#1 | Link |
PGS Subtitles Overlapping
How do I make two lines from PGS subtitles overlap with one another? For example, I want this subtitle line to be on top of this one.
#2 | Link | |
If you want epochs (1, then 1+2, then 2), you have to create 3 epochs. Epochs 1, 1+2, and 2. Then adjust the start and end times to display in the correct order. The epochs never really overlap. It just looks that way. |
#3 | Link | |
#4 | Link |
First you are double posting things all over the place. Second you asked in this thread how to "overlap" the epochs. In another thread you asked how to "replace".
https://forum.doom9.org/showthread.p...11#post2019511 We really can't help if you can't tell us exactly what you are trying to do. I gave you the instructions on how to "overlap" epochs. If you want to "replace" one with another that's totally different. When I replace, I use BDSup2Sub. I export the PGS to BDN/XML. This gives me an XML file with all the timings and the associated PNG's. I then simply replace any PNG I want to change. Then I export it back to PGS. Using just BDSup2Sub by itself is a more manual way of doing it and that's why I wrote a subtitle interface into my Blu-Ray Ripper. |
| Tags |
| pgs, pgs subtitle |
| Display Modes | |
