12th January 2016, 18:28 | #2481 | Link |
The highlights are also working with EVR-CP in latest nightly. So, yes, it must be a bug in EVR Sync.
MPC-HC 2.2.1 |
13th January 2016, 03:32 | #2482 | Link | |
Hi-Fi Fans
"So slow" is said because whole last year, NIGHTLY builds had became MONTHLY builds. NIGHTLY published at least by half a month. Last edited by nijiko; 13th January 2016 at 04:47. Reason: Fix slip of pen |
13th January 2016, 04:21 | #2483 | Link |
Im not gunna comment on MPC-HC vs MPC-BE theyre both cool projects, but I will say if nightly builds are important to you nijiko then MPC-BE have a good setup for nightly builds and they even digitally sign their nightly binaries too.
13th January 2016, 10:39 | #2485 | Link |
hi, I have problem when try creating a new ticket on trac, "Submission rejected as potential spam" and then "Trac thinks your submission might be Spam. To prove otherwise please provide a response to the following." I wait for captcha but doesn't show anything.
edit: (wanted to post this) ISR: subtitle doesn't move to bottom when using madVR my video res 832x352, play on my desktop resolution 1366x768 using madVR with zoom control -> move subtitles -> to bottom of screen /window enabled using ISR (MPC-HC latest nightly) : http://i.imgur.com/MI0OAO9.jpg using XySubFilter (latest beta) : http://i.imgur.com/eNbGuT7.jpg if more info needed, let me know. thanks Last edited by rock; 13th January 2016 at 10:48. |
13th January 2016, 14:16 | #2486 | Link | ||
13th January 2016, 16:56 | #2487 | Link |
MPC-HC still works on XP. The Vista requirement is only for certain optional functionality such as WASAPI output of the internal audio renderer.
MPC-HC 2.2.1 |
13th January 2016, 17:22 | #2488 | Link | |
MPC-HC Helper xD
@StainlessS: It's clearly stated where that requirement is present. @clsid already explained it.
Once and IF XP support gets dropped, everyone will be notified via our website. We might even create new branch that will remain there for archive purposes, just like we have the legacy one.
MPC-HC Links: official nightlies | Trac | GitHub | git log | IRC | Twitter | Facebook Last edited by vBm; 13th January 2016 at 17:25. |
13th January 2016, 17:34 | #2489 | Link |
OK, I stand corrected, many thanks for your continued support.
14th January 2016, 17:34 | #2490 | Link |
YADIF deinterlacing is the only way to get progressive video from natively interlaced sources in a number of cases. On the other hand, with telecined sources it gives worse results than madVR's film mode. So it would be nice to have a way to enable YADIF deinterlacing for the current MPC-HC session via command line switch.
Windows 8.1 x64 Magically yours Raistlin |
16th January 2016, 20:19 | #2491 | Link |
Forced Subtitle Problem
The forced French subtitles in the Blu-ray movie "The Walk" are not displayed even though "Forced Subtitles (eng) (auto)" has been ticked.
There are two other subtitle choices in English (pgs) Choosing either one of those will bring up subtitles, but now they are displayed all the time, even when they are speaking English. Is there a setting somewhere that I'm missing so I can get just the forced English subtitle track ? Most of the time I can get only the English forced track, but the odd movie (like this one), the subs show up all the time no matter what track I choose. I'm not sure what info to give, but I'll begin with these two screen shots. Thanks ! Last edited by Jeff R 1; 16th January 2016 at 20:27. |
16th January 2016, 22:53 | #2493 | Link | |
Much appreciated, thank you ! With UHD Blu-ray just around the corner, I'm hoping to use MPC-HC for that. My Sony 4K projector has no frame interpolation at 4K, so I have to use the computer. This assumes that there will be a reader that can deal with UHD Blu-ray and that James over at Sly Soft can get around AACS 2 so a free player can be used. Last edited by Jeff R 1; 16th January 2016 at 22:57. |
16th January 2016, 23:16 | #2494 | Link |
Sadly, until full bluray menu support is added to FOSS players, forced subtitles will always be hit and miss because in some cases it relies on the menu data for forced subs. Its good in this case you've fixed it, but it wont always work out that way.
MPC-BE/HC along with lav filters and madVR works really well with MAIN 10 HEVC full hardware acceleration at 127 Mbps even at 60 FPS in IHD 4K, so thats ready for UHD Bluray. HDR is kinda an evolving thing and having the right display is a big part of that. |
17th January 2016, 00:26 | #2495 | Link |
when to downmix ?
