Old 19th February 2023, 19:46   #3021  |  Link
23.21 has no range issue and "no" deint issue.
the masters is ever so slightly flicker. same for the kanji or Chinese. that's a huge win in my book.
please wait for more tests a sample size of one is way to low.
edit: broken in madVR.
Old 19th February 2023, 21:19   #3022  |  Link
Sunspark
@huhn What are you observing that you say madVR has an issue? It is fine for me with 92.17 and my older hardware/driver combination. Try using quicksync decoding with the adaptive HW deinterlacing checkbox that LAV has.
Sunspark is online now   Reply With Quote
Old 19th February 2023, 21:37   #3023  |  Link
AMD deint does not work here at my end that's all.
i would never use quicksync i would never use software chroma scaling because it's bad and expensive compared to hardware/GPU.
i have no clue how intel performance these days i don't have any intel hardware i replaced all PCs in the past 2 years with ryzen CPU.
Old 8th April 2023, 23:42   #3024  |  Link
GTPVHD
https://www.intel.com/content/www/us...s-windows.html
This download installs Intel Graphics Driver 31.0.101.2121 for 7th-10th Gen Intel Core Processor Graphics, and related Intel Atom, Pentium, and Celeron processors.
6th gen Intel Skylake Gen9 integrated GPUs are no longer supported and will not receive any drivers updates.
End Of Life
6th Generation Intel Processor Graphics is an "End of Life" product as of December 30, 2022. For more support information, see Support Options for Discontinued Intel Graphics Products.
As this Software relates to “End of Life” products, it may contain security vulnerabilities. Intel does not intend to offer updates to mitigate any security vulnerability in this Software, whether currently known or discovered in the future.
GTPVHD is offline   Reply With Quote
Old 15th April 2023, 22:46   #3025  |  Link
mclingo
Hi, anyone still using amd 5000 series GPU running up to date windows 10 / MADVR who can still get 3D MVC to work, cant get 3D to trigger for the life of me, all the usual prerequisites are in place, movie starts, TV goes into 3D mode but movie plays in 2d, cant work it out.
windows 10 22h2
LG OLED EF950-YAM RX-V685-RYZEN 3600 - 16GBRAM - WIN10 RX 5700 - https://www.videohelp.com/software/madVR/old-versions
Old 15th April 2023, 23:09   #3026  |  Link
mclingo
seems to be an issue with full screen mode, using MPC-HC, if I double click on the movie to come out of full screen mode 3D MVC triggers, but dies again when I go back into full screen mode, any ideas anyone? - windows 10 22h2
Old 15th April 2023, 23:44   #3027  |  Link
mclingo
so after playing around with driver versions, MADVR versions, LAV filers etc etc nothing work but I played one video and accidentally triggered my on screen keyboard which came up over the top of the movie, bizarrely this fixes it, if I leave OSK on the screen and drag it down to the bottow so I can only see a small corner of it the movie plays fine, this is utterly bizarre, unless someone knows something I dont about 22H2 issues?
Old 16th April 2023, 10:08   #3028  |  Link
mclingo
doesnt seem to be a driver issue so I'll not post on here anymore as 3d work with potplayer and non MADVR renderer.
Old 17th May 2023, 08:28   #3029  |  Link
Sunspark
Originally Posted by Klaus1189 View Post
If you use madVR this bug is circumvented. So you will not see it. But it is in EVR and EVR custom presenter and also in MPC Video Renderer but only when using D3D9, that means if you check D3D11 in options you are fine.
I set up a Windows external drive on a mobile RDNA2 APU. Was pretty surprised when testing video to blacks washed out, but happy to report that MPC Video Renderer doesn't have this problem in Shader mode, even with D3D9.
Unforunately, the drivers from Valve are super busted in some aspects.. one is that they have no hardware acceleration at all for video decoding or encoding with Windows.
Old 19th May 2023, 21:38   #3030  |  Link
Goeggel
I have an issue with stuttering on 4K HDR MKVs with RTX 3080, Marantz SR-6011 and LG OLED65B8. 1080p SDR MKVs are fine. Latest madVR, LAV filters and Nvidia 531.79. Win 10 22H2. Zoom Player and MPC-BE.
Every half a minute or couple of minutes, the picture stumbles / stutters / jumps a few frames. Sound is fine. madVR display info doesn't show any frame drops. The issue is random and and always occurs at different time stamps.
