#1 | Link |
VLC Player 3.0.22 RC1 available
https://code.videolan.org/videolan/v...ags/3.0.22-rc1
v3.0.22 rc1 is out albeit not compiled. changelog: Code:
VLC media player 3.0.22-rc1 'Vetinari' This is the twenty-third release of VLC 3.0 branch, named "Vetinari", in reference to the Lord Patrician from Discworld. This update contains a few improvements and some fixes: - Add option to use dark palette (Qt) - Add compilation support for Qt6 and newer versions of Qt5 - Add Windows ARM64 builds - Fix support for Windows XP SP3 - Allow renaming/moving/deleting of playing file on Windows - Restrict SystemParametersInfo calls to Windows XP - Fix Opus channel mapping - Fix hardware decoding with VideoToolbox of XVID MPEG-4 video - Add dav1d-all-layers option - Fix DVD CEA-608 captions parsing - Fix ProRes 4:4:4:4 - Disable decoding using libdca, libmpeg2 and liba52 by default in favor of libavcodec - Handle mkv-use-chapter-codec option - Add A_ATRAC/AT1 support in matroska - Prevent FLAC seeking logic get stuck - Handle pictures in FLAC - Fix VOB/AOB LPCM/MLP detection failing occasionally - Cut QNap title on first invalid character - Fix display of certain JPEG files - Fix playback of very short ASF files (duration less than 1s) - Fix crashes in multiple demuxers (reported by rub.de, oss-fuzz and others) - Fix SFTP seeking for large files on 32-bit OS - UPnP: remove SAT>IP channel list fallback - Use a better stretch mode in wingdi - Fetch missing device information when running in UWP - Add AMD GPU Frame Rate Doubler (Direct3D11) Many thanks to the Sovereign Tech Agency (https://www.sovereign.tech/), and especially their Sovereign Tech Fund program, for helping VLC sustainability and safety. Thanks to oss-fuzz as well for their help and resources to find issues. Thanks to their support, 3.0.22 becomes the VLC release with the most security fixes ever! |
#2 | Link |
Installer now available: https://artifacts.videolan.org/vlc/r...-rc1-win64.exe
#4 | Link |
VLC 3.0.22 is now out! 18 months since the last version.
installer: http://ftp.videolan.org/pub/videolan...0.22-win64.exe changelog: https://code.videolan.org/videolan/vlc/-/tags/3.0.22 |
#5 | Link |
and 32 bit here [vlc-3.0.22-win32.exe]:- http://ftp.videolan.org/pub/videolan/vlc/3.0.22/win32/
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 3rd December 2025 at 02:51. |
#6 | Link |
They broke Windows 7 Hardware acceleration
Automatic displays now a black window Direct3D9 Manual = Black Direct3d 11 = Works no Hardware acceleration congratulations finally you did it you have to set it manually now Output = Automatic Hardware Acceleration = Direct3D 11 Output = Direct3D9 Hardware Acceleration = Direct3D 11 both on Automatic will fail = Black Window Hardware Decoding works again But not entirely correct for everything it seems to fall back sometimes looks like stream specific fallbacks maybe for no real reason filter= noscale what are you doing you like barbecues ? same stream FPS difference ahhhaaa the 60 FPS int streams fallback to noscale the 59.940 work with direct3d11_filters "Charlie throw it on the CPU is hot enough" ![]() "Charlie you have to get direct3d down or the barbecue freezes"
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th December 2025 at 02:45. |
#8 | Link |
"Charlie what are you doing we said barbecue"
Charlie: "I prefer sushi here" (hot and spicy enough )![]()
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 6th December 2025 at 14:50. |
| Display Modes | |
