#1 | Link |
HDR to SDR StaxRip Problem
I am having this problem in StaxRip: https://github.com/staxrip/staxrip/issues/1891
One guy said: "Dolby Vision requires YCbCr 4:2:0 color space. Just make sure you convert the video (back) to YUV420 before you send it to x265." But how do I convert the video (back) before I send it? |
#3 | Link |
Donor
![]() Join Date: Jun 2024
Is there an option in StaxRip for output pixel format?
As an alternative, you can try in FFmpeg: Code:
ffmpeg -init_hw_device vulkan -i SOURCE.mkv -map 0:v:0 -map_metadata -1
-vf libplacebo=w=-1:h=1080:upscaler=spline36:downscaler=spline36:colorspace=bt709:color_trc=bt709:color_primaries=bt709:range=limited:format=yuv420p10le,sidedata=delete
-c:v libx265 -preset slow -crf 18 -x265-params level-idc=41:no-sao=1:deblock=-1,-1:aq-mode=1 OUT.mp4
#4 | Link |
Hi jay123210599,
could you upload a short cutout of your source clip, and also your desired target format and frame size? My conversion options are limited to DGHDRtoSDR for Avisynth+ (using old StaxRip 32bit version), and to zimg based scripts for FFmpeg. Cheers manolito |
#5 | Link |
Donor
![]() Join Date: Sep 2025
@jay
DGHDRtoSDR() can output 4:2:0 with fulldepth=false (default). Note it runs on Avisynth+ or Vapoursynth. It's intended for an nVidia graphics card. However, you can run it in software mode with impl="sw", but it's rather slow. Other filters like libplacebo would be faster. That should be enough to get you going using a manual approach with avisynth+/vapoursynth/x265. I cannot help with staxrip, due to my ignorance of it, and not anything against staxrip, which is a fine application. Like Z2697 said, what are you talking about if you are going to SDR? Last edited by Columbo; 10th January 2026 at 18:01. |
#10 | Link | |
ffx264/ffhevc author
![]() Join Date: May 2007
For ffmpeg, see example above by GeoffreyA (the format= filter) What did you not understand?
The Cyberpunk Database || NTP & NTS Time Server || Mirror Services ffhevc || ffx264 || ffxvid |
#11 | Link |
Donor
Post a screenshot of the dialogue boxes. I am guessing that near to where you selected Placebo, the output pixel format will be. Perhaps it's set to YUV444. Then, set DV to None.
#12 | Link |
@microchip8 @GeoffreyA
Here's my dialogue boxes: https://imgbox.com/BL44UHX3 https://imgbox.com/qdtQrWUZ |
#13 | Link |
Your input is already YUV420! There is no conversion needed.
#14 | Link |
All right, but now I have this error.
vpy [INFO]: using external VapourSynth library from: "C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\VSScript.dll"
vpy [INFO]: VapourSynth Core R73
Allocation of size 252K failed: VK_ERROR_OUT_OF_DEVICE_MEMORY!
Memory heaps supported by device:
0: flags 0x1 size 23G
1: flags 0x0 size 15G
2: flags 0x1 size 214M
Memory pool 0:
Compatible types: 0x3
Optimal flags: 0x1
Slab 0: 8 x 15M: 24M used 47M res 63M alloc from heap 0, efficiency 50.98% [../subprojects/libplacebo/src/utils/upload.c:239]
Pool summary: 24M used 47M res 63M alloc, efficiency 50.98%, utilization 75.00%
Memory pool 1:
Compatible types: 0xffffffff
Optimal flags: 0x3
Buffer flags: 0x3
Slab 0: 8 x 15M: 22M used 45M res 60M alloc from heap 0, efficiency 50.00% [../subprojects/libplacebo/src/gpu/utils.c:576]
Pool summary: 22M used 45M res 60M alloc, efficiency 50.00%, utilization 75.00%
Memory pool 2:
Required flags: 0x1
Optimal flags: 0x2
Buffer flags: 0xc3
Pool summary: 0 used 0 res 0 alloc, efficiency 100.00%, utilization 100.00%
Memory summary: 47M used 93M res 124M alloc, efficiency 50.50%, utilization 75.00%, max page: 1520M
Backtrace:
#0 0x7ff81c4769ed in pl_vulkan_release_ex+0x748d (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x869ed) (0x240ac69ed)
#1 0x7ff81c478042 in pl_vulkan_release_ex+0x8ae2 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x88042) (0x240ac8042)
#2 0x7ff81c46ac82 in pl_vulkan_sem_create+0x1082 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x7ac82) (0x240abac82)
#3 0x7ff81c452f01 in pl_buf_create+0x211 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x62f01) (0x240aa2f01)
#4 0x7ff81c459618 in pl_timer_query+0x44f8 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x69618) (0x240aa9618)
#5 0x7ff81c454ab0 in pl_pass_run+0x420 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x64ab0) (0x240aa4ab0)
#6 0x7ff81c43dfcc in pl_find_error_diffusion_kernel+0x54c (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x4dfcc) (0x240a8dfcc)
