17th May 2011, 18:08 | #21 | Link | ||
As for caring about VSFilter, what alternative was there? No other subtitle renderer even had decent support for ASS subtitles, and libass is very new. Up until a few months ago PotPlayer's renderer was garbage and KMPlayer's one is out of date. The reason VSFilter is the de-facto standard is because it's used in Aegisub, the community-standard timing/typesetting/karaoke editor. They use a patched VSFiler for the software http://www.animereactor.dk/aegisub/readme-vsfilter.txt and that's the reason it will ever be supported by any fansub group, ever for SSA/ASS subs. As far as specs go, however Aegisub and VSfilter works IS the spec now. That's how de-facto works. Quote:
http://i55.tinypic.com/20f3mf9.png The correct one is this: http://i54.tinypic.com/2mpl8qw.png However as you can see MPC-HC internal renderer has its own problems. I can't get the subs to render within the video frame itself, it renders throughout the window or outside the window and gets cropped, depending on whether the option of positioning relative to video frame is ticked or not. PotPlayer works better in this regard. VSFilter also works, of course. |
17th May 2011, 20:45 | #22 | Link | |
There is a quite dated ASS spec, but no fansubbers try to improve it. Libass has supported karaoke effects since long ago, but a lot of ass subtitles created by fansubbers mess up in libass. They are using VSFilter "features" which are never mentioned in the ASS spec. Some subtitles are written in bad syntax, which are rejected by libass and ffdshow, but accepted by VSFilter. VSFilter itself is highly unportable. It relies heavily on Windows stuff, like fonts. And it cannot even be compiled by gcc because it uses a lot of MFC craps. If I were a hardware engineer, how could I implement a subtitle renderer by investigating the bugs of VSFilter, instead of reading the spec? P.S. another bug in VSfilter. When rendering subtitle on a YUV frame, it never takes BT601/BT709 issue into account. BT601 matrix is always used. |
17th May 2011, 21:38 | #23 | Link |
Broadband Junkie
Everybody is aware of the problems with VSFilter, roozhou.
jfs (Aegisub dev | former-VSFilter hacker) gave up fixing/expanding VSFilter way back in 2007, and decided it was best to write a new well-defined standard (AS5), authoring application (Aegisub 2), and reference rasterizer from scratch, which is well supported on Windows/MacOS/Linux from the get-go. That is the three-prong approach needed to gain support of the fansubbing community, but unfortunately all three projects appear to have stalled. If were lucky, someone will step-up within our lifetime and solve all our subtitle woes. Until then, we are stuck with a reference rasterizer made of numerous buggy patched VSFilter revisions and a messy ASS (ASS2/ASS3) spec which is a nightmare to support. Last edited by cyberbeing; 17th May 2011 at 21:52. |
17th May 2011, 22:00 | #24 | Link | |
The basic notion is that people are still using very old VSFilter builds from 2004 which are somehow still in circulation, which creates incompatibility with new extensions added to VSFilter specs in 2008. Although I personally don't support such a backward thought, it's a fact that Aegisub is virtually the only ASS sub editor in the fansub community, and no matter how you improve or expand libass or VSFilter, unless Aegisub decides to support that, it's pointless. Yes, VSFilter has not been actually updated in a long long time, it doesn't even support NV12 output, but it's not like libass is that much better an option either. There isn't even a directshow filter based on libass, so it's pretty irrelevant to the people using VSFilter. You can expect more support for libass after there are actually third party renderers using it out there, not the other way around. Until then, VSFilter is here to stay. |
17th May 2011, 22:06 | #25 | Link | |
If you have 1.0 or earlier, if it ain't broke don't fix it.
"I don't want to belong to any club that would have me as a member." - Groucho Marx |
18th May 2011, 03:14 | #26 | Link | |
18th May 2011, 12:06 | #28 | Link |
VLC from my perspective as an absolute newbie is absolutely wonderful.
I barely understand what most of you are on about here, but when I recently bought an Acer Revo R3700(Intel Atom+Ion) and got totally baffled trying to enable hardware acceleration to watch some HD TV I downloaded, it took a brief Google and checking one check box in VLC to achieve the desired result.
