#1 | Link |
vspreview: Incorrect Frame Rate
No matter which source I use, I always get the wrong frame rate from one of my videos. How do I fix it?
Video Information: Code:
Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 24 min 36 s Bit rate : 4 725 kb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 26.195 FPS Original frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.087 Stream size : 831 MiB (87%) Writing library : x264 core 148 r2638 7599210 Encoding settings : cabac=1 / ref=5 / deblock=1:1:1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=0.70:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No |
#2 | Link |
Big Bit Savings Now !
You may try BestSource()
#4 | Link |
Then it might be borked by the last encoder, or real VFR.
I have no access to your source, but I would inspect all frames, their motion, and maybe the damage can be undone. In the worst case by exporting them all, dropping the repeats, count the uniques and Assumefps them across the new timeline.
#5 | Link | |
https://www.mediafire.com/file/fvx8t...le_vfr.7z/file Last edited by jay123210599; 6th November 2024 at 18:17. |
#6 | Link | |
#7 | Link |
It's 24p and 30p mix
I assume that only the credits part of the video is 30p so maybe you can do some black magic to it but that's complex just extract and mux the timestamps and call it a day if you are doing some VapourSynth but if not just use FFmpeg to handle the VFR with -fps_mode |
#8 | Link | |
#9 | Link | |
http://www.vapoursynth.com/doc/funct...assumefps.html |
| Tags |
| vapoursynth, video comparison, video player |
| Display Modes | |
