Old 26th June 2016, 17:02   #1  |  Link
kagetoki
Author of AVSEdit Plus
kagetoki's Avatar
AVSEdit Plus - official thread
AVSEdit Plus
https://sourceforge.net/projects/avseditplus/
I introduce a new AviSynth editing environment - AVSEdit Plus. The interface and the functionality is strongly inspired by the original AVSEdit. I have focused on creating a useful and efficient video preview feature that many of You may find interesting e.g. buffering frames into memory or side-by-side video preview. I encourage You to give it a try and I hope You will enjoy using AVSEdit Plus. You will find the latest build, source code and more details in the link above - at the official repository.
This is the official thread for AVSEdit Plus. Feel free to post here any suggestions, state issues and ask for improvements or bug fixes.
AVSEdit Plus is an AviSynth script editor with side by side preview and video encoding GUI for command line encoders:
- edit AviSynth scripts,
- preview script video results,
- buffer slow scripts and preview them in real time,
- enable side-by-side preview for two script video results,
- work with command line encoders using an encoding GUI,
- create an encoding queue.
Video tutorial on Vimeo (higher bitrate, recommended):
Video tutorial on YouTube:
https://www.youtube.com/watch?v=VWxd6YBTZZU
Changelog
1.25.0.0 / stable / 2016.08.26
[Script editor]
- Find feature with optional regular expressions included
(Menu > Edit> Find).
[Other]
- Translation bugs handled: English
1.24.0.0 / stable / 2016.06.29
[Other]
- Fixed a mistake in handling "AvisynthWrapper.dll was not found"
exception.
1.23.0.0 / stable / 2016.06.28
[Other]
- Improvements made to the installer. Program used to install the
database files to the install location. The database files are
installed to the user's profile now (User/AppData/Roaming) and are not
removed when the program is being uninstalled. When UAC enabled, in
versions below 1.23 the database files might have been redirected from
the install location to (User/AppData/Local/VirtualStore). You might
want to recover your previous database by copying it to
(User/AppData/Roaming).
- The installer remembers the custom install location for future
upgrades.
- Fixed an exception thrown when the database files/directory was not
found or deleted.
- Fixed an exception thrown when AvisynthWrapper.dll was not found or
deleted.
1.22.0.0 / stable / 2016.06.18
First version of AVSEdit Plus ever released. The following is a list of
initial features:
[Script editor]
- AviSynth script editor with line numbering, tabs, undo/redo function
and block commenting capability.
- Sortable list of standard read-only AviSynth functions. Add function
to the editor with double click.
- Sortable list of editable functions. Add useful script parts or
functions with customized argument lists. Edit, rename, delete, add to
[Video preview]
- Video preview of script video result. Many preview windows at the
same time. Right click to open settings and study the list of shortcuts
to all video preview features.
- Seek bar, frame seeking with keys or mouse. Video playback at
original frame rate. Go to a specified frame, copy the selected frame
to clipboard. Remove borders in the preview.
- Frame buffering is turned on by default. No more encoding of
extremely slow scripts to see the results, just let a part of the clip
to buffer into memory and play it at original frame rate.
- Side by side preview mode (dual preview). Set second script video
result in the same video preview to watch before/after changes. Move
the splitter with mouse, change the splitter orientation.
- Zoom in/out the whole frame. Crop preview to a specified range.
- Clip properties shown, values may be copied: current frame and time,
clip frame length and time duration, zoom, video resolution, current
crop values, clip frame rate, video aspect ratio, system memory
information, buffer statistics for each clip in dual preview mode.
- Trim editor. All clip selections made in the preview are stored here
and may be copied to clipboard in AviSynth format. Paste it into your
script.
[Encoding GUI]
- GUI editor for command line encoders. Create and save your custom
commands for CLI encoders with the help of prepared forms. Choose
encoder, opened script (input), destination path (output) and add the
command to the batch queue.
- Sortable list of your encoder commands. Edit, rename, delete, add to
the command editor.
- Batch queue. Change job status with double click, edit or delete
commands with right click. Start or stop queue processing, each job
opens in a separate command line window.
[Other]
- Program global preferences. Any modifications made here become
default in the future unlike most ones made locally.
- language localization: English, Polish.
Known issues
- 2GB memory limitation per x86 .NET process. This limits a video
buffer capacity although there is still more physical memory left on
the system.
