Old 22nd April 2025, 15:52   #1  |  Link
Arizoa
making dvd menu with avstodvd
hello,
to make my dvds i use avstodvd since several years and i am very satisfied with it. But i have a small problem when creating the menu. At this moment i am creating dvds with 20 titles-titles labels- on each dvd.
I use the static menu.
If i edit the menu, each title label has a default value of 20 in the height case
i wish to change this 20 value and the basic way is to do the change by editing each of the 20 title label one after the other.
So my question is: in what folder of avstodvd program is the "title label heiht" value? If i could change this default value i will no more have to do the change in the 20 "title label height" one after the other.
I looked in the menu template -labels.ini- but there is no height value.
thank you for your attention
Arizoa is offline   Reply With Quote
[IMG] code is Off
