Old 4th March 2025, 22:07   #1  |  Link
jay123210599
Cut to Black and White
How do I make videos cut to black and white freeze frames like in these ones?
https://www.youtube.com/watch?v=m9mKLph-U4o
https://www.youtube.com/watch?v=nobhFnBAXRY
https://www.youtube.com/watch?v=5WRPJpbbr80
jay123210599 is offline   Reply With Quote
Old 5th March 2025, 07:11   #2  |  Link
GeoffreyA
Donor
An easy way to do it is with Resolve. Simply delimit a part, using a cut for example, position the timeline on the desired frame, and click Clip > Freeze Frame (or Shift + R). That frame will be used for the length of the cut, so you may have to duplicate the clip to get it seamless on either end, though with animation, it might not be an issue. Then, under Fusion, use the Colour Corrector to desaturate that part. Or, use the Colour Compressor filter on the timeline and set Compress Saturation to 1.0.
GeoffreyA is offline   Reply With Quote
video editing
