Old 2nd November 2025, 03:21   #1  |  Link
filler56789
SuperVirus
filler56789's Avatar
MPC-VR does not work as expected in GraphStudio
Hello MPC-BE devs,
actually this question was asked by someone else at Videohelp dot com.
Since nobody has posted an answer yet, I though it would be interesting to reproduce it here.
I've installed the 64-bit version of the DirectShow filter "MPC video renderer".
I'm also using the 64-bit versions of GraphEdit and GraphStudioNext.
But with either of them, I can't play an MP4 file with this renderer.
When I press Play, GraphEdit doesn't open a video rendering window.
Yet the cursor moves as if it's playing the file.
If I use the EVR or MADvr renderer, or even VMR9, everything works.
The application I'm developing uses the IVideoWindow interface to display the video.
But it doesn't work any better. The screen remains black. I use the same code when using the MADvr Renderer,
and it works perfectly.
Perhaps the approach needs to be different with the MPC Renderer.
Thanks in advance for your help.
Windows 10
RTX 4060
Visual Studio 2022
source: https://forum.videohelp.com/threads/...with-GraphEdit
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 2nd November 2025, 06:10   #2  |  Link
Aleksoid1978
Aleksoid1978's Avatar
https://github.com/cplussharp/graph-...ext/issues/332
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Denon AVR-X2800H+NS-555+NS-C444+NS-333+YST-SW215+Klipsch R-40SA
Aleksoid1978 is offline   Reply With Quote