With the same setup and a GTX 980, SDR and HDR were fine. Then I changed to a RTX 2070 Super. At first everything was fine. Then with around Nvidia 512.x and/or a Windows update, SDR and HDR were constantly stuttering. This was solved by:
- Vertical Sync to 'On' for the media player exe.
- In the madVR settings, uncheck 'enable automatic fullscreen exclusive mode
- In the madVR settings, how many video frames shall be presented in advance' to 1
Now with the RTX 3080, what else can I try to solve this stuttering with HDR MKVs?
Goeggel is offline   Reply With Quote
Old 22nd May 2023, 01:08   #3031  |  Link
Furgiuele
Help me!
Hello.
After using madvVR on the pc with Jriver Media Player for years, in 2020 I bought the Envy Pro.
But I continued to use the PC as a media server: on the PC madVR performs the upscaling (->4k, chroma, luma, etc.), the hdr is set to pass trough (sending metadata to the display) and the Envy performs the calibration (with 3d lut) and tone mapping.
For years I have had Nvidia 2060 card with 442 driver in my PC and everything worked perfectly.
A few days ago I changed GPU (for 3050) and I had to update the driver.
Since then, when madVR broadcasts HDR signal it gets stuck and if I throw an SDR video, it doesn't show well.
Can someone help me? Is there a Nvidia driver with which this error does not occur?
In the PC I have the latest edition of madVR (166). Is there another remedy?
Sony VPS-VW870ES, Panasonic TX-55GZ950. Trinnov Altitude 16. Krell FPB200C - KAV500 - ART SLA4. Infinity RS9K, K Ref, 4 x Modulus, 4 x Kef CI200QR, 2 x SVS PB12Plus. HTPC, Sky Q.
Furgiuele is offline   Reply With Quote
Old 22nd May 2023, 17:01   #3032  |  Link
Klaus1189
@Goeggel and @Furgiuele: Sounds to me that a new card was installed and a driver was installed. DDU the driver and install driver new. But don't forget to apply the needed settings in driver like VSync for player exe, ...
Old 26th May 2023, 18:04   #3033  |  Link
Crimson Wolf
Some weird video playback issue with 532.03. Whenever I watch a video larger than my screen and downscaling, I would have massive frame drops. For example, watching 4k60 video using mpv via yt-dlp downscaled to 1080p would show Display FPS: 119.982 (specified) ###.### (estimated) , where ###.### would be lower than normal which would cause frame drops constantly. For MPC-HC (madvr), Ctrl-J would start out fine, then constant frame drops, then fine again, then frame drops. It would also happen when watching 4k 24fps/30fps video as well. If watching 1080p video, no frame drops and mpv would show estimated FPS matching my specified.
I just DDU'd and installed the last studio drivers 531.61 and the issue is gone. I was not patient enough to find out if 532.03 was the issue or if it happened earlier.
Crimson Wolf is offline   Reply With Quote
Old 28th May 2023, 21:20   #3034  |  Link
SamuriHL
SamuriHL's Avatar
I really wish nVidia would do something about the Dolby dropouts. ATMOS tracks are a mess. It really sucks.
Old 29th May 2023, 08:23   #3035  |  Link
ryrynz
ryrynz's Avatar
I get the odd drouput over E-ARC with any audio which I suspect is related.
Old 29th May 2023, 13:49   #3036  |  Link
SamuriHL
SamuriHL's Avatar
No earc in this case. It's a 3080 connected to an avr.
Sent from my SM-G998U1 using Tapatalk
Old 29th May 2023, 23:40   #3037  |  Link
ryrynz
ryrynz's Avatar
I had the same audio issue before when running it out from a DP to HDMI adapter to the AVR as well. Thankfully it's not happening terribly often.
Old 30th May 2023, 18:20   #3038  |  Link
SamuriHL
SamuriHL's Avatar
Oh yey more "beta testing" for them. LOL
Old 14th June 2023, 23:57   #3039  |  Link
ryrynz
ryrynz's Avatar
I did a DDU and haven't had any audio issues since. Everything's peachy.
Old 16th June 2023, 10:53   #3040  |  Link
SamuriHL
SamuriHL's Avatar
I may try it. The dropouts are annoying.
