Old 2nd March 2020, 20:37   #1  |  Link
Toguro
Odd width or height
Hello,
Iíve got many video files with an odd resolution (e. g: 1168 x 863), either width or height, or just only one of those.
I barely can create a single avisynth script to a video in order to resize it to a mod4 or mod16 resolution.
The question is: Is there a tool or batch script to resize lots of videos to an even resolution? (I mean, without have to interact with every single video)
X265 and others codecs donít accept odd width or height.
Thanks in advance
Regards
Toguro is offline   Reply With Quote
Old 2nd March 2020, 21:39   #2  |  Link
videoh
Useful n00b
OK, I'll bite... What are these videos and where are you getting them?
Old 2nd March 2020, 21:51   #3  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Is there a tool or batch script to resize lots of videos without have to interact with every single video?
Yes there is, if you know in advance which resolution you wanna go to (i.e you want all your videos to be resized to 1280x720), I strongly suggest you FrostyBorders made by hello_hello.
If you don't know which resolution you're gonna go to and you just wanna round them up according to their native resolution, you can round them up to the closest even resolution by doing something like:
clip=ColorBars(width=848, height=479)
my_initial_width=clip.Width()
my_initial_heigth=clip.Height()
i_width = my_initial_width / 2 * 2
i_height = my_initial_heigth / 2 * 2
Spline64Resize(clip, i_width, i_height)
It should work fine: Image
As a side note for those who "know" me here on Doom9, if you take a sneaky peek at my AVSPmod tabs you can see that although I'm a broadcast encoder and I use Avisynth at work on a daily basis, whenever I'm at home I still do some pretty bad things once in a while, like fansubbing
Again, Avisynth is a wonderful frameserver for those things. *_*
I wonder whether there are some crappy chinese mobile phones that record at weird resolutions...
Dunno, now I'm curious about where he's getting them as well. xD
Old 3rd March 2020, 01:17   #4  |  Link
Maybe dont bother with resize, just crop to multiple of required.
Untested
AviSource("...")
XMOD=4    # Req X multiple
YMOD=4    # Req Y multiple
W=Width/XMOD*XMOD
H=Height/YMOD*YMOD
Crop(0,0,W,H)    # Spline36Resize(W,H)
return Last
Old 3rd March 2020, 08:41   #5  |  Link
hello_hello
Thanks for the plug, but I should point out... the borders won't be frosty unless they're at least 16 pixels wide. It'll add plain borders instead. Or you can specify Frosty=false and it'll always add plain borders.
You can also do it with CropResize. If you specify just the width it'll resize the height accordingly (and crop a little if need be). The default is mod4. Or you can specify just the height. Either way if you specify a width (or height), you must make sure they're the correct mod yourself. The script only uses the mod option when they're un-specified.
Based on the example in the OP (1168x863), this would give you an output of 976x720.
CropResize(0,720, Mod=8)
This would give you 1280x944 (using the default of Mod=4 for the height).
CropResize(1280,0)
If you're happy to resize down to the nearest mod height, with the width resized to match (and cropped a little if need be), this would give you 1152x848.
CropResize(Mod=16)
Or for cropping-only you get 1168x848.
CropResize(Mod=16, NoResize=true)
Unless you want to check each source, only specify the width, or only specify the height. If you specify both and they don't match the source aspect ratio, such as 640x480 for a source that's 16:9, the script will crop it to 4:3 before resizing to 640x480, so you'd lose a lot of picture (unless you enable borders).
Old 3rd March 2020, 13:49   #6  |  Link
Toguro
Untested
AviSource("...")
W=Width/XMOD*XMOD
H=Height/YMOD*YMOD
return Last
It works!. Sorry, I didn't know that an avisynth script could do that, mathematical operations like those. I suposse that the mark (/) return the leftover (module) of the division, like Python...
By the way, this script is only possible with AviSource? And LWLibavVideoSource or DirectShowSource? I get errors with LWLibavVideoSource...
I got these video clips from recording my screen with third party software, and that software uses some kind buggy codec.
Thank you all, guys. Problem solved
Old 3rd March 2020, 15:41   #7  |  Link
hello_hello
/ is division. When you divide integers, Avisynth returns an integer (rounded down), so when you multiply the result by the same integer you get the desired mod. ie If you want mod16.
