Old 7th June 2005, 15:41   #41  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Can anyone confirmed that 2 videos and more into a mp4 file muxed with mp4box last compile crashes during the playback with Osmo4 ?
btw it seems to play fine with mpc...
/me goes back to Yamb dev right now...
Old 8th June 2005, 13:04   #42  |  Link
Drachir
Teetrinker
Drachir's Avatar
Osmo4(CVS)@Linux don't crash here with a Mpeg 4 Systems presentation with two video stream or with an ISO Media File with two video stream.A Mpeg 4 Systems presentation make more sense if more then one video stream is used.
Play GO ( http://en.wikipedia.org/wiki/Go_(board_game))
Drachir is offline   Reply With Quote
Old 9th June 2005, 15:41   #43  |  Link
yaz
n00b ever
just found
	- updated configure for opengl disabling and fixed-point configuration
  - misc fixes in ffmpeg decoder and MP4Box ISMA for amorphic video (PAR!=1:1)
  - misc updates in MP4Box meta handling for item extraction.
  - fixed MPEG-2 aac importing and info dumping
  - fixed 3GPP text display bug when stoping and changing an animationStream using a 3GPP text object.
  - fixed AVC/H264 HP parsing
  - added BIFS track visual size info at BT/XMT encoding stage
  - MOVED FFMPEG INCLUDE FILES TO LATEST CVS VERSION to support AVC/H264 HP decoding
	- added meta self reference item for dual-headed files
	- commit MPEG-4 LATM Audio hinting patch and added rtp aggregation. RTP reassembler NOT UPDATED YET
	- fixed bugs in TeXML parser
	- fixed bt/xmt to MP4 encoding for IOD with single BIFS ESD.URLString set
	- fixed SVG outline handling and SVG/SMIL anim on appearance/geometry
	- fixed svg_loader compilation on winCE (ARM binaries and include to follow in next release of gpac_extra_libs)
	- commit of SVG fixed-point version
	- Fixed MP4Box spliter crash introduced by MetaBox support.
	- Merged MP21 and MP4 handling, added meta support in MP4Box (creation/extraction - cf MP4Box -h meta)
	FROM THIS DAY ON, ALL WORK ADDED TO GPAC IS COPYLEFT ENST
u know where to go
happy wrapping !
the bests
y
yaz is offline   Reply With Quote
Old 9th June 2005, 16:01   #44  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
New MP4Box.exe Compile
It looks as though Celtic Druid has generated a new MP4Box.exe compile for us all.....
MP4Box.7z 09/06/2005 15.56.06 326K
Many thanks
Old 9th June 2005, 16:08   #45  |  Link
Elias
Be Brave!
Elias's Avatar
This is all very nice. Anyone knows where I can get the latest source code for Linux? I want to start using this pwnage software on Linux
Elias is offline   Reply With Quote
Old 9th June 2005, 16:23   #46  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
cvs co :pserver:anonymous@cvs.sourceforge.net:/cvsroot/gpac gpac
Old 10th June 2005, 08:35   #47  |  Link
Kurtnoise
Kurtnoise's Avatar
10x...I updated the GPAC framework and it works great now.
Old 10th June 2005, 08:56   #48  |  Link
SeeMoreDigital
Sounds good Kurt.......
A few days ago, I also sent a message to Jean Le Feuvre, informing him of this very thread, here on Doom9...
Comment Sent: 2005-06-04 13:57
Hi jeanlf,
Just thought I would let you know that we have started
an "GPAC MP4Box Information and Discussions"
thread over on the Doom9 forum. Which can be found
here: -
http://forum.doom9.org/showthread.php?t=94874
If you have any time to spare we would be happy to
welcome your presence and any comments you can
offer.
Kind regards
SeeMoreDigital
Comment Received: 2005-06-09 13:21
Sender: jeanlf
Good job, and already some interesting discussions. Hope I'll
have time to post there - once I get back in sync with all my
late gpac mails...
Oh, and keep spreading the news
jean.
So it looks like we might be gaining a new forum member
Old 12th June 2005, 09:50   #49  |  Link
SeeMoreDigital
Celtic_Druid has generated a new MP4Box. exe compile: -
MP4Box.exe 11/06/2005 4.56.14 327K
Many thanks again
Old 16th June 2005, 08:26   #50  |  Link
Kurtnoise
Kurtnoise's Avatar
It seems there are some changes according to the changelog :
- Preparing 0.3.0 release
- fixed bug in SDP playback without RTSP session attached (live casts)
- added language and delay selection at import time (cf MP4Box -h import)
- made -lang able to change all tracks languages by default !erase language specified at import time!
btw, Many thanks to Bond for the request.
Old 16th June 2005, 10:05   #51  |  Link
SeeMoreDigital
I noticed from one of Bobololo's posts that MP4Box has the ability to display an encodes bit-rate: -
Is implementation available in YAMB, or have I missed something (again)?
Cheers
Old 16th June 2005, 10:26   #52  |  Link
Kurtnoise
Kurtnoise's Avatar
Hi SMD,
It should works in "Extract tab"...
Old 16th June 2005, 11:43   #53  |  Link
SeeMoreDigital
Originally Posted by Kurtnoise13
Hi SMD,
It does not appear to
Cheers
Old 16th June 2005, 13:28   #54  |  Link
Kurtnoise
Kurtnoise's Avatar
Indeed...I'll add it.
Old 16th June 2005, 13:57   #55  |  Link
SeeMoreDigital
Cool
Given the .MP4 container is becoming much more popular, I wonder whether it's time to start discussing tools that can provide more detailed information abut the encoded stream(s). Such as: B, I, P, S frames, aspect ratio signalling etc.
Admittedly, it's possible to de-muxed Mpeg4 SP/ASP .AVI streams and run them thru' MPEG Modifier to obtain very detailed information about the video stream (putting Open DML and/or 2/4GB issues to one side). But there does not appear to be any such option for Mpeg4 AVC streams!
Then there's the question about adjusting the PAR/DAR signalling of both Mpeg4 SP/ASP and AVC streams within the .MP4 container.
Cheers
Old 17th June 2005, 07:26   #56  |  Link
GUTB
I'm just ignoring mp4box and all other half-baked mp4 tools until they can mux h264 and acc together. Until then the vdub/x264/vbr-mp3 regime will continue uncontested.
GUTB is offline   Reply With Quote
Old 17th June 2005, 08:12   #57  |  Link
Doom9
clueless n00b
Huh? mp4box has done that for some months now
Doom9 is offline   Reply With Quote
Old 17th June 2005, 10:56   #58  |  Link
Elias
Be Brave!
Elias's Avatar
Trust me, MP4Box isn't buggy like mp4UI. In fact, don't be surprised if MP4Box muxes MPEG-4 video and MPEG-4 audio better than VirtualDub does. I was thinking exactly like you at first, since mp4UI was buggy, and mp4creator generated buggy mp4 files as well (haven't tried mp4creator lately, but a couple of months back, it was buggy too), but take my word on it: MP4Box knows what it's doing.
Old 17th June 2005, 17:41   #59  |  Link
SeeMoreDigital
MP4Box.7z 16/06/2005 13.27.30 328K
Many thanks
Old 18th June 2005, 04:46   #60  |  Link
celtic_druid
celtic_druid's Avatar
17/06/05: GPAC 0.3.0 release
I'll put a full package up later.
celtic_druid is offline   Reply With Quote
