21st October 2017, 21:20 | #41 | Link | |
Here is my config file:
Although subtitles are much better now i feel they can go below video a bit more. Need to figure it out Another thing i dont know is if opengl-hq is affecting videos that dont need image up or down scaling. |
22nd October 2017, 10:21 | #42 | Link |
mpv --show-profile=opengl-hq Profile opengl-hq: profile=gpu-hq scale=spline36 cscale=spline36 dscale=mitchell dither-depth=auto correct-downscaling=yes sigmoid-upscaling=yes deband=yes Really dunno about subtitles. |
22nd October 2017, 13:21 | #43 | Link | |
22nd October 2017, 14:39 | #44 | Link |
Mind to provide a screenshot?
opengl-hq should in no way influence colors (except of removing banding). It shouldn't have any influence on the CPU either. Again: mpv by default always uses a OpenGL renderer (at least currently, D3D11 and Vulkan are in the making or already mostly completed), "opengl-hq" is only the above preset of certain quality settings. There is no "opengl" vs. "opengl-hq". I btw. don't think it's necessary to provide a --vd-lavc-threads setting. If your system isn't entirely crappy, you can use --video-sync=display-resample for better frame timing and it should also be save to use --hwdec=dxva2-copy. We also already had a discussion about --opengl-backend=... in this thread. Default is angle, which I wouldn't advise for best performance (or not at all, if possible). |
22nd October 2017, 16:51 | #45 | Link |
Do i need to use any order in giving options to the config file?
Meaning, should --profile= come first than --hwdec= or after? Sometimes is hard for me to tell if hwdec was used or not. I needed to search for the log command so i realized the decoding always fall back to software decoding. probably no need for 16 threads neither hwdec= setting. As for the smooth --video-sync=display-resample i feel its similar to madvr smooth motion without losing so much sharpening. Anyway not to my taste. PS: Well i need the screenshot command please Last edited by xabregas; 22nd October 2017 at 16:53. |
22nd October 2017, 16:58 | #46 | Link |
Without --interpolation, --video-sync=display-resample doesn't introduce any visible blur or whatever.
The order is not relevant for config entries, maybe except of some special video filters. Screenshots: https://mpv.io/manual/stable/#taking-screenshots You can ofc also just press the print screen and insert it into Paint. You can drag&drop video files onto mpv.com to see the console with information about playback (or start it via shell). Current git version also got overlay script integrated (shift + i), which is also available as a userscript. |
22nd October 2017, 17:03 | #47 | Link |
_
I'm fine with opengl-backend=Angle, better performance than dxinterop.
For config file, you don't need --. Just profile=opengl-hq in config file. Order is not important. Curious about the next version with new gpu-api settings. Last edited by pirlouy; 22nd October 2017 at 17:16. |
2nd November 2017, 20:54 | #48 | Link |
_
I was wondering if there is some equivalent for madVR option "automatically detect hard coded black bars".
There's a script (autocrop), but it is not automatic like madVR option. With madVR, 1 option, and it does the job without taking too much ressources (well... I think). |
11th March 2019, 22:01 | #49 | Link |
Version 1.0 is out with a much more feature packed context menu.
Keybinding and context menu conf file: https://github.com/stax76/mpv.net/bl...input_conf.txt Download: https://github.com/stax76/mpv.net/releases Screenshot: |
13th March 2019, 16:55 | #50 | Link |
Working on IronPython integration now maybe a german dev kan help me with my curent issue described here:
https://social.msdn.microsoft.com/Fo...rum=offtopicde |
14th March 2019, 05:44 | #51 | Link |
Version 1.1 has support for Python scripting using IronPython, for testing I migrated the seek-show-position.js script to Python, the API is identical to the Lua/JavaScript API, certainly not fully implemented but assigning to events, executing commands and accessing properties are all shown in the seek-show-position.py script. Since IronPython is .NET based it can also use the APIs which the two included .NET addons use. Personally I think Python is much nicer than Lua and JavaScript, Python scripts can be located in the startup dir in the script folder or in mpv's script folder in the appdata folder. The script is shown below, feel free to ask anything about mpv/mpv.net, .NET addons or Lua/JavaScript/Python scripting. I'm not having any further plans for the player right now since it does everything what I use.
# when seeking displays position and # duration like so: 70:00 / 80:00 # which is different from mpv which # uses 01:10:00 / 01:20:00 import math def seek(): mp.commandv('show-text', format(mp.get_property_number("time-pos")) + " / " + format(mp.get_property_number("duration"))) def format(f): sec = round(f) if sec < 0: sec = 0 pos_min_floor = math.floor(sec / 60) sec_rest = sec - pos_min_floor * 60 return add_zero(pos_min_floor) + ":" + add_zero(sec_rest) def add_zero(val): val = round(val) return "" + str(int(val)) if (val > 9) else "0" + str(int(val)) #mp.Seek += seek mp.register_event("seek", seek) Last edited by stax76; 14th March 2019 at 05:47. |
18th March 2019, 14:42 | #52 | Link |
1.2
https://github.com/stax76/mpv.net/releases |
19th March 2019, 10:39 | #53 | Link |
1.3
https://github.com/stax76/mpv.net/releases https://github.com/stax76/mpv.net#powershell-scripting |
20th March 2019, 18:43 | #54 | Link |
1.4
21st March 2019, 15:41 | #55 | Link |
In the mpv SDK docs of Lua/JS I'm not sure I understand the following:
mp.get_property_bool(name [,def]) Similar to mp.get_property, but return the property value as Boolean. Returns a Boolean on success, or def, error on error. If the property is not available it returns the default value and if the property is not available and no default value was provided it returns an error. |
21st March 2019, 18:38 | #56 | Link |
1.5
21st March 2019, 19:44 | #58 | Link |
it's difficult because:
most difficult is I never make a easy decision on which programming language and UI toolkit to use, I don't like always using the same languages and toolkits. |
21st March 2019, 22:57 | #59 | Link |
cosmic entity
is there a list somewhere on wich settings i can use or are avaiable?
i find it hard to configure it, but i want to learn more of course.. also, is it possible to select the monitor that should be used? i have som eproblems with multimonitor config.. Thanks for this project, really liking the minimalism of it.. even doh its kinda hard to configure.. cheers |
22nd March 2019, 02:29 | #60 | Link | |
mpv.net has hardly documentation, only a few words at the start page:
https://github.com/stax76/mpv.net mpv.net supports many mpv features without difference, mpv is mostly documented here: https://mpv.io/manual/master Quote:
https://mpv.io/manual/master/#options-screen window related features however must be implemented in mpv.net, I should be able to add support for it. |