- No syntax highlighting developed yet.
- No code complete feature developed yet.
- Firing [AvisynthWrapper.dll].dimzon_avs_init while being very low on
memory may lead the application to freeze instead of throwing an
emergency shutdown of the video preview.
- Cannot drag & drop .avs files directly onto the script editor to open
them.
- Troubles with selecting text by mouse in the script editor moving to
the left edge when the line's length exceeds the visible width.
- No x64 AviSynth support yet. Using Dimzon's AvisynthWrapper which is
x86 only.
kagetoki is offline   Reply With Quote
Old 26th June 2016, 17:06   #2  |  Link
kagetoki
kagetoki's Avatar
Reserved
Old 26th June 2016, 17:33   #3  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
WOW! Downloaded.
Will install tomorrow.
Edit: couldn't wait to try it.
System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\AVSEdit Plus\data\settings.xml' is denied.
You can't have your settings file under Program Files as your application can't write to that folder. You must move your settings file somewhere else.
I've done that same mistake before in some other app.
MysteryX is offline   Reply With Quote
Old 26th June 2016, 17:33   #4  |  Link
luigizaninoni
Looks interesting. No AVS+ 64-bit ?
luigizaninoni is offline   Reply With Quote
Old 26th June 2016, 18:39   #5  |  Link
kagetoki
kagetoki's Avatar
There are going to be lots of bugs at first as it's the first release and I have been the only tester so far. Forgive me and be patient while I try to fix it.
I know I had been quite aware of the potential problem before the 1.22 release but I tested it on an admin account with Windows UAC enabled and it worked fine moving the database files to Virtual Store automatically. Will fix it. Until then, use the portable .zip version, please.
Unfortunately I use dimzon's x86 AvisynthWrapper that won't cooperate wit x64 AviSynth, I guess. But I may be mistaken. Will check it if sth can be done.
Old 26th June 2016, 18:43   #6  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Best first post ever!
I started work on something similar years ago, but never had the time to finish it up. I planned to have the same split-bar comparison thing, though I was going to do it so that you would prepare your script with a stackhorizontal or stackvertical, and the program would let you swipe between the two halves of the output.
Something else I planned was to have control over conversion to RGB and also bobbing, external to the AviSynth script being edited. So for example, if you were working on interlaced video, you could view a bobbed preview without having to add bob() to your script (frame numbers could count as 0T, 0B, 1T, 1B etc). You could also select which colour matrix you wanted to use to convert to RGB for display. This was all going to be done using env->invoke.
The buffering for previews looks great, too. I had all kinds of ideas, such as: if someone starts seeking backwards (left arrow) don't just get the previous frame; go back a few frames more and work forward. If they keep seeking backwards, jump even further backwards. I hoped that - at least on simple formats like MPEG2 - it would allow smooth reverse seeking, which you just can't do with Virtualdub. I also thought about caching many frames as low quality JPEGs to allow fast scrubbing, or allowing the user to somehow specify a "low quality" version of their output. For example, they could set a special line of AviSynth code (lo_quality_clip_=source.bob) which would allow fast scrubbing, with the full quality frame (generated, for example, using QTGMC) only being displayed once scrubbing stopped.
Other ideas: a tooltip to give information about individual pixels, such as RGB value or YUV value, or if you zoom in far enough, to have these numbers printed on the pixels themselves.
A timeline below the video, on which you could set markers for interesting places in the video, or scene changes.
Copying and pasting:
The ability to copy a frame onto the clipboard, edit it in (for example) Photoshop, and paste it back on to the video. This would then generate a "diff" file which you could apply to your AviSynth script with a plugin.
Syncing:
Two or more instances of the program could be set to "sync" which would mean moving to another frame would also make any other "sync"ed instance move to the same frame.
I hope some of this might be useful to you.
wonkey_monkey is offline   Reply With Quote
Old 26th June 2016, 20:01   #7  |  Link
geometer
Really great idea!
So far I use AviDemux (connected to frameserver) for the simpler adjustments, as it has sliders and [x] check boxes for the parameters and many filters have an instant preview. Also, it can freely skip forwards and backwards one or many frames, though not entirely stable.
Suggestion:
Parameter sliders and checkboxes with fast preview cycle.
