6th April 2006, 22:07 | #81 | Link |
Programmer
@JeanL: I'd be happy to see accents properly recognized on top of all letters, which is not the case now.
As for neural networks, well, I'm thinking of using my own similarity engine to determine which font is the closest, then train the network on it or use previous training data. There must be something good in them if professional products such as Recognita use them . |
7th April 2006, 14:30 | #82 | Link | |
And there are some other professional applications like Recognita/OmniPage that must have a great OCR engine. The main problem is that they're closed source. So, how to study their OCR system /engine to see their strong points and maybe adapt them for the main purposes from SubRip and DVDSubEdit in reading dvd subtitles streams? But, no doubt that both Subrip and DVDSubEdit improve a lot in a short period of time. Thanks for your programs, guys. devil (johner) |
7th April 2006, 16:47 | #84 | Link |
I only found one other one, and it didn't look as promising. GOCR approach is quite outdated, nobody would do it that way these days... But you have to admit it does not work that bad for something completely coded *by hand* (absolutely no learning from any data!).
jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
13th April 2006, 19:05 | #85 | Link |
Version 1.32 of DVDSubEdit is now available here...
This is mainly a bug-fix update, but a few annoying things have been fixed.
Also, don't forget to checkout CoNS's cool guide for changing subtitle colors! As usual, thanks to CoNS for many additional tests, and many many suggestions for improvements. Feedback is most welcome! Enjoy... Jeanl
14th May 2006, 11:15 | #86 | Link |
Thanks for the work you have put in on DVDSubEdit. It is an excellent utility that i have been using to correct errors in the subtitles extracted from a DVB recording.
An additional feature I would like to see is to be able to apply all changes to a selected color/transparency, this would also allow the removal of effects subtites. For a bad recording I currently have to set all the text to single setting, which isn't ideal. A minor inconvenience I find is the default of Exactly for changing the timings of subtitles on the apply last modifications to all. I would prefer it to be at most. Again this is because I sometimes get and invalid time. I suppose ideally a search for overlaping subtitles might be good idea? |
16th May 2006, 12:18 | #87 | Link |
I'm not sure what you mean by "apply all changes to a selected color/transparency". YOu can already do that, is that not working for you?
Also, you'd like the default to be changed in the subtitle timing? Is it too hard to use the drop down to select whatever option you like better???? jeanl
21st May 2006, 13:08 | #88 | Link |
SubtitleCreator's Co-Dev
Question related to displayed video frame
Hi jeanl,
I am presently working with Paddington on the next version of SubtitleCreator. This version will allow to preview the subtitle on top the the DVD video. We still have some timing adjustments to make. To better understand our timings, I wanted to use DVDSubEdit to look at the video frame being displayed with the start of each subtitle. For this purpose, I created my own DVD with each frame holding the bitmap of the actual video time code. I also added to the DVD some custom subtitles holding the time code. However when I look at my subtitles with DVDSubEdit, it seems that the video frame being displayed is not the one that should be displayed but some frame next to it. You can see a screen copy here: 00:01:19-17 is the time code of the video. 00:01:20-00 is the subtitle displayed by DVDSubEdit. (Current subpic info gives the time code of the subtitle: 00:01:20,000) I suppose this is because there is no real mpeg2 decoder in DVDSubEdit and you can only display I-frames? Thanks for your software! |
24th May 2006, 13:59 | #89 | Link |
You're absolutely right. DVDSubEdit only displays I-Frames (because DVD2AVI can only pause on I-Frames). The frame displayed is the I-Frame just before the subpic, and that's somewhat inaccurate
I'm afraid fixing that in DVD2AVI would be hard forme... Jeanl
25th May 2006, 03:32 | #90 | Link |
interlace this!
@ jeanl:
i just stumbled upon this proggy (slipped under my radar initially i think). very cool. on your last comment: perhaps try DGindex? i think that can decode all frames, but i'm not sure. should be pretty easy to swap it for DVD2AVI. definitely easier than modding DVD2AVI yourself.
sucking the life out of your videos since 2004 |
25th May 2006, 16:50 | #91 | Link |
hi Mug Funky,
in fact, it would have been a good idea to start with DGIndex right off the bat, but unfortunately, I learned about it too late and I had already started making changes to DVD2AVI (which i really need now). DVD2AVI does decode all frames, the only thing it does not do at this point is stop on any arbitrary one. I'm not sure DGIndex can stop on any non-I-frame arbitrary frame, but I don't think so... jeanl
2nd June 2006, 17:40 | #92 | Link |
Version 1.33 of DVDSubEdit is now available here...
This is a small update with a few bug fixes and a couple improvements.
Enjoy... Jeanl
5th June 2006, 19:46 | #93 | Link |
Your tool is quite impressive. It is about the tool I am looking for.
I look for a tool with which I could add a subtitle stream to a DVD (or recompile a DVD with a new subtitle stream). There are a couple of films where I'd like to add some subtitle streams (or translate or correct some). For this I need a very userfriendly program, where I could browse through the DVD, play the movie with any audio stream, allowing easy and precise rewinding and forwarding, and very fine, easy and quick time adjustment of the subpictures I create. Is DVDSubEdit going to be like this? |
5th June 2006, 20:04 | #94 | Link |
No, not really. For this you need something like subtitle creator, or something like that. DVDSubEdit can't add a subtitle stream and it can't play the movie with the sound and the subs....
Sorry... Jeanl
5th June 2006, 21:54 | #95 | Link |
As jeanl replied, SubtitleCreator 2.0.0 (will be available in a few weeks) will be exactly what you need. You will be able to play the audio you want and the sub you want. At the same time, you will be able to preview your subtitles. It will also include a DVD authoring wizard which allows to automatically add one or more subpicture streams using pgcdemux, muxman and vobblanker. You can try version 1.9.2 but you can't preview the subs on top of the video and you have to add your subpicture streams to your DVD by hand. Manusse |
12th July 2006, 02:09 | #96 | Link |
Hi Jeanl
What a fantastic program. Can I make a suggestion? Options to invert the selection of modified and forced subpics would be nice. Maybe a dropdown with; ‘ ’ ‘show only’ ‘hide all’ modified subpics ‘ ’ ‘show only’ ‘hide all’ forced subpics I’d like to make all subpics which are not forced invisible. Can you suggest how I might do this? (without doing it one at a time) |
12th July 2006, 05:33 | #97 | Link |
Select all subpics. Make them all transparent. Select the forced subpics, make them opaque... Easy no?
Jeanl
15th September 2006, 04:47 | #99 | Link |
That's much harder. For one thing, you need to re-encode the bitmap, and it has to fit in the number of packs that were used in the original bitmap, so there could be many cases where that would fail...
You can already alter the content, but only to remove letters and move things around... Pretty limited... jeanl
17th September 2006, 19:32 | #100 | Link |
Aging Video Hobbyist
To make the subs less obtrusive, I've used DVDSubEdit to reduce the transparency e.g. move '15' down to '6' and the subs are still readily view-able without being blinding. I also move them down a bit to get them more out of the line-of-vision. What a great tool jeanl!
In a similar vein, I wonder if it might be possible to reduce the *size* of the subpics somehow, and then they can be further moved around on the screen? |
