Old 4th April 2009, 18:11   #1  |  Link
Kerrin Shea
Pls help me understand B, I & P frames and psy-rd
DISCLAIMER: I'm a Newbie; please bear with me...
1. I've read and read and read, but I still don't understand B frames, I frames or P frames.
One site advised using as many B frames as possible because they're inherently good somehow (how, IDK).
Another site said not to use too many B frames because they result in a less sharp picture.
What are the differences between these frame types, and what is a good number of B frames to use when decoding with, say, HandBrake? (That doesn't result in a less-sharp picture.)
2. What is "psy-rd" and what is a good setting? I hear the settings are very fussy and you can get a fuzzy, less sharp picture unless you use psy-rd...just...right...
3. Does the very latest H.264 support psy-rdo, and what the heck is it? What are good settings?
4. Reference frames: the more the better?
5. Does anyone know the H.264 instruction for "verbose logging"? I've tried v=1, vb=1, verbose=1, verboselog=1, verboselogging=1 in HandBrake, but the Activity Window always says unrecognized instruction -- every time.
Sorry for so many questions.
Any help is appreciated.
Thanks,
Kerry
Kerrin Shea is offline   Reply With Quote
Old 5th April 2009, 01:50   #2  |  Link
J_Darnley
J_Darnley's Avatar
1) An I-frame (or key frame) is one that does not depend on any other. A P-frame is one that involves prediction/compensation from other previous frames. A B-frame is one that that involves prediction/compensation from previous and future frames. B-frames are good because they are small. With a good encoder/format B-frames don't have to look bad.
2) Psy-rd is a psycho-visual adjustment in x264. It try to retain a similar frame complexity as in the original because this looks good.
3) x264 supports psy-rd. What is it? You just asked and I just answered. For more see: http://forum.doom9.org/showthread.php?t=138293
4) Yes but more makes x264 slower and there are level-related restrictions.
5) x264's verbose switch is --verbose (-v for short). In future check x264 --longhelp
Finally: H.264 is a video format, x264 is an encoder for that format.
x264 log explained || x264 deblocking how-to
preset -> tune -> user set options -> fast first pass -> profile -> level
Doom10 - Of course it's better, it's one more.
J_Darnley is offline   Reply With Quote
Old 5th April 2009, 05:19   #3  |  Link
Kerrin Shea
psy-rdO
Thanx, J_Darnley.
Your answers were VERY helpful.
Question #3 was about psy-rdo. Is it the same as psy-rd? If not, what is it? Do the latest x264 encoders support it, and what are ideal settings?
Thanks again,
-Kerry
Old 5th April 2009, 08:26   #4  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
x264 pretty much pioneered psy-rdo.
And yes, around these parts psy-rd(o) is the same thing.
PSY-RDO: "Psychovisually optimized rate-distortion optimization", however you say it, it means the same thing.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Old 5th April 2009, 18:00   #5  |  Link
Kerrin Shea
Thanx, Merlin777.
That clears the issue right up!
I'm still learning, and I appreciate the help of experts such as yourself and J_Darnley.
My philosophy is, I could do lots and lots of "leg work" and find the answer myself, but going straight to an expert for the answer saves me time, effort and "leg work."
Experts are like "aliases" or "shortcut" icons. They take you directly where you want to go with no hassles in between.
Thanx,
Kerry
Old 5th April 2009, 18:13   #6  |  Link
Kerrin Shea
J_Darnley,
Thanks for your help. You said that with a good x264 encoder, B-frames don't have to look that bad. I use 2-pass encoding and set the "Average bitrate (kbps)."
If I increased the Average Bitrate, would B-Frames look better (sharper) or would it have no difference on PSNR?
I am presently encoding episodes of The Simpsons (Seasons I BOUGHT and PAID FOR) to create a "Best Of" DVD containing only my favorite episodes. That will save a lot of searching through discs and seasons and ejecting and re-inserting discs to get to my favorite episodes.
The Simpsons is not the most complex animation in the world--lots of solid colors.
I am using "Reference Frames" = 9 and "B-Frames" = 8. (Plus "Mixed References," "Direct Prediction" = Automatic, "Weighted B-Frames," M.E.M.=umh, "Motion Estimation Range" = 64 (the max), "Subpixel Motion Estimation" = 9 (the max), "Analysis" = All, "8x8 DCT," "Trellis"=2, "No Fast-P-Skip," "No DCT-Decimate," and "CABAC Entropy Coding."
Is my Reference Frame value too high? And is my B-Frames value too high?
Thanks
Old 5th April 2009, 20:37   #7  |  Link
nurbs
More reference frames usually help on animation but for normal content more then 5 is probably not very helpful. Generally from each reference frame you add you can expect about half as much quality gain then from the previous. In my opinion it's mostly the question how much time you are willing to spend on encoding and if you need hardware compatibility, in which case you have to choose an ammount appropriate for the resolution and level you encode to. Since you encode cartoons there are some things you should do, like lowering the aq strenght. Use search, it was discussed recently.
Also, drop "No Fast-P-Skip" and "No DCT-Decimate", they don't really help. Trellis 1 will also be much faster compared to the quality you lose.
Old 5th April 2009, 21:08   #8  |  Link
Adub
Adub's Avatar
You don't really need these.
This is way to high. Leave it at default for your Simpson DVD's. The only reason I ever increase that is if I am working with HD material, which you are clearly not.
You may not need this so high. What b-adapt are you using?
If I may ask, what are you using to encode? MeGUI comes with a plethora of built-in profiles that can tackle anything you throw at it. Each of these profiles were made by our very own Sharktooth, and have been tested repeatedly for errors.
Site:Adubvideo
b frames, h.264, psy-rd, psy-rdo, reference frames