#7 0x7ff81c4416a7 in pl_dispatch_finish+0x747 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x516a7) (0x240a916a7)
#8 0x7ff81c3fe222 in VapourSynthPluginInit2+0xcb92 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0xe222) (0x240a4e222)
#9 0x7ff81c3ffea2 in VapourSynthPluginInit2+0xe812 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0xfea2) (0x240a4fea2)
#10 0x7ff81c40a7a1 in pl_render_image+0xc1 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x1a7a1) (0x240a5a7a1)
#11 0x7ff81c3f2937 in VapourSynthPluginInit2+0x12a7 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x2937) (0x240a42937)
#12 0x7ff81c3f2c8f in VapourSynthPluginInit2+0x15ff (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x2c8f) (0x240a42c8f)
#13 0x7ff81c3f3980 in VapourSynthPluginInit2+0x22f0 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x3980) (0x240a43980)
#14 0x7ff8743c796c in getVapourSynthAPI+0xdf0c (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x10796c) (0x18010796c)
#15 0x7ff8743daa22 in getVapourSynthAPI+0x20fc2 (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x11aa22) (0x18011aa22)
#16 0x7ff8743dc2d5 in getVapourSynthAPI+0x22875 (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x11c2d5) (0x18011c2d5)
#17 0x7ff91dd537af in wcsrchr+0x14f (C:\WINDOWS\System32\ucrtbase.dll+0x37af) (0x1800037af)
#18 0x7ff92051e8d6 in BaseThreadInitThunk+0x16 (C:\WINDOWS\System32\KERNEL32.DLL+0x2e8d6) (0x18002e8d6)
#19 0x7ff920c8c53b in RtlUserThreadStart+0x2b (C:\WINDOWS\SYSTEM32\ntdll.dll+0x8c53b) (0x18008c53b)
for malloc: ../subprojects/libplacebo/src/gpu/utils.c:1175
No slab to serve request for 96 bytes (with alignment 0xc00) in pool 2!
Failed allocating vertex buffer!
Memory pool 0:
Optimal flags: 0x1
Slab 1: fffe x 16K: 16K used 16K res 256K alloc from heap 0, efficiency 100.00% [subprojects/libplacebo/src/shaders/sampling.c:1032]
Pool summary: 24M used 47M res 64M alloc, efficiency 51.00%, utilization 74.73%
Memory pool 1:
Optimal flags: 0x3
Buffer flags: 0x3
Memory pool 2:
Required flags: 0x1
Optimal flags: 0x2
Buffer flags: 0xc3
Memory summary: 47M used 93M res 124M alloc, efficiency 50.51%, utilization 74.86%, max page: 1520M
Backtrace:
#4 0x7ff81c457588 in pl_timer_query+0x2468 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x67588) (0x240aa7588)
#5 0x7ff81c46d8ea in pl_vulkan_sem_create+0x3cea (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x7d8ea) (0x240abd8ea)
#6 0x7ff81c452b4c in pl_tex_upload+0x7c (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x62b4c) (0x240aa2b4c)
#7 0x7ff81c46ee30 in pl_vulkan_wrap+0x1350 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x7ee30) (0x240abee30)
#8 0x7ff81c42a6eb in pl_lut_parse_cube+0x247b (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x3a6eb) (0x240a7a6eb)
#9 0x7ff81c42f87d in pl_shader_sample_ortho2+0x32d (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x3f87d) (0x240a7f87d)
#10 0x7ff81c3ff3b1 in VapourSynthPluginInit2+0xdd21 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0xf3b1) (0x240a4f3b1)
#11 0x7ff81c400adb in VapourSynthPluginInit2+0xf44b (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x10adb) (0x240a50adb)
#12 0x7ff81c40a7a1 in pl_render_image+0xc1 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x1a7a1) (0x240a5a7a1)
#13 0x7ff81c3f2937 in VapourSynthPluginInit2+0x12a7 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x2937) (0x240a42937)
#14 0x7ff81c3f2c8f in VapourSynthPluginInit2+0x15ff (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x2c8f) (0x240a42c8f)
#15 0x7ff81c3f3980 in VapourSynthPluginInit2+0x22f0 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x3980) (0x240a43980)
#16 0x7ff8743c796c in getVapourSynthAPI+0xdf0c (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x10796c) (0x18010796c)
#17 0x7ff8743daa22 in getVapourSynthAPI+0x20fc2 (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x11aa22) (0x18011aa22)
#18 0x7ff8743dc2d5 in getVapourSynthAPI+0x22875 (C:\Users\Jalen\Documents\StaxRip\Apps\FrameServer\VapourSynth\Lib\site-packages\VapourSynth.dll+0x11c2d5) (0x18011c2d5)
#19 0x7ff91dd537af in wcsrchr+0x14f (C:\WINDOWS\System32\ucrtbase.dll+0x37af) (0x1800037af)
#20 0x7ff92051e8d6 in BaseThreadInitThunk+0x16 (C:\WINDOWS\System32\KERNEL32.DLL+0x2e8d6) (0x18002e8d6)
#21 0x7ff920c8c53b in RtlUserThreadStart+0x2b (C:\WINDOWS\SYSTEM32\ntdll.dll+0x8c53b) (0x18008c53b)
for malloc: ../subprojects/libplacebo/src/gpu/utils.c:576
No slab to serve request for 8192 bytes (with alignment 0xc00) in pool 1!
