6th May 2007, 12:06 | #22 | Link | |
Coder
Thanks! The -h worked well and create a huge pgs (43MB). How does the -u option work? Code:
Transport Sync Error, skipped 4 bytes, at 3218297 Transport Sync Error, skipped 4 bytes, at 3218298 Transport Sync Error, skipped 4 bytes, at 3218299 Transport Sync Error, skipped 4 bytes, at 3218300 Transport Sync Error, skipped 4 bytes, at 3218301 Transport Sync Error, skipped 4 bytes, at 3218302 Transport Sync Error, skipped 4 bytes, at 3218303 Transport Sync Error, skipped 4 bytes, at 3218304 Transport Sync Error, skipped 4 bytes, at 3218305 Transport Sync Error, skipped 4 bytes, at 3218306 Transport Sync Error, skipped 4 bytes, at 3218307 The .sup file contains 10 extra byte before every subtitle 'SP',PTS(4bytes),0x00000000 Edit: We can create a new file format for BD subtitles. We can use other two letters instead of 'SP' (for example 'BD' or something), and the 4 bytes long PTS value, and the subtitle segment data. Last edited by Pelican9; 6th May 2007 at 14:03. |
6th May 2007, 12:23 | #23 | Link | |
Coder
No. Yes. This information is confidental. |
6th May 2007, 12:39 | #24 | Link | |
xport -hus movie.m2ts 1 1 1 1 Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
6th May 2007, 13:52 | #26 | Link |
I meant just to get rid of the error messages and dump the PTS. I'll add the PTS header tomorrow (left coast time).
Ron
6th May 2007, 14:08 | #27 | Link | |
Coder
But I've thought about the header, and it would be better to use another two letters instead of 'SP', because the structure is quite different and it would be easier to program. |
7th May 2007, 07:02 | #31 | Link |
Here's the update:
http://www.w6rz.net/xportpgs.zip Make sure you clear your browser cache to get the latest. Files are dated 5/6/2007 at 10:55 PM. I chose to use "PG" (for Presentation Graphics) instead of "SP". Ron
7th May 2007, 09:36 | #32 | Link | |
Coder
This is the structure of one subtitle as I thought: ------------- 'PG', PTS, 0,0,0,0, (start time) 0x16, ... presentation composition definition (0x13 bytes) 0x17, ... window definition (0x0A bytes) 0x14, ... palette definition (0x4F8 bytes) 0x15, ... object definition (0x3087 bytes) 0x80, 0, 0 end of displayset 'PG', PTS, 0,0,0,0, (end time) 0x16, ... presentation composition definition 0x0B 0x17, ... window definition 0x0A 0x80, 0, 0 end of displayset ------------- Next subtitle This is the structure of the xported .pgs: ------------- 0x16, ... presentation composition definition (0x13 bytes) 0x17, ... window definition (0x0A bytes) 'PG', PTS, 0,0,0,0, (0xFB9B81) 3:03.215 0x14, ... palette definition (0x4F8 bytes) 0x15, ... object definition (0x3087 bytes) 'PG', PTS, 0,0,0,0, (0xFB9C00) 3:03.216 0x80, 0, 0 end of displayset 0x16, ... presentation composition definition 0x0B 0x17, ... window definition 0x0A 'PG', PTS, 0,0,0,0, (0xFE4620) 3:05.156 0x80, 0, 0 end of displayset ------------- Next subtitle What is the extra (first or second) PTS? Could you change something or I have to handle this structure? |
7th May 2007, 10:52 | #33 | Link |
I know what's wrong. Some segments have a PTS/DTS PES header, and I was only putting a header in the .pgs file on the segments with just a PTS.
Here's the update: http://www.w6rz.net/xportpgs.zip Files are dated 5/7/2007 at 2:48 am For the segments with DTS, I've put the DTS after the PTS. "PG", PTS (4 bytes), DTS (4 bytes) If you think the DTS is useless, and you'd rather have 0x0, let me know. Ron
7th May 2007, 12:01 | #34 | Link | |
Coder
All segment have their own PTS/DTS info. What do you think about the file extension? I mean the .sup is well known as subtitle file. But on the other hand .pgs shows that it is a different structure. Last edited by Pelican9; 7th May 2007 at 13:34. |
7th May 2007, 23:23 | #36 | Link | |
Coder
Did you decrease the PTS values with the PTS of the first video frame? I think you didn't, because the subtitles are delaying about 10 sec. Could you check it? And I vote the .sup extension too. Thanks in advance. Edit: SUPread v0.4b1 Last edited by Pelican9; 8th May 2007 at 00:12. |
8th May 2007, 11:23 | #37 | Link | |
http://www.w6rz.net/xportpgs.zip File times are 5/8/2007 at 3:16 am. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net Last edited by drmpeg; 8th May 2007 at 12:56. |
8th May 2007, 12:51 | #38 | Link | |
Coder
(The working link: http://www.w6rz.net/xportpgs.zip) Edit: Something wrong with the PTS/DTS adjusting. Original - Adjusted: 0xFBB289 - 0xFBB28A 0xFBB281 - 0xFBB282 0xFBB249 - 0xFBB24A ... Like the first video PTS is -1 (or 0xFFFFFFFF) I've expected something like this: Original - Adjusted: 0xFBB289 - 0xEDF6E9 0xFBB281 - 0xEDF6E1 0xFBB249 - 0xEDF6A9 ... Edit 2: It was my fault. I've used this command: xport -h 00001.m2ts 1 9 9 1 because I didn't want to demux the video and the audio stream but only the subtitle stream (not enough space on this drive). Is there a way to skip the video stream demux but get the first video PTS and make a .sup? Last edited by Pelican9; 8th May 2007 at 13:55. |
8th May 2007, 13:20 | #39 | Link |
SubtitleCreator's Co-Dev
Could you post an example of such an extracted SUP file so that I can try working on its import by SubtitleCreator?
(Or better a file from which to extract the sup plus the command line I must use). A short sample will be enough. Thanks Manusse |
