21st January 2010, 22:24 | #10421 | Link |
mark0077
thanks for letting me know! let me know if it's fixed with rev. 3215 dann23 we still did not implement subtitle input pin, so only external subtitles are working now (movie.srt). we will implement the subtitle input pin in the future. tetsuo55 I've spoken with casimir, in m2ts: MPC assign the PTS timestamp to each frame, haali does not. in mkv: we're not even sure that there is a container timestamp, so neither you or haali assign the chronological value. the only thing we can do is to ask haali to assign the PTS timestamp to vc-1 in m2ts like you do, but we would still need some check based on the container, so not much will change. Tal |
21st January 2010, 22:31 | #10422 | Link | |
Didée Fan
IanB said to ignore this part of the diff file though: src/imgFilters/avisynth/TimgFilterAvisynth.h @@ -99,7 +99,12 @@, but it works for me.
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 21st January 2010 at 22:33. |
21st January 2010, 22:44 | #10423 | Link |
Kid for Today
ok ok...well, please allow me to come whine if the patch is no workee...and I might very well not be the only one if it's as broken as the previous version I tried
and you guys hoping Haali to help you w/ anything... Last edited by leeperry; 21st January 2010 at 22:59. |
21st January 2010, 23:04 | #10424 | Link | |
MPC-HC Project Manager
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
21st January 2010, 23:10 | #10425 | Link |
leeperry,
I was referring to a regression with rev. 3205 that I fixed regarding avisynth not delivering additional frames being created. Jeremy Duncan refers to another issue regarding x64 compatibility (if I understood correctly). |
21st January 2010, 23:14 | #10426 | Link | |
Didée Fan
The x64 part enables the patch to work in windows 7 64 bit. Maybe include the diff file patch in the svn and LeePerry can try it out? With these newer ffdshow trunk builds you also need to do this to get the benefit of the patch though: Decoder options tab Uncheck "Detect soft telecine and average frame durations"
When I get tired during work with dvd stuff i think of River Tamm (Summer Glau's character). And the beauty that is Serenity. Last edited by Jeremy Duncan; 23rd January 2010 at 16:20. |
21st January 2010, 23:23 | #10427 | Link | |
post a beta build so people can test, also, if the patch include multiple functions (like x64 support), it's best to test and commit them one by one. |
22nd January 2010, 01:01 | #10428 | Link | |
Kid for Today
currently w/ CoreAVC CUDA 2.0/ffdshow/avisynth, it currently jumps two frames ahead when I do frame step by step in KMP(it used to be only one frame) the first time(the following frames are OK)...but I didn't try to find the culprit, as it's really no biggy for me. please noone take it bad, but Jeremy's bruteforce approach to compiling software scares me a bit |
22nd January 2010, 15:06 | #10429 | Link |
I hope i haven't missed a post, tried to keep up
would any of the devs mind commenting either way if they have any plans to make DXVA compatible with live streams. Cinch had some stuff in a post about it but i havent (unless i missed it) seen any reply. if you don't have any plans to address this, we can let it go appreciate your work and im not pushing it, just wondering if its been noted or not |
22nd January 2010, 23:14 | #10431 | Link |
some updates:
1. I can't get DXVA hardware alpha blending to work yet, I'll keep trying. (getting E_FAIL from the driver) 2. software overlay mode: it seems that most of the cpu consumption is dedicated to the high quality drawing method I implemented. I'll try to write a faster method for overlay, I might leave the current method as "Overlay - High Quality". p.s. since hardware alpha blending requires conversion to AYUV 32, (and calculating an alpha mask), it would be a safe to assume software overlay would (after optimizations) be faster then hardware alpha blending. |
23rd January 2010, 03:30 | #10434 | Link |
Starting sometime after rev. 3204, IVTC via avisynth make the video stutter extremely bad. I've tried severl versions through to the latest, 3217, and the last working version seems to be 3204.
"Do everything by hand, even when using the computer." - Hayao Miyazaki |
23rd January 2010, 08:20 | #10435 | Link |
there are still artifacts tal.aloni (Nvidia) compared to MPC-HCs decoder
also if i try to close the video now libavcodec.dll crashes im using xhmikosr current 3219 build
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd January 2010 at 08:22. |
23rd January 2010, 11:00 | #10436 | Link | |
since which revision? this might be related to ffmpeg. (please provide more details, I've tested this build and I don't any any issue) Last edited by tal.aloni; 23rd January 2010 at 11:15. |
23rd January 2010, 14:20 | #10438 | Link |
I made some test using dxva and haali splitter, divx mkv splitter and matroska splitter from mpc-hc website.
With haali I can play all the movies. No artifacts. With divx all the movies play but many artifacts. And with matroska splitter some of the movies don't play. Just black screen. And some artifacts. Also I found that if using matroska splitter and the movie has mpeg2 video in it, it won't play. The test was on windows xp with ati 3850. Also I want to mention that using beta2 from albain has no problem with matroska splitter. The problem appeared after that build. Edit. Some artifacts also appear with haali but very rarely. Last edited by dann23; 23rd January 2010 at 14:48. |
23rd January 2010, 18:02 | #10439 | Link | ||
the crash problem appeared between 3212-3217 3212 = ok (file close in MPC-HC) 3217 = libvcodec.dll crash on exit (file close in MPC-HC) 3219 = libavcodec.dll crash on exit (file close in MPC-HC) sorry i don't have any other builds to test
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd January 2010 at 18:30. |
23rd January 2010, 18:51 | #10440 | Link |
http://www.mediafire.com/?sharekey=3...e79d7d0540e1e1
old builds > generic > page 2 let's narrow it down to a build, ok? |
