Old 2nd October 2007, 15:50   #501  |  Link
Toti
My PC originally comes with WinXP and it works fine there. However, on Windows Vista, the slider doesn't work but if you press preview then I can see the video just fine.
Yes, I do have Avisynth 2.5 installed and the script file is pretty simple just like you put on your "Read Me". I am not doing anything different from XP where it worked flawlessly.
I can import the file via directshow/graphedit but I always rather use your products.
VAIO VGX-XL3 4gig RAM, 4Tb HDD. MEDIA CENTER WINDOWS 7 simply the best!!
Toti is offline
Old 2nd October 2007, 16:18   #502  |  Link
dk75
dk75's Avatar
UPS!
So Yoda Master not I am?
I'm going down...
dk75 is offline
Old 2nd October 2007, 16:59   #503  |  Link
@dk75
Stop making useless posts or you will be struck.
Guest is offline
Old 12th October 2007, 18:10   #504  |  Link
Toti
Neuron2; I found the problem. Haali Media Splitter installed doesn't let DGAVCindex work.
Uninstalling Haali Media Splitter does not help. Just don't install it at all.
Thanks anyway.
Toti is offline
Old 12th October 2007, 22:58   #505  |  Link
Are you sure? I don't see any way they could interfere with each other.
Guest is offline
Old 17th October 2007, 08:15   #506  |  Link
Toti
Don't worry neuron2, I gave up on trying to encode in Vista. CineVision the only app that I have the produces a compliant AVC stream for AVCHD & HD-DVD.
I am back on XP where everything works great.
Toti is offline
Old 28th October 2007, 16:08   #507  |  Link
LigH
LigH's Avatar
ffdshow_rev1579_20071026_xxl.exe is able to decode PAFF AVC video.
Unfortunately, it is not possible to copy libavcodec.dll from ffdshow to DGAVCDec and make it index such a file. DGAVCIndex "knows it better" and refuses to even try it.
Donald Graft, please update...
LigH is offline
Old 28th October 2007, 23:49   #508  |  Link
Yes, I'm aware of it and it is on the agenda.
Guest is offline
Old 31st October 2007, 17:34   #509  |  Link
tjmitchem
Weird Stream
Can someone take a look at this H.264 stream and tell me if it's valid/okay? DGAVCIndex doesn't like it at all, and crashes when I try to open it.
The stream is from Dish Network, and was recorded with an R5000-HD modded receiver.
Any and all help is appreciated.
tjmitchem is offline
Old 31st October 2007, 18:32   #510  |  Link
harissa
dont even bother I use a genpix 8psk and a R-5000 to record from dish , ( even the PPVHD arent scarmbeld )
and i wasnt able at all to encod any h264 1440*1080
I spent the whole summer trying
even directshow crach
only ABC FOX H264 can be encoded cauz they are 1280*720
harissa is offline
Old 31st October 2007, 18:35   #511  |  Link
canTsTop
canTsTop's Avatar
for some reason DGAVCIndex aplha 6 crashes on my pc to, try older DGAVCIndex (dgavcdec100a5) and you will see that your video is PAFF, it not supported now.
canTsTop is offline
Old 1st November 2007, 01:28   #512  |  Link
tjmitchem
Dang! I was hoping it would be a simple fix and then I could go beg squid_80 for a 64-bit version of the avisynth plugin
Old 1st November 2007, 01:45   #513  |  Link
harissa
dont expect h264 from dish network easy to manipulate like any other h264
it quit hard to cut , to encod , to play ,
it s not even worth it ,
the quality is way worse than canadian hd , I wasnt expectin that
harissa is offline
Old 1st November 2007, 03:10   #514  |  Link
tjmitchem
I haven't had any problems playing it at all.
Old 1st November 2007, 14:26   #515  |  Link
G_M_C
Yep, there were more problems; Alpha 6 crashes on my version too, and the earlier versions (up till Alpha 3). were much faster. In the end it was something or another with libavcodec, when Neuron2 tried to incorporate it into the application (to remove the need for .DLL's in system-directory's).
Too bad that development seems to have stopped after this snag was found on alpha 6.
G_M_C is offline
Old 1st November 2007, 14:35   #516  |  Link
No, it was the move to the Windows based build for libavcodec. If you use the one from ffdshow_tryouts, you should not have crashes. And PAFF will be added soon. The project has not stopped, only paused.
Guest is offline
Old 1st November 2007, 18:18   #517  |  Link
G_M_C
Good to hear that the project has not stopped
I still use it whenever i need to get an X264 stream openend in AviSynth, best tool for it imho.
But i've read that FFMPEGSource () can also open AVC-streams, but since you tool works fine, i havent felt the need to it try out.
G_M_C is offline
Old 4th November 2007, 02:03   #518  |  Link
zurv
gdavcdec works fine for stuff encoded in x264, but avc files from blu-ray's i get odd bands on it. I've seen it on all the blu-ray i've tried it on. Please see linked pix.
http://www.kickassanime.org/derp/test/tekkon01.png
Ideas?
i guess in the meantime i can use directshow() orFFMPEGSource() - but of which are pretty useless for seeking around with (ie, going back and forward u can wind up with different frame numbers for the same frame - which is a problem when doing subtitles)
^_^
yes, the video was demuxed from the m2ts to a avc/h.265 elementary stream
zurv is offline
Old 4th November 2007, 03:41   #519  |  Link
Post a link to an unprocessed source stream. I can't do anything with a PNG.
Guest is offline
Old 4th November 2007, 09:15   #520  |  Link
ACrowley
[QUOTE=zurv;1061670]gdavcdec works fine for stuff encoded in x264, but avc files from blu-ray's i get odd bands on it. I've seen it on all the blu-ray i've tried it on. Please see linked pix.
Ideas?
^_^
Try to use a new ffdshow Build which supports PAFF and copy over the libavcodec.dll from ffdhsow to the dgavc folder
Also you can perfectly encode directly from the .m2ts
HaaliMediaSplitter-ffdshowVidedecoder (or you can use Sonic Decoder)
I pers never demux the m2ts with H264 before encoding.
ACrowley is offline
