Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 28th November 2018, 09:14   #1  |  Link
srfscenar
Scenarist SD and Line 21 error
Hi all,
I added a trailer to my build and Scenarist keeps popping a Line 21 information error during the mux for that particular trailer. There is no line 21 file added for that trailer so no idea why it keeps showing that error.
If I check the Line 21 checkbox, without adding any files, the mux is finishing okay.
Anyone has any ideas? Will enabling the checkbox without files produce any issues to the final build?
Thanks!
Sent from my iPhone using Tapatalk
" 2 minds are better than 1 "
srfscenar is offline   Reply With Quote
Old 4th December 2020, 13:04   #2  |  Link
larisk2
Tell me, there is such a situation, when building in the Script this error:
Error: [MUX] can not write the file(s) MAX: the reference to the object is not set to an instance of the object.
And on the first two disks everything ends, and on the third an error.
larisk2 is offline   Reply With Quote
