Old 24th February 2006, 21:39   #81  |  Link
Sirber
retired developer
Sirber's Avatar
0.7.1.1 works fine in some place, but not others, using the same code. It's wierd.
Sirber is offline   Reply With Quote
Old 24th February 2006, 22:13   #82  |  Link
LAIN
RealAnime dev
LAIN's Avatar
Originally Posted by Kurtnoise13
I'm testing the last version with my Delphi tool and it works fine...pb with the Handle maybe.
Ok... i'll continu to take a look and i'll ask sirber to do some test... maybe it's a p4 problem :P
Thank you
LAIN
よろしく。 <- if you see "???" you need japanese fonts ;)
LAIN is offline   Reply With Quote
Old 24th February 2006, 22:20   #83  |  Link
Sirber
retired developer
Sirber's Avatar
We'll use the 0.7.1.0-dev (pre 0.7.1.1, post 0.7.1.0) if we get no news from Zetriman.
Old 25th February 2006, 11:37   #84  |  Link
Zenitram
Sorry, I will not have time to work on it this Week-end.
This is not normal, I have not change a lot ot things (maiunly changed of compiler : Boraland to Microsoft)
And I will need more info, let's see you on IM...
Want to know all about your media files? http://mediaarea.net/MediaInfo
Zenitram is offline   Reply With Quote
Old 16th March 2006, 16:54   #85  |  Link
Sirber
retired developer
Sirber's Avatar
I get a lot of Access Violation uising MediaInfo 0.7.2.0 on MKV. Contact me for more infos.
Old 17th March 2006, 03:00   #86  |  Link
Sirber
retired developer
Sirber's Avatar
Procedure:
1) Get reaanime 4.1.0
2) Drag the MKV I sent you
3) Start encode
4) While Analyzing, right click the file and press Info.
--> Access Violation
Kill RealAnime4.exe or else you'll be stuck in a crash loop.
Now retry with the AVI I sent you. After #4, we see the info as it should be.
Verdict: death errr MKV is borked
I tryed with 0.7.1.0, same problem.
Old 17th March 2006, 03:04   #87  |  Link
Sirber
retired developer
Sirber's Avatar
AVI and MP4 are #1.
Old 29th March 2006, 01:06   #88  |  Link
Sirber
retired developer
Sirber's Avatar
using:
MediaInfo_Close(handle);
MediaInfo_Delete(handle);
Maybe the AV is on my side (the one I talked to you about eariler), since this one tells explicitly it's MediaInfo.
Old 29th March 2006, 01:09   #89  |  Link
Sirber
retired developer
Sirber's Avatar
Here's the screenshot of previous RA AccessViolation:
Old 29th March 2006, 01:20   #90  |  Link
Sirber
retired developer
Sirber's Avatar
I get the popup (MediaInfo.dll) using the MKV I sent ya, but not my AVI test, by just asking "Info" on it.
Old 29th March 2006, 07:29   #91  |  Link
Zenitram
I have not the time to work on MediaInfo DLL now, you will have to waite some days/weeks...
Old 1st April 2006, 15:32   #92  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Sirber : could you put online your mkv which fails with this library ? I would like to check something. Thanks..
Old 1st April 2006, 15:44   #93  |  Link
Sirber
retired developer
Sirber's Avatar
At the moment mkvmerge does not support converting from VfW-mode AVC/h.264 tracks to native Matroska-mode AVC/h.264 tracks. You can, however, first import the video track into a MP4 file with e.g. 'MP4Box' (use Google). Then you can use mkvmerge and put the video into a Matroska file.
bad source, BAD!
Death to VFW!!!!
Old 12th April 2006, 04:03   #94  |  Link
chipzoller
Mr. Woof
chipzoller's Avatar
Thank you for a great piece of software. I use it all the time!
chipzoller is offline   Reply With Quote
Old 22nd April 2006, 08:07   #95  |  Link
thuongshoo
I used Belight to convert a wav file to aac
I uses Winamp-encoder . AVIcodec says source file has 44khz samplerate . MediaInfo always says that destination file has 22khz samplerate after I try to convert this file with many samplerate. AVIcodec and Gspot isn't also stable
thuongshoo is offline   Reply With Quote
Old 22nd April 2006, 11:34   #96  |  Link
Zenitram
I am interested in all files which have a problem with MediaInfo.
Please send me axample files with different bitrates at zen@mediaarea.net
Old 22nd April 2006, 22:20   #97  |  Link
multicone
matroska people have added a link to Mediainfo on their download page : http://www.matroska.org/downloads/windows.html
Looks like they are happy about the great MKV support in your app, Zenitram
multicone is offline   Reply With Quote
Old 23rd April 2006, 10:36   #98  |  Link
thuongshoo
Thank for interesting my problem !
My wav file is made by Virtualdub . Perhaps AVIcodec only say right if file isn't AAC, MP4
You can download Belight , AVIcodec and do some transcoding .
Sometimes AVIcodec and Gspot say right but MediaInfo isn't . Media Classic Player seem to say right but I still know it actually . I will post more information at next post
Old 23rd April 2006, 10:40   #99  |  Link
Zenitram
I already do a lot of transcoding, but never the one you do.
This is why I am interested in your files, to have not "common" (from my point of view) files.
Old 23rd April 2006, 15:07   #100  |  Link
Sirber
retired developer
Sirber's Avatar
@Zenitram
You should update first post for 0.7