Failed creating LUT texture!
Failed initializing separated LUT!
Failed dispatching scaler.. disabling
Memory pool 0:
Optimal flags: 0x1
Slab 1: fffe x 16K: 8192 used 16K res 256K alloc from heap 0, efficiency 50.00% [subprojects/libplacebo/src/shaders/colorspace.c:1857]
Pool summary: 24M used 47M res 64M alloc, efficiency 50.98%, utilization 74.73%
Memory pool 1:
Optimal flags: 0x3
Buffer flags: 0x3
Memory pool 2:
Required flags: 0x1
Optimal flags: 0x2
Buffer flags: 0xc3
Memory summary: 47M used 93M res 124M alloc, efficiency 50.50%, utilization 74.86%, max page: 1520M
Backtrace:
#7 0x7ff81c429817 in pl_lut_parse_cube+0x15a7 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x39817) (0x240a79817)
#8 0x7ff81c4169e3 in pl_shader_color_map_ex+0x2013 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x269e3) (0x240a669e3)
#9 0x7ff81c4033b0 in VapourSynthPluginInit2+0x11d20 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x133b0) (0x240a533b0)
#10 0x7ff81c40a813 in pl_render_image+0x133 (C:\Users\Jalen\Documents\StaxRip\Apps\Plugins\VS\libvs_placebo\libvs_placebo.dll+0x1a813) (0x240a5a813)
No slab to serve request for 1024 bytes (with alignment 0xc00) in pool 1!
Failed generating tone-mapping LUT!
Attempting to modify a failed shader!
Trying to dispatch a failed shader.
Failed rendering image!
vpy [WARN]: Failed processing planes!
vpy [INFO]: 3840x2076 fps 24000/1001 i444p16 frames 0 - 76 of 77
vpy [INFO]: using 12 parallel requests
raw [INFO]: output file: C:\Users\Jalen\Desktop\New folder (2)\The SpongeBob SquarePants Movie (2004) (2160p BluRay x265 HEVC 10bit HDR DV EAC3 5.1 KLRK)-00.31.57.19-00.32.01.16.mkv_temp\The SpongeBob SquarePants Movie (2004) (2160p BluRay x265 HEVC 10bit HDR DV EAC3 5.1 KLRK)-00.31.57.19-00.32.01.16_new_out.hevc
x265 [INFO]: HEVC encoder version 4.1+212+35-87f5a69a8 [Mod by Patman]
x265 [INFO]: build info [Windows][Clang 21.1.7][64 bit] 10bit
x265 [INFO]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [FLAW]: Dolby Vision profile - 5, profile - 8.1, profile - 8.2 and profile - 8.4 requires YCbCr 4:2:0 color space
x265 [FLAW]: x265_encoder_open() failed for Enc,
#15 | Link |
Donor
Could be a driver issue. On my Arc B580, libplacebo does not work through VapourSynth. If I remember correctly, you've got an Nvidia card. I would consider using FFmpeg, which is simpler.
#16 | Link |
On the 444 regard, vsplacebo tonemap ONLY outputs RGB48 or YUV444P16, depending on input color family.
(The reason I said "upscaled chroma") Pixel format conversion is covered by core.resize plug it in after vsplacebo |
#19 | Link |
YCbCr420 and YUV420 are virtually the same. The former is a "digital" format, the latter comes from the analog era. Something is outputting a different format in your chain. As others noted, add a converting filter at the end of the filter chain.
#20 | Link |
Where in any of these codes are outputting YUV444?
ConvertBits(16) libplacebo_Tonemap(src_csp=3, dst_csp=0, dynamic_peak_detection=True, tone_mapping_function="bt2390", contrast_recovery=0.3, contrast_smoothness=3.5) # ConvertBits(10) # ConvertToYUV420() Code:
--crf 10 --dolby-vision-profile 8.1 --dolby-vision-rpu "C:\Users\User\Desktop\New folder (2)\4K HDR.mkv_temp\HDRDVmetadata.rpu" --output-depth 10 --vbv-bufsize 160000 --vbv-maxrate 160000 --range limited --colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --chromaloc 2 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --max-cll "1000,257" --hdr10 --repeat-headers --hrd --aud |
| Tags |
| colorspace, dolby vision, hdr to sdr, staxrip, ycbcr |
| Display Modes | |