Baffled but not Defeated! |
18th May 2011, 12:36 | #29 | Link | |
The problem here is not that renderers don't support all the functions of the spec, since none of the sub editors are creating codes which support these non-existent functionalities; the problem is that they don't even strictly conform to the standard for which they do. ASS subs support in players like DivX or Splash is just atrocious, and players like Zoom, AFAIK, rely on VSFilter, which does work and will work for 99% of all subs out there because Aegisub conformance. Even the sub editors don't actually strictly conform to specs. Imagine what H.264 would be if there weren't a complete spec-compliant encoder. No matter how much you make your decoder spec-compliant, it'd be pointless. |
18th May 2011, 12:36 | #30 | Link | |
18th May 2011, 14:35 | #31 | Link | |
If aegisub needs a frozen feature set, write down the spec. It should define all supported syntax and how it is rasterized. ASS is not HTML and VSFilter is not IE6. |
18th May 2011, 15:04 | #32 | Link | |
From one perspective, it IS like the IE6 and HTML scenario. When IE6 was the major browser out there, webmasters would constantly break standards to ensure compatibility. It sucks for developers but it works better for the general masses. There isn't even any guarantee that anyone will fix VSFilter if Aegisub even fixes all the non-conformant issues. With the lack of any decent alternative to VSfilter, breaking existing compatibility to just adhere to a spec that no one yet fully supports globally is rather stupid. I don't quite see the issue in adhering to the feature subsets that VSFilter supports in the first place. Sure libass might some day provide full spec compliance but if Aegisub doesn't support a few of those extensions and you'd die without them, yes, you can always edit the file with a text editor and be done with it (of course it won't run anywhere but whatever). Libass needs to be everywhere before you should expect to see any change in the status quo, and even libass isn't fully feature complete or bug-free yet. Changing anything at this point, from Aegisub's perspective, is rather counter-productive. |
18th May 2011, 15:28 | #33 | Link | |
Banned
If your video card can be set for video levels, it's probably better to do it that way, as then all video will display using the same levels regardless of the video player being used. For Nvidia cards at least, the option is under "adjust video settings" in the Nvidia control panel. |
18th May 2011, 17:55 | #34 | Link | |
BTW new features are important. The main advantange of ass is karaoke and drawing. Unfortunately the embedded bitmap is not supported by official VSFilter IIRC. It requires thousands of lines, sometimes one line per pixel, to draw a very simple pattern. One of my friend send me 200MB .ass file. The loading of the subtitle in VSFilter took 10+ minutes and finally ran out of 2GB address space. The inclusion of embedded bitmaps, which is present in the ASS spec, will ease all these things. |
18th May 2011, 22:37 | #35 | Link |
I think you're getting the wrong idea here. You can always change the default patched VSFilter 2.39 renderer that comes with Aegisub with something newer (even the latest MPC-HC builds) or VSFilterMod. Their "support" goes as far selecting which version of VSFilter to include and not providing the access to functions which they consider to be extensions beyond which they consider the base spec (which is apparently some VSFilter in 2004). Here's the dev's comment to refresh your memory: http://forum.doom9.org/showthread.ph...72#post1375872
If you want to support the latest VSFilter 2.40 then just replace Aegisub's VSFilter with MPC-HC's and you're good to go. You can actually see which of the effects work first hand, Aegisub will not actually stop you from creating ASS using extensions which are not officially supported, if you know the specs. It is however, very unlikely that anyone would bother changing the default renderer. Selecting an old version as default just makes it more probable to be more compatible with the larger audience. As for how you know how versions differ, well, you can blame that on the lack of documentation on VSFilter's part. As for the bitmap part, yes that would be nice, but a lot of things would be nice in a lot of programs, you have to maintain a certain balance of features and feasibility when creating specs. ASS was never a well-thought-out spec with long-term vision to be supported by hardware players, it just threw in everything that ever seemed to be possible to do to subs. I am no engineer but I can guess bitmap image manipulation would be quite expensive to do on hardware. Again, if libass doesn't support it, blaming VSFilter is pointless (although I think VSFilterMod supports that). The fact is that there doesn't actually seem to be much development to VSfilter, so any problems and shortcomings now are likely to persist over the years. |
19th May 2011, 10:26 | #36 | Link |
This is completely wrong. Bitmap requires less hardware resources. Your video card can fill billions of triangles with texture within a second. Using D3D/OpenGL to render is simpler than rasterize it in pure software, for both comupters and programmers. Vector graphics are less effecient than rasterized images here.
