#61 | Link | |
Clouded
FWIW, I think this is a very convenient feature to have.
#62 | Link |
Funny, relative paths was exactly what my next request was going to be.
I tend to make my .d2v in the same location as my source files, and sometimes I move them from one machine to another. Directly editing the .d2v to reflect the new path of the source files is possible, but cumbersome when I have 60+ .ts files in the .d2v. Perhaps a rootPath could be "set" at the beginning of the .d2v that could be edited so when they do get moved, only a single line needs to be modified. |
#65 | Link |
The video you're processing probably doesn't use pulldown flags. Instead it actually has the frames in it to make it 29.97fps. The fact that some of those frames are dupes or blended (if interlaced) is what makes it get detected as FILM. Those frames get dropped when you IVTC it to bring it back down to 23.976 (as close to FILM as you'll get).
#66 | Link |
Please don't post questions/problems in this thread. Thank you.
When you Ignore Pulldown Flags, DGIndex does not change the framerate; it just reports the stream value. Using general pulldown, the base rate could be anything. If DGIndex ignores the flags, he can't guess the base rate, so he just reports the stream value. |
#69 | Link |
I recently posted a request for replacing 2.0 AC3 with 5.1 silence. I'd like to slightly revise that.
I'd like to be able to replace 2.0 AC3 with 5.1 AC3 of the same bitrate that remains in the audio stream (or be able to select a bitrate for the silence). For example, I have a stream with 5.1 @ 384k that switches to 2.0 @ 384k. When using ProjectX to replace the 2.0, it repalces it with a silent sample at 448k. It should be 384k, but I have no way of telling it to do that... |
#71 | Link |
When I open file in DGIndex I can't find information window (only when playing or previewing). Sometimes it's wanted to see information while frame-by-frame seeking.
Кайда барасын, Пятачок? ...let me see you stripped... |
#72 | Link |
Split By Chapter
I convert alot of songs DVD's into VCD using DGIndex. I Rip the DVD in DVD Decrypter using IFO Mode and File Spliting is set to "By Chapter". So I have to manualy create projects for all the chapters.
I would like you to implement a feature in DGIndex that Automaticaly Creates D2V and AVS files per chapter (IFO Parsing). And thank you for such a great tool.
#73 | Link |
Enthusiast
Speed increase for AMD Turion 64
The AMD Turion 64 laptop processor changes speed constantly using multipliers 4, 8, and 10. When I encode with VirtualDub, the speed stays at 2GHz (10 x 200), but when I make a D2V in DGIndex, the speed is at 1.6GHz (8 x 200). I think, because I had a AMD Athlon 64 2.2GHz PC before, that this 400MHz might make a difference in speed (consider: 3 minutes for a normal length movie with Skal SSE MMX on the Athlon 64 processor although it was 2.2Ghz not 2Ghz, 15 minutes for this Turion 64 at 1.6GHz with Skal SSE MMX) So somehow, DGIndex would somehow need to tell the processor or OS drivers to keep the speed to the maximum (or prioritize). Windows prioritizing does not work on this.
I don't know much on the subject, but somehow the processor or VirtualDub know to keep the speed at 2GHz for encoding. Or, is the speed because of the laptop HD speed (4200 RPM)? Even with 7200 RPM a USB2 HD, it seems to be about the same. |
#74 | Link | |
#75 | Link |
User of free A/V tools
File Version number update?
Hi neuron2,
I just downloaded your 1.4.8 Final release and found out that the File version (File->Properties | Version tab) of both DGIndex.exe and DGDecode.dll is still showing 1.4.7.0 although the Product version in details tab reports properly 1,4,8,0 Could you please re-release those files so that no users would be confused about version numbers inconsistency?
#76 | Link |
I updated the zip files to correct this. Thanks for pointing it out.
(May I ask next time can you please not wait for my final release to report things? The 1.4.8 beta has been ongoing for a long time, at any point of which you could have reported this.) |
#77 | Link | |
At that time I didn't check the file properties at all because I was eager to try it out after reading all included documentation and help files. Anyway, it's a terrific piece of work you made on it, keep it up
#78 | Link |
Duke is my hero
Hi neuron2 i have problem with linking dgdecode from latest sources from your web
link says that a symbols @simple_idct_mmx and @Skl_Dct16_SSE defined in asm files (simple_idct_mmx.asm and skl_dct_sse.asm) are unknown (compiling is ok...)... whath i may do to fix it ???
NVIDIA CUDA(5.0 RC) on 460M Last edited by devaster; 4th August 2006 at 13:52. |
#80 | Link |
Duke is my hero
I have:
- both asm in project - nasm is installed and functional as i have wrote compiling is ok (when i havent a nasm then woudnt compile due a custom build step error) ![]() only linking is a problem today at 23:00 ill sent to this forum a full error statement from VS from my home - it would be better
NVIDIA CUDA(5.0 RC) on 460M Last edited by devaster; 4th August 2006 at 14:59. |
| Display Modes | |
