19th July 2009, 11:53 | #23 | Link |
Program is crushing on this ASS file
http://rapidshare.com/files/25752121...f_25_.ass.html Is there any possibility to write log into a file? I can't get the problem string in ASS file and try to fix it manually. P.S. Is it possibly to make a bigger font in log window? |
19th July 2009, 17:37 | #24 | Link |
Hi Oleg,
That crash is quite an unusual one to fix for me, as it is in libass. Rather than delve into it's internals I've found a more recent version (http://greg.geekmind.org/viewgit/?a=summary&p=libass), thankfully this allows that subtitle to be produced! [In the future I'll keep in sync with this tree.] However as I'm quite close to figuring out the format of the large subtitle bitmaps, going to delay releasing this until the next release. It is about time the application got some preferences, so the release after that will also have configurable logging (including file redirection, font size and maybe png output). Thanks again for your bug reports! |
19th July 2009, 20:51 | #25 | Link | ||
Again, sorry for my English |
20th July 2009, 19:00 | #26 | Link | |
Anyway, waiting for new build. |
12th August 2009, 12:44 | #28 | Link |
hi I'm seriously busy with work at the moment, too busy too fix two outstanding bugs. I'll will be back as soon as I can to bug-fixing!
However as I can't afford that software supporting it's format wouldn't a priority for me, Sorry! Have you tried using the wonderful BDSup2Sub to convert from the pgs generated .sup to .bdn? |
12th August 2009, 19:19 | #29 | Link |
Thanks for the recommendation, BDSup2Sub worked like a charm.
However, If I use large font size, PunkGraphicStream just reports encode fails - Subtitle image too large. Try to reduce effects, font size or number of characters. Code:
[ass] **MSGL_V**: FreeType library version: 2.3.9 [ass] **MSGL_V**: FreeType headers version: 2.3.9 [ass] **MSGL_INFO**: [ass] Init [ass] **MSGL_INFO**: [ass] Updating font cache. [ass] **MSGL_V**: file size: 38462 [ass] **MSGL_V**: [05156488] Style: Default,Arial,28,&H00FFFFFF,&H000000FF,&H00000000,&HC8000000,0,0,0,0,100,125,0,0,1,1.2,0,2,10,10,50,1 [ass] **MSGL_INFO**: [ass] Added subtitle file: E:\punkgraphicstreamtry\engtotal_linespace.ass (1 styles, 372 events) [ass] **MSGL_V**: fontconfig_select: (Arial, 80, 0) -> C:/WINDOWS/fonts/arial.ttf, 0 [ass] **MSGL_V**: cache statistics: total accesses: 25660 hits: 25659 misses: 1 object count: 1 [ass] **MSGL_V**: cache statistics: total accesses: 821706 hits: 810012 misses: 11694 object count: 1266 [ass] **MSGL_V**: cache statistics: total accesses: 821706 hits: 810012 misses: 11694 object count: 1266 Another issue is that the output does not seem stay close to what my preview in aegisub/vsfilter was. I had some drop shadow applied, but the output seems ignoring it. Also the output doesn't seem to have the same aspect ratio as in the preview in aegisub/vsfilter, the subtitles appear to be crushed/rectangular in the x direction. I have to change Scale Y% to 125 to encounter the problem. |
12th August 2009, 21:31 | #30 | Link | |
Please correct me if I am wrong. And sorry for my English |
30th August 2009, 21:02 | #31 | Link |
The timing of the subtitles should adapt to the framerate chosen. Create an ass file (24000/1001 fps) and let a subtitle start on 00:00:01.00 ( the last zeros meaning frame #0) and it will create a sup file with the subtitle starting on 00:00:01.000 (last zeros meaning 0 ms) instead of 00:00:01.001.
26th September 2009, 21:39 | #32 | Link |
Hi All,
Just to let you know, Got some free time today and finally managed to figure out the multipart RLE bitmaps. Version 0.7 will be out next week, I've first got to rebuild all the libraries for a new libass version (0.9.8 has been released) and add Windows 7 support. P.S. sneaker_ger, I'll try to fixed the timing issue too. I'd it is caused by some over-enthusiastic overlap detection/merging of events. Thanks for continued patience! Uploaded Version 0.7, got testing the win32 version with tsMuxeR 1.10.6 seems fine, especially the multipart bitmaps , although I've yet to test complex animations with large bitmaps, it might be a challenge for devices to handle but it is not like I have access to the spec to avoid violations- as always test where you need these subs to work! (And please report success/failures thanks!) Last edited by slartibardfast; 27th September 2009 at 22:21. Reason: Version 0.7 |
3rd October 2009, 08:17 | #35 | Link |
Well, the new libass works much better (less "do not know how to decode" warnings), but large subs still have flickering. Especially complex subs - picture is in the upper and the bottom part of the screen.
Here is an example ASS file. Mux it with any 720p video. http://rapidshare.com/files/28804644..._-_01.ass.html Problem is on the first moving pink sub. May be this thread could be usefull http://forum.doom9.org/showthread.php?t=146493&page=4 Last edited by Oleg Rode; 3rd October 2009 at 08:23. |
3rd October 2009, 12:58 | #36 | Link |
Elit Amans
With the sub I posted a while ago in this thread: I only had flickering a couple of times on fades. I can't say about missing lines as I haven't watched the movie completely yet. But it seems like great improvement from the last version. Only thing I noticed.. The tooltips is still really confusing. (23.97 and 24 are switched)
But as I said before.. Great improvement Thanks!!! //LD |
30th October 2009, 23:23 | #37 | Link |
Hi All,
Sorry I seem to have somehow disabled email notification :-( my bad... Thanks for the link to that thread Oleg, some very interesting points are raised, never really considered the palette shifting as a solution to fading, there is a possibility that over the winter holiday I could bake some dirty hack into the renderer. Something like calculating the % of transparency of a faded image from the middle image and just use the centre image from the start with that % of transparency added to its palette. Unfortunately I'm really busy for the foreseeable future. I guess you are hitting the limits of the spec (which I am blissfully unaware of ), don't forget blu-ray players are embedded devices!!! Personally I don't use any animations or fades in the subtitles I make with PGS, for me it is all about good resolution fonts! Thanks also LowDead for the reports! Sorry about the tooltip Promise it will be fixed for the next release! |
2nd April 2010, 17:49 | #39 | Link |
Hi Guys!
Managed to free up some time to look at this again. I've released 0.7.1 which fixes a bug in the colour table generation which could cause invalid output and the tooltips. I've also improved the validation of the sup files. I've also tweaked the output validation, so there should be more warning when an invalid file has been generated. LowDead, unless you were running in this bug not much excitement tbh! The next version will probably concentrate on updating to the latest libass and more platforms, unless you have some feature requests? Cheers |
