Old 21st November 2024, 11:40   #61  |  Link
RBO
GPAC maintainer
set a global title field
Usually people use -tags title="..."
omit tagged date
If you set a tag to null then it is removed, see https://wiki.gpac.io/MP4Box/mp4box-other-opts/.
Does MP4Box (as part of GPAC) depend on ffmpeg?
It does (optionally) since GPAC 1.0 in 2020. We rewrote the core of GPAC to reuse the same framework ("filters") that you see in the new 'gpac' app. Add -graph to your command-line to see the MP4Box processing graph.
Now MP4Box can leverage other libraries. FFmpeg is a kind of last-resort fallback.
To come back to your case, I would expect to see:
dtsc [ODE]:                   DTS Coherent Acoustics and Digital Surround Audio (audio/dts)
dtsh [O]:                     DTS-HD High Resolution Audio and DTS-Master Audio (audio/dts)
dtsl [O]:                     DTS-HD Substream containing only XLLAudio (audio/dts)
dtse [O]:                     DTS Express low bit rate Audio (audio/dts)
dtsx [O]:                     DTS-X UHD Audio Profile 2 (audio/dts)
dtsy [O]:                     DTS-X UHD Audio Profile 3 (audio/dts)
This is on Windows, correct?
RBO is offline   Reply With Quote
Old 21st November 2024, 11:53   #62  |  Link
LigH
LigH's Avatar
Yes, Windows. Building from sources in an MSYS2/MinGW environment with GCC 14.2.
Does it require to configure with a special parameter to include ffmpeg support?
New German Gleitz board
Old 21st November 2024, 13:36   #63  |  Link
RBO
GPAC maintainer
No. It really seems GPAC doesn't see the DTS codec in FFmpeg. I propose to reproduce your media-autobuild_suite build, let me know if you use specific options.
Old 21st November 2024, 13:48   #64  |  Link
LigH
LigH's Avatar
This archive contains a few relevant files, mainly media-autobuild_suite.ini (configured for many codecs with additional separate executables besides ffmpeg which gets built as static EXE with a custom set of libraries) and ffmpeg_options.txt; may be way too much for your needs, you can probably safely disable many codecs to run your test, the dca codec is part of libavcodec (the ffmpeg core) anyway, does not depend on additional libraries.
I would recommend to configure M-AB-S from scratch, select only static build, GPL, minimal set for ffmpeg; disable most codecs except GPAC/MP4Box, and enable building of separate codecs besides ffmpeg.
The resulting binaries are not installed in the Windows\System and not in the MSYS2 base environment but in local directories.
Old 22nd November 2024, 09:10   #65  |  Link
GeoffreyA
Donor
Thanks. It worked.
GeoffreyA is offline   Reply With Quote
Old 22nd November 2024, 14:21   #66  |  Link
RBO
GPAC maintainer
M-AB-S builds GPAC before FFmpeg. So obviously GPAC can't rely on FFmpeg in these builds.
Second remark: M-AB-S seems to rely on libgpac_static only (code). Does this script aims at building static binaries whenever possible?
FYI the build failed for me because ccache said there are too many files in the FFmpeg build. Retrying the build from a root folder. It takes a lot of time because I have continuous network issues and the system continuous updates dozens of git repos when relaunched.
Old 22nd November 2024, 14:29   #67  |  Link
LigH
LigH's Avatar
Good to know, will tell the maintainers about it, so they can possibly rearrange.
Not always. You can try to build ffmpeg with shared DLLs as well. Some other separate tools may prefer static building "always" if there used to be linking issues when trying to run a dynamic-link build in the past. Needs to be answered by the maintainers.
Very useful information. I know there is an issue with a "too long command line" when building ffmpeg with dynamic linking and a lot of enabled optional modules (that was the reason why I recommended to you to configure from scratch with a minimal ffmpeg with GPL license), and knowing that ccache may be the bottleneck here should help greatly solving it.
PS: See M-AB-S issue 2801.
Old 22nd November 2024, 16:27   #68  |  Link
filler56789
SuperVirus
filler56789's Avatar
F.W.I.W., I downloaded the latest GPAC-installer available at videohelp dot com,
and saw that it uses the (lib)av libraries...
BUT it cannot do everything that the (lib)av DLLs are capable of doing...
which raises the question:
¿what is the point, then?
In comparison, the L-Smash muxer.exe rev1477 18a9ed2 filesize is only 569 kB.
And obviously, it does not depend on the FFmpeg stuff.
Bottom line is, something very-wrong cannot be right.
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 22nd November 2024, 18:59   #69  |  Link
RBO
GPAC maintainer
Ah. What can't it do?
MP4Box built with with "--isomedia-only --static-bin --strip" is the closest comparable I think. It weighs around 1MB and handles network, multithreading, configurable cache, etc. Do you need something smaller? What's your need?
