Old 9th February 2021, 15:48   #24241  |  Link
el Filou
el Filou's Avatar
How much VRAM does that 650 Ti have? IIRC there were models with 1 or 2 GB. Even 2 GB is short for madVR with 4K.
clsid's right, there's some problem with the GPU, maybe some driver setting or too old driver.
If using HDR passthrough and a light chroma upsampling algo and short render/present queues, it probably should still be OK with madVR even with 4K IMO.
Old 9th February 2021, 18:08   #24242  |  Link
clsid
Another difference in the screenshot is refreshrate: 71Hz vs 85Hz
Lower the refreshrate so the GPU has to do less work. 71Hz is also smoother for video playback.
madvr settings to adjust:
gpu queue size = 4
frames to present in advance = 1
nvidia settings:
Disable GSync
Enable VSync
Power management mode = Adaptive (or Normal in latest drivers)
Old 9th February 2021, 20:23   #24243  |  Link
Siso
Soul Seeker
Siso's Avatar
Regarding the v-sync in nvidia control panel, is it required to be enabled for pascal cards too?
Old 9th February 2021, 20:57   #24244  |  Link
el Filou
el Filou's Avatar
One time I forced VSync by mistake in NVIDIA Control Panel on my 1050 and madVR rendering times skyrocketed and it started to stutter like crazy so I don't think you can use the same settings that are recommended for Turing & Ampere with older cards.
Old 9th February 2021, 21:00   #24245  |  Link
Siso
Soul Seeker
Siso's Avatar
I see, and you have the same card as mine.
Old 10th February 2021, 08:33   #24246  |  Link
Asmodian
Personally, I wouldn't enable v-sync on Turing or Ampere either. Is there a situation where it helps?
Disabling G-sync is a good idea though, at least for the player.
madVR options explained
Old 10th February 2021, 10:39   #24247  |  Link
Siso
Soul Seeker
Siso's Avatar
I tried enabling and disabling v-sync on my machine, and it didn't make a difference.
Old 17th February 2021, 20:15   #24248  |  Link
mzso
Hello!
Which HW acceleration option is supposed to be the fastest? Is it in the order of the drop-down list? I would expect native DXVA in front of copy-back.
Is there a way to conveniently compare the performance of decoding options? Particularly HW vs SW.
Old 17th February 2021, 21:05   #24249  |  Link
chros
chros's Avatar
d3d11-native is the fastest.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config
Old 18th February 2021, 16:54   #24250  |  Link
mzso
Old 19th February 2021, 17:19   #24251  |  Link
max79
SUPPORT REQUEST - #34
@Nevcairiel
LAVSplitter ignore information written after "-" character in CUE-chapters. Example:
https://feeds.soundcloud.com/stream/...tromix-120.m4a
Any feedback would be appreciated.
max79 is offline   Reply With Quote
Old 19th February 2021, 17:20   #24252  |  Link
max79
SUPPORT REQUEST - #35
@Nevcairiel
Starting from LAV_v0.73.1-28(I have no such issue on v0.73.1-19 and older) i got live stream issues: playback stops right after approx 8-10minutes for two hundreds HLS-streams from yandex.ru site. Example(Geo block. Only for Russia):
https://strm.yandex.ru/kal/rt_hd/rt_hd0.m3u8
UPDATE: Fixed in LAVFilters_v0.74.1-108!
Old 19th February 2021, 17:25   #24253  |  Link
max79
@Nevcairiel
LAVVideoDecoder[Native & Copy-back modes]_v0.74.1-32 in Win7(x64) on NVidia GeForce GTX1650 card with latest drivers gives artifacts issues. if this OS is still supported by you, I can describe the problem in details with a UHD HEVC-10 video short example.
UPDATE: Fixed in v0.74.1-87 and newer!
Old 19th February 2021, 22:56   #24254  |  Link
VictorLS
Originally Posted by VictorLS View Post
Can anyone confirm new H.265 4K SAT channel Mooz 4K (here's my record 20201031-170739_Mooz 4K.ts (56 MB) https://yadi.sk/d/NngfIFAIVyK-hQ ) with LAV Video Decoder 0.74.1-75 (I didn't test earlier versions) as minimum on nVIDIA's videocards GM206 and newer can't be accelerated with DXVA2 (native and copy-back) or gives artifacts in Win7x64? With CUVID hardware acceleration works well. MPC-BE, Cyberlink and MainConcept accelerates via DXVA2 well too.
Corrected in 0.74.1-87 - thanks.
VictorLS is offline   Reply With Quote
Old 19th February 2021, 23:40   #24255  |  Link
max79
My message #24298 was about exactly the same issue!
Old 20th February 2021, 00:25   #24256  |  Link
max79
SUPPORT REQUEST - #36
@Nevcairiel
Starting from LAVSplitter_v0.74.1-34 i got issues after seeking to the beginning on HLS VideosOnDemand, now playback is starting but in fact, frames are output that do not correspond to the beginning position, but those that were at the time that was before the rewind to the beginning. On v0.74.1-32 and older LAV version I have differ behavior, it just didn't start to play media(i didn't hear sound and see only one frame that were at the time that was before the rewind to the beginning. And I liked this behavior better), example:
http://demo.unified-streaming.com/vi...m/machete.m3u8
Seems it looks like something similar with the problem here:
https://github.com/Nevcairiel/LAVFilters/issues/306
UPDATE: Fixed in v0.74.1-98 and newer!
Old 20th February 2021, 01:33   #24257  |  Link
clsid
Reverting 9fbf56d does fix that seek issue.
Old 20th February 2021, 11:25   #24258  |  Link
max79
@clsid
Awesome. Thank you!
Old 26th February 2021, 08:39   #24259  |  Link
nevcairiel
There is a reason for this check. Reverting it just breaks other cases to fix one thing, instead of investigating why it fails. Which case is more important, the one the complained the most recent?
Old 27th February 2021, 06:52   #24260  |  Link
gfxnow
Why no new release in 2 years despite so much activity here?
gfxnow is offline   Reply With Quote
