the original DVD, you didn't have to select the Titles Only subs, since they became hard subs automatically when you selected one of the foriegn language tracks. With my current muxing, you have to select the foriegn language track, and then the Titles sub track... would be nice to automate this if I could. |
30th May 2007, 04:08 | #337 | Link |
Mmmmmmmmangoscam!
A small feature request (dunno if it's already been requested) - can there be a checkbox in options to enable quiet mode (-q) without error reporting? When muxing DTS created with Surcode, if the DTS has padding, mkvmerge strips the padding which is fine, however it produces thousands of error messages and the process stalls waiting for the console / GUI to catch up to display them, causing it to take literally half a day to mux a DTS track. This also occurs with AC3 and other tracks which have padding in them.
I just add -q to the commandline and do it but I figure a checkbox would be a simple feature to add and would be less confusing. |
30th May 2007, 08:34 | #338 | Link | |
MKVToolNix author
However, Matroska's header fields may NOT change mid stream. Therefore the answer is more likely "no".
30th May 2007, 08:38 | #339 | Link | |
MKVToolNix author
I've added this to my Bugzilla.
30th May 2007, 08:41 | #340 | Link | |
MKVToolNix author
