Old 9th December 2025, 13:13   #21  |  Link
GeoffreyA
Donor
Originally Posted by tormento View Post
Please, post your script with libplacebo.
ffmpeg -init_hw_device vulkan -i "%src%" -map 0:v:0 -map_metadata -1 -vf libplacebo=w=-1:h=1080:upscaler=spline36:downscaler=spline36:peak_detect=true:tonemapping=spline:gamut_mode=perceptual:colorspace=bt709:color_trc=bt709:color_primaries=bt709:range=limited:dithering=blue:format=yuv420p,crop=%crop%:exact=true,sidedata=delete -c:v libx264 [...] "%dst%"
You can actually shorten it because a lot of those settings are the defaults:
ffmpeg -init_hw_device vulkan -i "%src%" -map 0:v:0 -map_metadata -1 -vf libplacebo=w=-1:h=1080:upscaler=spline36:downscaler=spline36:colorspace=bt709:color_trc=bt709:color_primaries=bt709:range=limited:format=yuv420p,crop=%crop%:exact=true,sidedata=delete -c:v libx264 [...] "%dst%"
And if you want to output to 10 bit, just change the format to yuv420p10le.
From November, the sidedata wasn't getting deleted. I submitted the issue, and it has been fixed.
GeoffreyA is offline   Reply With Quote
Old 9th December 2025, 13:47   #22  |  Link
tormento
Acid fr0g
tormento's Avatar
I see. I thought you did with an AVS+ script.
@turment on Telegram
Old 30th December 2025, 09:14   #23  |  Link
RocketJet
RocketJet's Avatar
Consider Dolby Vision Converter app
You may like to try the app "Dolby Vision Converter".
It requires no technical knowledge of DV.
https://sourceforge.net/projects/dol...ion-converter/
It is easy enough to give it a try.
No promises though.
RocketJet is offline   Reply With Quote
Old 30th December 2025, 14:55   #24  |  Link
GeoffreyA
Donor
I think libplacebo works with AVS too.
dolby vision, dovi, dovi_scripts, hdr10