1276 / 16 = 79
79 ◊ 16 = 1264
If the numbers aren't integers, you can do the same thing this way:
floor(1276.0 / 16.0) * 16
Avisynth math functions:
http://avisynth.nl/index.php/Interna...eric_functions
For some reason only the FMod function is listed there. There's a mod function for integers that uses "%".
17 % 2 = 1
Ah... apparently it's an operator rather than a function.
http://avisynth.nl/index.php/Operators
It should work for any source. What's the error?
Old 3rd March 2020, 16:09   #8  |  Link
As Hello_Hello said.
when you first learnt how to divide, you did not produce fractional numbers, but something like
1276 / 16 = 79 remainder 12
so for integers
1276 / 16 = 79
1276 % 16 = 12
If either one of the numbers is a float, then the other one is also converted to float, where result is a float. [goes for +, -, *, and /]
Old 5th March 2020, 13:53   #9  |  Link
Toguro
so for integers
1276 / 16 = 79
1276 % 16 = 12
Thanks StainlessS
1276 / 16 = 79
79 ◊ 16 = 1264
17 % 2 = 1
x265 [warning]: Source height < 720p; disabling lookahead-slices
avs [error]: Filter Error: Attempted to request a planar frame that wasn't mod2 in height! occurred while reading frame 0
LWLibavVideoSource(Clip+".avi", format="YUV420P8")
W=Width/XMOD*XMOD
H=Height/YMOD*YMOD
return Last
In AviSource, works like a charm...
Thanks
Old 6th March 2020, 07:56   #10  |  Link
hello_hello
It's probably because the height is mod1, and you're asking Lsmash to convert to YV12, which requires mod2. I assume the source is RGB? Try this instead:
LWLibavVideoSource(Clip+".avi")
W=Width/XMOD*XMOD
H=Height/YMOD*YMOD
ConvertToYV12(matrix="rec709")
return Last
ConvertToYV12(matrix="rec709") assumes the source is RGB and high definition. If it's YUV or SD, or the conversion changes the colors a little, try ConvertToYV12() instead.
http://avisynth.nl/index.php/Convert
AviSource or DirectshowSource could be doing something you're not seeing because you're cropping, such as displaying the bottom line of the picture as green and/or duplicating it for mod2.
Old 6th March 2020, 10:47   #11  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Or it could just be returning RGB.
wonkey_monkey is offline   Reply With Quote
Old 6th March 2020, 13:36   #12  |  Link
I should perhaps have included the ConvertToYV12(Matrix="???"), after either crop or resize,
if doing convert before crop/resize, then there would likely be another prob because YV12 requires at least mod 2 [4 vertical for interlaced].
Old 6th March 2020, 14:39   #13  |  Link
Toguro
I don't know if it's RGB. Regarding MediaInfo:
Video
Format : FICV
Codec ID : FICV
Duration : 39 s 317 ms
Bit rate : 25.9 Mb/s
Width : 1 680 pixels
Height : 1 050 pixels
Display aspect ratio : 16:10
Frame rate : 60.000 FPS
Bits/(Pixel*Frame) : 0.245
Stream size : 121 MiB (95%)
So, I assume it is RGB...I used to stick up with
AviSource(Clip+".avi", pixel_type="+FULL", fourCC="FICV")
Anyway, ConvertToYV12(matrix="rec709") works flawlessly.
I very appreciate it, guys. Thank you all
Old 6th March 2020, 15:19   #14  |  Link
Never heard of FOURCC 'FICV', but according to K-Lite is Mirillis FIC.
You can insert a "return Info" immediately after avisource to show some clip details.
Old 6th March 2020, 18:16   #15  |  Link
Toguro
That's correct, it's mirillis action.
AviSOurce(Clip+".avi")
# LWLibavVideoSource(Clip+".avi")
return Info #before Convert in order to know color space
returns
avs [info]: AviSynth+ 3.4 (r2923, 3.4, i386)
avs [warning]: Converting input clip to YV12
avs [info]: Video resolution: 1400x960
avs [info]: Video framerate: 60/1
avs [info]: Video framecount: 3689
Nevermind, ConvertToYV12(matrix="rec709") works.
odd
