#62 | Link |
these TVs can't frame interpolated with a 60 HZ signal. they can't judder free display 24p using the build in app (runs at 60 instead of 120).
beware recovering 24p from a 60 HZ source is part of the "smoothing" settings but it needs to be setup correctly so it just creates the orginal frames without frame interpolation. x800H is currently one of these https://www.rtings.com/tv/reviews/sony/x800h |
#64 | Link | |
Location: Mansfield, Ohio (formerly San Jose, California)
Any TV with a native 120Hz panel (or a true variable refresh rate panel) can display 24fps perfectly via simple 1-to-5 frame repeat (i.e. 5x frame rate boost) whereas a native 60Hz panel requires 4-to-10 field repeat (i.e. 2.5x frame rate boost) via either telecine (which either judders or is so smoothed out that faces look like plastic) or interpolation (via either pixel interpolation or motion vector interpolation). Pixel interpolation is fast but it results in fuzzy pictures that, for fast motion is relatively unnoticable, but for smooth motion is noticable. Motion vector interpolation is better at retaining sharpness but MV block size -- the motion vectors are per-block, not per-pixel -- becomes an issue. Large MV blocks are more apt to produce motion vector block artifacts that are similar to macroblock blocking (e.g. the blocks seen in low detail, low contrast areas on non-HDR TVs). MV artifacts show up mostly in tracking shots: Shots in which an object (a boat or a plane or an actor) 'appears' motionless as the background moves. The artifacts can be avoided by adaptive analysis of the picture content and/or by using smaller motion vector block sizes. But perfoming MV interpolation in the TV is a real-time situation because the TV has to produce a new picture every 1/60 second. Really good adaptive analysis and smaller MV blocks simply take more time -- too much time -- than most TV's can afford. When I started this thread I hoped to avoid these kind of detail discussions and simply compile a list of TVs that display 24fps content well. I've concluded that, in order to process 24fps video with sufficiently small MV blocks and sufficient adaptive analysis, I have to transcode them (decode - interpolate to 120fps - encode) before sending them to the TV. That requires a chain of 3 functions that are available to VapourSynth: Super() followed by Analyse() followed by SmoothFps(). The plugin DLLs that accomplish that were developed by the Smooth Video Project (SVP) but it's objective was to accomplish the 120fps conversion in real time (for use inside TVs), not as part of transcoding. As part of transcoding, the process could take whatever time it requires but SVP is not set up to take 'whatever time it requires'. If you bring up my thread history in the VapourSynth sub-forum and look at what I've been posting you'll see the direction I'm taking. But understanding Super() and Analyse() and SmoothFps() is not easy, and understanding how to adapt Super() and Analyse() and SmoothFps() to (non-real-time) transcoding is difficult due to lack of detailed documentation. I could use some help and some support in the VapourSynth sub-forum. PS: The required transcoding could be done via ffmpeg but for 2 problems: 1, the ffmpeg MV interpolation routines are poor, and 2, the ffmpeg developers are busy supporting streaming and are not interested in non-real-time issues. Last edited by markfilipak; 20th October 2021 at 16:10. |
#66 | Link | |
#68 | Link |
huhn wrote: "these TVs can't frame interpolated with a 60 HZ signal. they can't judder free display 24p using the build in app (runs at 60 instead of 120)."
I guess the interpretation is up to the reader, eh? And how do you know what he meant? For that matter, how do you know that huhn is a 'he'? PS: That brings to mind the cartoon: "On the Internet, no one knows you're a dog." -- a dog holding a cell phone, to another dog. Last edited by markfilipak; 21st October 2021 at 04:48. |
#69 | Link | ||
A 24fps source with 3-2 pull-down (or 2-3 pull-down, which is much more common) is called "hard telecine". Why/how would a TV interpolate a hard telecined stream? |
#70 | Link | ||
PS: That reminds me of the old joke: The United States has the best politicians that money can buy. Quote:
Your TVs run 24fps cinema at 25fps (4% speedup) unless the frames been treated to Euro pull-down. And I'll bet there's a Euro telecine that adapts 29.970fps to 25fps. ...Or are you saying that you can take a Region 1 DVD that's hard telecined to 30000/1001fps and play it on a d-PAL TV and people don't sound like they're falling asleep or on tranquilizers? Last edited by markfilipak; 21st October 2021 at 05:25. |
#73 | Link | |
Formerly davidh*****
All appear to be the correct framerate without interpolation. |
#74 | Link | |||
maybe they just do 48 HZ and the rest didn't come up with that simple trick. taking an old TV with 50 and 60 HZ support and giving it a custom refreshrate of 48 HZ is pretty trivial. modern TV don't like custom refreshrate anymore they may work but huge changes are suually rejected on the other hand they are usually 120 HZ anyway. pulldown is part of interlacing/telecine while i totally undertstand what you mean 3:2 judder should be clear enough and no there is no difference between 3:2 or 2:3 it's just where you start counting. |
#76 | Link |
not exposing 120 HZ is very common in the past. than it was generally available at 1080p and 1440p on many brands and with HDMI 2.1 2160p120 was now possible too and is pretty common.
you can just look up your model on rtings to fugure it out or just send 60 HZ and destroy your image quality with the frame interpolation "feature" if it is possible to do that it has to be 120 HZ. |
24hz, 60hz, hdmi, nvidia |
