#21 | Link |
Pig on the wing
I'd say that is the problem. Or that the actual motion occurs in every other frame or so.
#22 | Link | ||
Here's a quote from Dark_Shikari (emphasis mine): Quote:
Say no to AviSynth 2.5.8 and DirectShowSource! Last edited by colours; 3rd July 2015 at 12:18. |
#25 | Link |
I've found that adding "QTGMC(InputType=1)" in this script as so:
LoadPlugin("F:\[0]StandAloneApps\MeGUI-2500(core)2443(data)0.3.5(libs)[Portable]\tools\DGIndexNV\DGDecodeNV.dll") DGSource("SourcePath") ### Deinterlace-Match Fields-Decimate-Fix Line Doubled Fields ### LoadPlugin("F:\[0]StandAloneApps\MeGUI-2500(core)2443(data)0.3.5(libs)[Portable]\tools\avisynth_plugin\TIVTC.dll") Function FieldMatch(Clip C) { Global PP = C.DuplicateFrame(0) Global CC = C Global NN = C.DeleteFrame(0) P2 = PP.SeparateFields() C2 = CC.SeparateFields() N2 = NN.SeparateFields() Global PC = Interleave(P2.SelectEven(),C2.SelectOdd()).Weave() Global CP = Interleave(C2.SelectEven(),P2.SelectOdd()).Weave() Global CN = Interleave(C2.SelectEven(),N2.SelectOdd()).Weave() Global NC = Interleave(N2.SelectEven(),C2.SelectOdd()).Weave() Global Deint = QTGMC(CC).SelectEven() Return ScriptClip(CC, \ "!CC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CC : " + \ "!NN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NN : " + \ "!CN.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CN : " + \ "!NC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? NC : " + \ "!PP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PP : " + \ "!CP.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? CP : " + \ "!PC.IsCombedTIVTC(CThresh=12,Chroma=True,BlockX=16,BlockY=32) ? PC : Deint") } TFM(Order=-1,Mode=5,PP=2,Clip2=FieldMatch(),Slow=2,MChroma=False,Ubsco=False,CThresh=12,Chroma=True) TDecimate(Mode=1) NNEDI3(Field=-2) Merge(SelectEven(),SelectOdd()) ### Reduce Shimmering ### QTGMC(InputType=1) ### Stabilize ### Stab(Mirror=15) ### Crop ### Crop(8,0,-8,0) ### Gibbs Noise Block ### Edge=MT_Edge("prewitt",ThY1=20,ThY2=40).RemoveGrain(17) Mask=MT_Logic(Edge.MT_Expand().MT_Expand().MT_Expand().MT_Expand(),Edge.MT_Inflate().MT_Inpand(),"xor") MT_Merge(DFTTest(),Mask,Luma=True) ### Overall Temporal Denoise ### SMDegrain(TR=2,ThSAD=500,ContraSharp=True,RefineMotion=True,Plane=0,Lsb=True,Lsb_Out=True,PreFilter=2,Chroma=False) ### Resize ### LinearResize(640,480,Lsb_In=True,Lsb_Out=True) ### Darken-Thin Lines ### F=DitherPost(Mode=-1) S=F.FastLineDarkenMod(Strength=20,Prot=6).aWarpSharp2(Blur=4,Type=1,Depth=3,Chroma=2) D=MT_MakeDiff(S,F).Dither_Convert_8_To_16() Dither_Add16(Last,D,Dif=True,U=2,V=2) ### Deband ### GradFun3(thR=0.55,SMode=2,Lsb_In=True,Lsb=True,StaticNoise=True) ### Preview Source OR Send 16-bit Output To x264 10-bit ### # DitherPost() Dither_Out() ![]() |
#27 | Link |
Why not try a faster preset on QTGMC?
Maybe "Preset=Medium"? The default preset is IMHO "Preset=Slower". Changing to "medium", "fast" or "faster" should give you a nice speedboost. Last edited by Taurus; 9th July 2015 at 11:31. Reason: luigizaninoni was faster |
#28 | Link | ||
#29 | Link |
real.finder,
using your mod I noticed YUY2 works only as long as I don't use SourceMatch. If I try to use SourceMatch with YUY2 I get this error message: "mt_lutxy : unsupported colorspace. masktools only support planar colorspaces (YV12, YV16, YV24)" Lines 928 and 585. |
#30 | Link | |
2016-01-19 http://pastebin.com/MgZ2pMJm 2016-04-11 http://pastebin.com/TV5YRwyu and in Attachments 2016-12-06 http://pastebin.com/RqB1sf9X and in Attachments 2017-01-01 http://pastebin.com/HAD74H7Z and in Attachments (QTGMC 3.352s) 2017-02-06 http://pastebin.com/2mnirSiN and in Attachments (QTGMC 3.353s) new updates will be here https://forum.doom9.org/showpost.php...postcount=2277 In future
See My Avisynth Stuff Last edited by real.finder; 9th February 2017 at 10:02. |
#35 | Link |
Very strange. That would mean for me that VirtualDub does not understand the whole script anymore just because QTGMC 3.33 is used?! If it could just not load a plugin, I would expect a different error ... More checks required.
Does AvsMeter (32 bit) report a more meaningful error? Did you save the script in Unicode format or "ANSI" (Windows CP1252)? Will AvsPmod or VirtualDubMod open the script and display a preview? |
#36 | Link |
Also try MPC-HC or some other media player that normally opens avs files.
And try temporary empty of Plugins32 dir in Vdub, (I've had problems before with avs ffms2 and VDub FFInputDriver.vdplugin dll's interfering with each other [some kind of change to the dll directories search order]).
#37 | Link | |
I tried 3.33s with MPC-HC and AvsMeter and I get this message ;
edit : If I empty Vdub's Plugins32 dir (which contains FFInputDriver.vdplugin and its dll's), I get the same message than with MPC-HC and AvsMeter ! By the way, is it possible to export error messages in text ? Last edited by Music Fan; 10th August 2015 at 10:21. |
#38 | Link |
I guess AvsMeter would report an error as text in the console.
It seems that you put several different plugins and import scripts into your autoload directory, and now accidently a wrong one is used... MDegrain1() is a function in mvtools2.dll; having this DLL in the correct (minimum) version is very important for QTGMC. Code:
# --- REQUIREMENTS --- # # Input colorspaces: YV12, YUY2 # # Core plugins: # MVTools2 (2.5.11.2 or above) # MaskTools v2 (recommend 2.0a45 or above. Must use the 2.5 version with YUY2) # NNEDI3 (recommend 0.9.4 or above for speed) # RemoveGrain + Repair (several versions of this plugin, use the SSE2 dlls from the file called "RemoveGrain-1.0.rar". Don't use the SSE3 versions ) # SSE2Tools for YUY2 support (from the earlier 0.9 version of RemoveGrain, use only SSE2Tools.dll from this version. Don't use the SSE3 version) Last edited by LigH; 10th August 2015 at 10:53. |
#39 | Link | |
I don't use MT version and I have mvtools 2.5.11.3, thus I guess it should work.
#40 | Link |
Ah, your QTGMC version is not 3.33, but probably 3.33s; an "lsb" parameter was introduced rather late. But mvtools-v2.5.11.3.zip offered by Fizick does not document it. There must be another one. Fizick's mvtools2.dll is from 2011-09-19, but I have one from 2012-04-02 too. Both don't seem to support a parameter "lsb", so there seems to be a more recent source.
