Old 8th June 2025, 19:23   #1  |  Link
jay123210599
Subtitle Edit: Incorrect Export
I have exporting .ass subtitles to PNG. These were my settings, But afterwards, I got this for the line I wanted to export (you may to download it you can't see it). How do I fix it?
jay123210599 is offline   Reply With Quote
Old 8th June 2025, 20:56   #2  |  Link
Music Fan
I don't know for PGS but for Sup files, before the export window, there is an import window (which allows OCR, among others) ; there you can right-click on a line, save subtitle image as, png.
Music Fan is offline   Reply With Quote
Old 8th June 2025, 22:36   #3  |  Link
jay123210599
Originally Posted by Music Fan View Post
Sorry, I meant .ass subtitles.
Old 9th June 2025, 10:07   #4  |  Link
Music Fan
Ok, but you can try to go in the import window : open SE, go in file, import, Subtitle with manually chosen encoding, and select your .ass file. Then try what I suggested above.
But I'm not sure it will open the same import window than when a sup is opened.
Or try to convert to sup (which allows transparency), then open the sup and go in the import window to see what I explained.
pgs subtitle, png, subtitle conversion, subtitleedit, sup subtitle
