Old 11th July 2021, 02:36   #1  |  Link
PCU
Best lossless codec for archiving
What's the best lossless codec for archiving?
PCU is offline   Reply With Quote
Old 11th July 2021, 04:34   #2  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Probably FFV1...
Old 11th July 2021, 11:55   #3  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Tough choice.
I'm gonna go for x265 --lossless just because it's generally more supported by NLE etc than the alternatives like HuffYUV, Lagarith and UTVideo and it performs well...
Old 11th July 2021, 12:28   #4  |  Link
kolak
h265 is slow. Also- is playback really that good for anything above 4:2:0 10bit? For archiving you want at least 4:2:2.
FFV1 is used by many institutions as archiving format.
Old 11th July 2021, 12:32   #5  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
For me...
Saving to x264 lossless in mkv has always produced reliable results when generating encodes with VirtualDub2.
Old 11th July 2021, 14:55   #6  |  Link
Jamaika
What kind of movies are we talking about? If new HDR then you can use 10bit HDR. Which codec? That's the problem. Cineform is out. MJPEG2000 is out. The JPEG XS was not seen by anyone. X265 at high bitrate is best in 4K.
Old movies only in RGB. Don't record on Bluray.
Will the AV1, VVC, EVC codecs satisfy the recipient in 20 years? No, then it will be 16K, and we will be able to throw 2K films in the trash.
Jamaika is offline   Reply With Quote
Old 12th July 2021, 16:57   #7  |  Link
benwaggoner
Yep, x265 has the best combination of compression efficiency, content type flexibility, and long-term decodability.
I doubt even 8K will be standard in 20 years for consumer viewing. The industry has yet to identify moving image content that customers can discriminate 4K from 8K even in optimal viewing conditions. And as theatrical movies have long been the primary driver of content tech innovation, the lack of any plan (or business model) for 8K projectors will blunt that.
My 2041 vision has HDR 4K with dynamic metadata as the default, probably in H.268.
Ben Waggoner
My Compression Book
Old 12th July 2021, 17:32   #8  |  Link
jpsdr
UTVideo and MagicYUV are good, i'm using them all the time but for intermediate production files. They are fast, but for archiving, there is probably slower codecs with better compression, like x264 or x265 lossless.
My github.
Old 12th July 2021, 18:26   #9  |  Link
benwaggoner
x265 lossless can be sped up a lot by doing IDR-only (--keyint 1) and using a faster --preset. You can really crank up -F in that case, as each frame is encoded independently. And better yet, you'll get HW decode on modern GPUs, which can give you performance back.
Ben Waggoner
My Compression Book
Old 12th July 2021, 18:28   #10  |  Link
kolak
How much are you going to gain on typical film source (with all grain/noise etc.) using h265 lossless compared to other "fast" codecs?
I never found real world lossless scenario which would give more than 2-2.5x compression (regardless fo the codec).
How difficult would be to do hybrid mode which hits chosen ratio (eg. 3:1), but when it can switches to lossless mode? HDCAM-SR worked this way no?
Old 12th July 2021, 20:16   #11  |  Link
Thundik81
In most cases, just keep original format!
Thundik81 is offline   Reply With Quote
Old 12th July 2021, 20:33   #12  |  Link
kolak
I agree, but at some point it's a difference between spending 1MLN$ or 500K$ for archive and then lossless has its argument
Old 12th July 2021, 21:09   #13  |  Link
PCU
x264/265 is not 100% lossless.
Old 12th July 2021, 21:12   #14  |  Link
benwaggoner
It wouldn't be difficult at all, and allows for VBV compliance for profile @ level. Just use --cu-lossless, and coding units that can be efficiently encoded as lossless get encoded as lossless. Lots of fun info about lossless mode here: https://x265.readthedocs.io/en/master/lossless.html.
And yes, about 2.5:1 for content with grain or other random noise is about what you can expect. Totally clean content in Long GOP can go way, way lower. That's less than you'll get with ProRes and other intermediate codecs. Actual mathematically lossless is rarely needed, and should only be used when it really is. Like delivering VFX with alpha for compositing.
Ben Waggoner
My Compression Book
Old 12th July 2021, 21:12   #15  |  Link
benwaggoner
They are in their lossless modes.
Ben Waggoner
My Compression Book
Old 12th July 2021, 22:19   #16  |  Link
kolak
3:1 is all what you really need.
Old 13th July 2021, 00:00   #17  |  Link
GMJCZP
GMJCZP's Avatar
In Simple X264 I try to code with X265 lossless and I can only pass in custom parameters --keyint 1 --lossless. I can't pass a preset, what am I doing wrong?
Edit: I am using x265 version 3.2, is that why?
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 13th July 2021, 07:30   #18  |  Link
rwill
HEVC higher levels @High Tier have a minimum compression ratio base requirement of 4 so good luck with that HW decode.
Old 13th July 2021, 23:09   #19  |  Link
Asmodian
My favorite lossless codec is MagicYUV. Very fast.
madVR options explained
Old 13th July 2021, 23:53   #20  |  Link
benwaggoner
Yeah, it comes out as High Tier Level 8.something. So far, the HW decoders I've tried seem to work okay. Not having to deal with interframe prediction saves a whole lot of work.
Ben Waggoner
My Compression Book