- for this we preselect one frame or a very short sequence in the video.
- we define the parameter(s) either in a template script with the syntax: myfunction(&val1&,&val2&,&val3&) ## &def val1:integerslider; &def val2:floatslider; &def val3:checkbox
-- so the actual script will be rewritten from that template,
- or we create reserved variable names and the function uses the variables as usual, and the script mechanism sets the variables with inserted/replaced assignment statements.
-- val1 = 100 ## &integerslider # 100 is the initial value to start that experiment from
- the sliders might appear in a pop-up window with the variable names written below
- a move of a slider triggers the redisplay mechanism, this can be switched off.
geometer is offline   Reply With Quote
Old 26th June 2016, 21:56   #8  |  Link
GMJCZP
GMJCZP's Avatar
Welcome to the forum, kagetoki.
I've always used VDubMod for these tasks but keep an open mind to new ideas. Thanks.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 27th June 2016, 03:40   #9  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Toolbar buttons need tooltips to say what they do. It's really obvious for most buttons anyway except the 2 '#' buttons. This change is very easy to add.
Clicking the '#' makes it easy to see what they do. Still, just out of respecting coding standards
Old 28th June 2016, 22:45   #10  |  Link
kagetoki
kagetoki's Avatar
AVSEdit Plus 1.23
New version has been released. See the Changelog section in the first post for the complete list of changes.
Old 29th June 2016, 00:44   #11  |  Link
Thank you kind sir.
Nice to see source available and also not Pascal (or Delphi maybe) as the original. [EDIT: Seems much C#]
Old 29th June 2016, 03:14   #12  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Now when I try to run the script, it says:
File was not found:
F:\AVSMeter\TestImage\tools\AvisynthWrapper\AvisynthWrapper.dll
Ctrl+F to Find would be an important feature to add
Old 29th June 2016, 05:37   #13  |  Link
real.finder
thank you for develop AVSEdit
I think if every script run in it's own process then you can even make side-by-side preview for two different AviSynth (x64 and x86) by an option to change that for every script, Regarding AvisynthWrapper, I think you can dispense it by make a tool in .exe that load AviSynth .dll directly just like avsmeter or mp_pipeline
See My Avisynth Stuff
Old 29th June 2016, 06:36   #14  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
+1 for running scripts in different processes. It would also greatly add to the stability as AVSEdit wouldn't crash if the script crashes.
Old 29th June 2016, 10:51   #15  |  Link
kagetoki
kagetoki's Avatar
AVSEdit Plus 1.24
Old 29th June 2016, 11:25   #16  |  Link
Groucho2004
One little cosmetic thing I noticed:
The file type combo contains Polish text (on English Windows).
Otherwise - nice program!
Groucho's Avisynth Stuff
Old 29th June 2016, 13:51   #17  |  Link
kagetoki
kagetoki's Avatar
Thank You all for the warm welcome of AVSEdit Plus, I appreciate Your fast feedback
Thanks. You give many great ideas which some of them I hope to use in the future. I've already been thinking about low quality JPEG buffering to extend buffered frames count.
Originally Posted by geometer View Post
Suggestions
Thank You for your suggestions. Instant-preview sliders may appear somewhen, that'd be some new quality.
I hate tooltips popping up when the button images are obvious enough especially when there are only a few custom buttons. I had disabled tooltips on purpose. Yet, I reactivated them for the custom buttons.
File was not found:
Thanks MysteryX for the quick response to the error. I didn't do enough testing, and made a mistake. Gonna think about Ctrl+F too.
I admit to have been thinking about it since the beginning, however I hadn't felt strong about multi-process coding back then. Will rethink the approach to this matter.
Nice catch! Will be fixed in the next release. Why translating using resources? When I was choosing the method, I simply found it'd be faster to click through designers at first, knowing what is what.
Old 29th June 2016, 14:45   #18  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
If you could run the script in one thread and store the cache in the main thread, that would solve a lot of memory issues.
In C#, there are several ways to share data between processes and Named Pipes may do what you need.
Old 29th June 2016, 14:58   #19  |  Link
Groucho2004
What cache?
Old 29th June 2016, 15:02   #20  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Didn't he say he's buffering the video to facilitate playback and that caused memory to run out?
avisynth editor, avisynth script editor, avsedit plus, encoder gui, side by side