19th May 2011, 13:39 | #37 | Link |
Actually, both pixel-based graphics and vector-based graphics have their use (if well-implemented). Note: for my explanation I'm ignoring that the ASS specification lacks gradients, other color notation formats than 8-bit RGBA (I'm not sure it's with sRGB, bt.709, bt.601 or other properties) and MPC-HC uses a single-threaded CPU approach to render the fonts, subtitles, OSD and stats screen.
The ASS specification should never have added bitmap support. Input of vector and bitmap data from a single data stream makes processing a disaster. Normal 2D bitmapped subtitle image data requires a mixer to interpret the RGB/Y'CbCr/other binary format and write it on to a working texture of the native resolution. Next, the surface needs to be positioned and scaled to match the so-called world view projection in screenspace (a bunch of floating-point vectors in space, relative to the viewing position, but still only for a flat, 2D view of the object). For scaling and sub-pixel accurate positioning, you can use the dumbest mode of nearest neighbor projection with an 8-bit RGB target, a slightly better surface with bilinear filter, or an entire chain of texture rendering items, like the path I'm trying to create for the main video renderer. The last item is a screenspace blend on top of the images from the rendered video stream. Vectorized subtitle image data in a modern rendering method requires a vector composition stage, which consists of a world view projection in screenspace that is filled with all vectors (usually just lines and curves for basic "2D" stuff, think of a sort of wireframe model). Those items form 2D or 3D surface parts that can be painted on during rasterization. The input doesn't use any pixel data, so there's no need for a mixer and input texture resources. The rasterization stage is where quality can be set. It's easy to change the anti-aliasing quality and the output surface bit-depth. The last item is again a screenspace blend on top of the images from the rendered video stream. To use both bitmapped and vectorized input, two subtitle rendering engine parts would have to be active at the same time. It would require special care that the texture(s) generated from bitmapped input data is already properly scaled, rotated and clipped to make it possible to blend it directly with the output from the rasterizer. In essence, the only thing the two parts could share are the color controls, color management and dithering stages (together with the screenspace-sized texture that holds the image created from the video input stream, after its screenspace rendering stages). I don't think any programmer would be happy to write such a shared rendering stage. On top of that, keeping performance in mind... I'd rather not think about having those two subtitle engine parts active at the same time when rendering animated subtitles. The only things that would be worse than that would be adding lighting, true 3D objects or ray-tracing support. For choosing between the bitmapped and vectorized image formats, I very much prefer vector graphics for being able to scale infinitely, and not take up a lot of space. That is valid as long as the content isn't photographic or extremely pixel-based. I can't imagine that that applies to subtitles.
development folder, containing MPC-HC experimental tester builds, pixel shaders and more: http://www.mediafire.com/?xwsoo403c53hv |
19th May 2011, 14:16 | #38 | Link | |
And I don't think the programmer has to separate bitmap and vector rendering. Bitmap processing looks like mapping texture on polygons, while vector processing looks like drawing lines and fill triangles with color. You can use 3D APIs to do these and each job takes less than 10 lines to finish. |
19th May 2011, 16:46 | #39 | Link | |
The vector renderer rarely draws a triangle patch. It usually doesn't if it's rendering fonts, as those typically use (quadratic) Bézier curves natively. Note that this type of rendering doesn't use a conventional 3D approach. For instance, if you use a pixel font, it will only use nearest neighbor for the basic scaling, as it converts all pixel borders to vectors prior to the filling stage. Of course, you are free to use 2D or 3D engines to use the texture generated by the rasterizer. That's even a requirement if you want to alpha-blend the (preferably small) output texture from the bitmap rendering part on the screenspace-sized texture. MPC-HC's subtitle renderers and underlying parts consist of several tenthousands of lines (code is public, also includes a lot of inline assembly). My attempts to improve some parts of it, have only increased that amount of code so far. (More developers for this item are very welcome to join.) Modern approaches to rendering vectorized items can reduce the amount code for that part, but not much. Also, the code parts that take care of bitmapped subtitle streams are only going to increase in size, as more formats are to be supported (most notably, the blu-ray PGS code needs a big update soon).
19th May 2011, 18:05 | #40 | Link | ||
