2nd September 2014, 01:49 | #1462 | Link | |
Troubleshooter
Have you updated any codec/filters recently, or installed any new hardware (like a camera)?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
2nd September 2014, 03:46 | #1465 | Link | |
edit: a 7GB m2ts file opened instantly. Last edited by DeathAngelBR; 2nd September 2014 at 04:04. |
2nd September 2014, 21:54 | #1472 | Link | |
When it's one line I sometimes want it top aligned below the frame, rather than with an empty line first. |
2nd September 2014, 22:38 | #1473 | Link | |
Perhaps it would be better if that option is removed and just always enabled.
MPC-HC 2.2.1 |
2nd September 2014, 22:41 | #1474 | Link | |
If it really only happens with mkv files, then my guess would be: old version of Haali splitter + linked files option enabled + many files in a single folder.
MPC-HC 2.2.1 |
3rd September 2014, 01:02 | #1475 | Link |
explorer.exe cpu usage goes up to 25% and memory usage up to whatever is the file size, briefly before the mkv file opens.
1) I never installed Haali splitter, 2) I don't think I ever enabled that option, 3) I've had over 50 mkv files in a folder and never had problems like this. |
3rd September 2014, 03:26 | #1476 | Link | |
/人 ◕ ‿‿ ◕ 人\
But it will screw up when there're >2 lines. |
3rd September 2014, 03:46 | #1477 | Link |
Troubleshooter
After a video starts pause it, right click on the video, and select filters. Let us know what is listed there.
3rd September 2014, 06:44 | #1479 | Link |
Go into Options->Internal Filter->Splitter and uncheck "Load Matroska Segments from external files".
That's only a work-around to test. It's the same problem clsid hinted at, i.e. when a Matroska file links to external segments it will read (parts of) all Matroska files in the same folder at start-up. This can lead to noticeable pause if there are many files. Last edited by sneaker_ger; 3rd September 2014 at 06:46. |
dxva, media player classic, mpc, mpc-hc |