Hi all,
Long time fan and user of MPC-HC here. My audio setup is a simple 2.1 plugged on the jack output of my motherboard integrated sound chipset (standard HD Realtek, MB is an Asus Z97-A). Everything has been perfect for years as-is. Among a few hundred mkvs with DTS/DTS-HD/etc, I have a few rare ones with DTS-ES audio. They all used to play fine. However, I have noticed that now DTS-ES audio isn't played properly (mainly voices are missing / very low), which sounds like a downmixing issue. And indeed, I do know a way to fix this : I just have to activate downmixing to stereo in MPC-HC's audio decoder options. Yet I don't know if this is ideal and more importantly doesn't explain why I am suddenly needing to select this option. Facts are : - up til now, I never needed to activate this option (thus leaving the downmixing to the integrated chipset and/or its driver), and my audio setup always did the job (even with DTS-ES files). I can't say for sure when/what caused the downmixing not to work anymore for DTS-ES files, as this is not a very common format thus I am quite rarely playing such a file. I can only hint that I just recently upgraded my Win7 Pro 64bits to Win10 Pro 64bits, but this also totally might not be related and maybe simply started to happen the last time I updated MPC-HC (or one of the previous times : it very well may have been a year since I last played such a file before today). - so I have now activated audio downmixing to stereo inside MPC-HC as this is the solution I've found to make DTS-ES play correctly. (- just in case / for the record, VLC plays these files totally fine) And my questions : - do you have any idea what could have caused this change (from playing DTS-ES files correctly to, well, not) ? - is there any other way to correct this ? - is downmixing by MPC-HC the best way to go (quality-wise), or should I revert to letting my chipset/driver do the job (DTS-ES files excepted of course) ? I am running MPC-HC (64-bit) 1.7.10 (d911f14) which should be the latest stable release at time of writing. Thanks for your help and advice. Last edited by ParkerLewis; 17th January 2016 at 00:42. |
17th January 2016, 00:56 | #2496 | Link |
I wouldve thought youd be better off getting the audio out through HDMI on your PC but anyway
As to who does the downmixing to make it 2.1 for your setup, well you have options in the chain as to where that happens. Personally I downmix within LAV filters via the audio configuration GUI for LAV. Id just set it via lav audio to downmix to stereo including a LFE and dont mix stereo sources, with clipping protection on. Should be fine and has been for me. If not, disable the MPC-HC internal fav filters and try the currently nightly LAV filters build as external filters. Ive ran nightly lav filters for sometime without much problem at all, its pretty robust. |
17th January 2016, 02:50 | #2497 | Link | |
You're right though, it can be a big guessing game as to which sub track is the forced one _ sometime MPC/LAV gets it right and some times not. And like this movie, as well as a few others, forced subs are in with the English track and I find that very annoying, so hopefully the fix works all the time. |
17th January 2016, 09:29 | #2498 | Link | ||
Also that doesn't make sense. My HDMI goes to my screens, only one of which is audio equipped (because it happens to be a TV that I never use for anything else than PC display). Are you saying I should plug my 2.1 to the TV instead ? Quote:
I just want to know if there are any pitfalls doing it one way or another (if you have no idea that's totally fine, but that's what I want to know, and why I am posting here). So if anyone has informed knwoledge in this area... |
17th January 2016, 09:52 | #2499 | Link |
Generally hdmi passthrough is optimal because it preserves the digital signal to be decoded by better quality digital to audio dacs and other parts of the electronics for higher fidelity. Also hdmi has the bandwidth to carry dts hd ma and Dolby true hd amongst other formats which other digital audio connectors cant do such as tos link. Generally using the onboard audio from the morherboard with its crappy dacs and signal path to then feed analogue audio to amps results in poor sound. I still use downmixing though because my current dac cant do some of the higher end formats so in those cases I need to convert it.
17th January 2016, 10:10 | #2500 | Link |
OK, but this HDMI generality does not apply to me. My setup is this : PC -> 2.1 through MB chipset jacks. There is no HDMI here, and my 2.1 is from the last century (literally ).
Still interested : - on whether LAV downmixing is preferrable to letting the audio chipset and drivers do it. - on what could have caused my setup to stop downmixing DTS-ES correctly, if anyone has an idea. |
dxva, media player classic, mpc, mpc-hc |
