20th April 2023, 20:48 | #1 | Link |
Audio only Blu Ray Disc using multiAVCHD
I've recently discovered and downloaded the multiAVCHD application in the hope of being able to burn 96Khz/24 bit/6 channel audio only files to a blank BD disc.
Unfortunately I keep getting the message about track duration not being detected and even when I manually enter the duration of each track, the process just stalls. Has anyone here had success in burning audio only BD discs with this program, and/or been able to overcome this specific issue? Thanks |
21st April 2023, 14:00 | #2 | Link |
Life's clearer in 4K UHD
Using what format as the audio stream?
22nd April 2023, 10:21 | #4 | Link |
That's not possible. You have to use an audio format that AVCHD supports. See the following: -
https://www.sony.com/electronics/sup...icles/00016537 https://en.wikipedia.org/wiki/AVCHD Personally, I think it would be really good if someone was able to get a stable freeware AVCHD muxer up and running, especially as the AVCHD 2.0 specification technically supports lossless PCM audio up-to 7.1 channels.
22nd April 2023, 15:41 | #5 | Link | |
22nd April 2023, 17:06 | #6 | Link | |
Cheers
23rd April 2023, 13:58 | #7 | Link |
Big Bit Savings Now !
What happens if you use tsMuxeR in AVCHD mode ?
23rd April 2023, 16:13 | #8 | Link |
I've tried this a few times over the years including yesterday using git-79b86ec.
Audio: LPCM 96/24 Video: AVC High@L4.1. Encoded from 72,700 (1920x1080) black images/frames at 24.000fps. Total run time: 50m 29s Methods tried: - Created an Blu-ray ISO file using TSmuxer GUI. Burned the .iso file onto BD-R media using ImgBurn. Created an 'AVCHD folder' mux using TSmuxer GUI. Used ImgBurn to create an .iso file. Burned the .iso file onto DVD+R DL media using ImgBurn. Outcomes: - Both discs will play through to the end (even through the DVD's layer change). However, as soon as I fast-forward through a track or skip to the next track (or tracks), the audio stops playing! Perhaps there's an option within TSmuxer GUI I've missed. Or maybe the video track is not up-to specification
23rd April 2023, 18:15 | #9 | Link |
Thank you, SMD. Will repeat that.
That would point to a DTS? PTS? flaw in tsMuxeR worth reporting, I guess. Just firing up TAW5: The maximum AVCHD audio preference there allows LPCM 96kHz 7.1ch Surround 20bpS resulting in 18432kbps. Have to get back to my larger repo for testfiles to mux and compare.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 23rd April 2023 at 18:36. |
23rd April 2023, 22:24 | #10 | Link |
I would like to experiment more as I really like the idea of (primarily) creating Blu-ray 'audio only' discs with 96/24 or 192/24 lossless LPCM audio.
Especially as BD-R single layer (25GB) discs often work out cheaper than DVD-DL (8.5GB) discs...
24th April 2023, 17:52 | #11 | Link |
Earlier today I tried various methods of adding 'black only' or 'white only' encoded video streams to the above mentioned LPCM 96/24 audio source.
Methods tried: - Encoded higher bit-rate 'black only' and 'white only' 24.000fps video streams along with closed GOP's every 24 frames and 0 b-frames. I split the 50m 29s LPCM 96/24 audio stream into 11No separate audio streams (at their original track lengths). A have also tried adding 'black only' or 'white only' encoded video streams to each one of the 11No separate audio streams. All in all I tried eight different methods, including selecting TSmuxer GUI's 'Mux CBR' mode (under the 'General' tab). Outcomes: - After creating each of the .iso files and mounting them on my Windows 10 computer, not even VLC or MPC-BE was able to fast-forward through a track or skip to the next track (or tracks), without the audio stopping!
25th April 2023, 01:03 | #12 | Link |
TAW5: quick and dirty AVCHD Audio mux test (for HDD/Memory, not using the AVCHD2.0 Progressive restrictions)
Just rendered and muxed a framecounter video (30000f FHD @ 23.976fps together with 2 LPCM audio tracks 7.1 96kHz 16bit (5.1 source +2 ch silence ). TAW5 warned this would be out of AVCHD spec (yes, I exceeded bitrate, intentionally to 26,5Mbps), and pressed the mux button anyway. Video came out as 0,55Mbps, audio as 12,3Mbps per track. MPC-HC 2.0.0 played that 00000.MTS flawlessly from SD, I could switch the 2 audio tracks, rewind and ffwd down to 0,06x, up to 128x. So it is well possible to mux such within TAW5 (TMPGEnc Authoring Works 5). Next I will try that with higher bit depths.
"To bypass shortcuts and find suffering...is called QUALity" (Die toten Augen von Friedrichshain) "Data reduction ? Yep, Sir. We're that issue working on. Synce invntoin uf lingöage..." Last edited by Emulgator; 17th May 2023 at 17:19. |
25th April 2023, 09:25 | #13 | Link | |
Would you be willing to upload your video so I can generate some test files with it?
25th April 2023, 15:57 | #14 | Link |
After more testing today I have established that my Blu-ray Audio disc playback issue is primarily related to how the video stream has been created.
After muxing full motion video (such as: MPEG-2, AVC or even VC-1) to the LPCM 96/24 audio stream, the disc works perfectly. Even if the video has been encoded with just 720x480 pixels. So in order to create a compliant Blu-ray Audio or AVCHD Audio disc, the trick is to determine what the lowest supported bit-rate for the video stream can be!
25th April 2023, 16:53 | #15 | Link |
That brings me to feed just
Blankclip(length=30000, width=1920, height=1080, fps=24.000*1000/1001, pixel_type="YV12",audio_rate=48000, stereo=true). Let's see what TAW5 makes of this.
12th May 2023, 14:21 | #16 | Link | |
While backing-up one of my HFPA Blu-ray audio discs I noticed that it contained some short black .m2ts video streams, which I've been able to copy and merge together multiple times into the required durations. Using the previously mentioned 'muxing methods' I've been able to create fully working 'audio only' discs burned onto either Blu-ray or DVD+R DL media. After creation I simple place the 'audio only' discs into my Blu-ray player and they behave just like an regular audio CD would... Brilliant.
