Old 17th November 2024, 08:08   #41  |  Link
GeoffreyA
Donor
I have been using FFmpeg to create MP4s for years and never had much of an issue, except perhaps during 2020, when I found the MP4s temperamentally working, or not, on our Samsung TV. (Though that could have been due to the USB drives. I don't quite know, except that the problem went away; I took it as there being some change in the muxer.) I prefer FFmpeg, being familiar with its syntax and metadata switches; and changing means changing scripts and more headache.
Objectively, how well does MP4Box mux compared to FFmpeg? Or, put differently, is there any tool that is the MKVToolNix of MP4s?
GeoffreyA is offline   Reply With Quote
Old 17th November 2024, 10:17   #42  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by GeoffreyA View Post
... is there any tool that is the MKVToolNix of MP4s?
Read this thread (it is still short) about GUI's for mp4 mux.
Old 17th November 2024, 10:47   #43  |  Link
GeoffreyA
Donor
Thanks, tebasuna. I actually dont want a GUI. I meant, what is the reference-quality muxer? I noticed that, in this thread, many are recommending MP4Box. If it is better than FFmpeg, I'm willing to switch. Having said that, I don't have any issues with FFmpeg's MP4 muxing at present. (In fact, I found issues with its MKV muxer.)
Old 17th November 2024, 15:06   #44  |  Link
LigH
LigH's Avatar
Objectively, the GPAC suite is the de-facto standard of MP4 tools; and MP4Box is part of it (a more user friendly CLI and less generic toolbox than GPAC).
If your hardware has issues, then it might support only a part of the MP4 standard and expect default values or extra flags MP4Box is able to provide but maybe only when you add them to the command line parameters explicitly.
New German Gleitz board
Old 17th November 2024, 16:52   #45  |  Link
GeoffreyA
Donor
Thank you, LigH. Well, I think I'm inclining to give MP4Box a go for the final muxing of permanent encodings.
Old 18th November 2024, 00:36   #46  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
I've been using MP4Box for years and I've never had a problem.
Yes, you can consider MP4Box as the "MKVToolnix" of mp4, a bit like TSMuxer is the "MKVToolnix" of .ts files.
I generally encode the raw_video.h264 with x264, then audio.aac with NeroAAC and lastly mux them both together with mp4box.
The simplest possible syntax would look something like this:
x264.exe "AVS Script.avs" --preset medium --ref 4 --level 4.1 --profile High --crf 22 --vbv-maxrate 25000 --vbv-bufsize 25000 --deblock -1:-1 --overscan show --colormatrix bt709 --range tv --log-level info --thread-input --opencl --transfer bt709 --colorprim bt709 --videoformat component --nal-hrd vbr --output "I:\raw_video.h264"
Bepipe.exe --script "Import(^AVS Script.avs^)" | neroAacEnc.exe -lc -br 320000 -if - -of "I:\audio.aac"
mp4box.exe -add "I:\raw_video.h264" -add "I:\audio.aac" "I:\final_output.mp4"
pause
so... no need to use FFMpeg, not even for audio.
Old 18th November 2024, 15:05   #47  |  Link
GeoffreyA
Donor
Appreciate your help, FranceBB. Generally, what I do is first process the audio with FFmpeg, piping to qaac, and then encode the final video, pulling in the encoded audio by direct-stream copy, and it works well. Using MP4Box will necessitate only a small change in the script at the end. Indeed, I'll still encode with FFmpeg: I consider it a crime not to do so!
This is my audio script:
set out_i=-23
set out_tp=-2
set out_lra=8.5
set in_i=-13.4
set in_tp=8.4
set in_lra=24.1
set in_thresh=-26.4
set tg_offset=1
::ffmpeg -i %1 -map 0:a:0 -af aresample=ochl=stereo,loudnorm=i=%out_i%:tp=%out_tp%:lra=%out_lra%:print_format=summary -f null -
ffmpeg -i %1 -map 0:a:0 -af aresample=ochl=stereo:osr=192000:resampler=soxr:precision=33,
loudnorm=i=%out_i%:tp=%out_tp%:lra=%out_lra%:measured_i=%in_i%:measured_tp=%in_tp%:measured_lra=%in_lra%:measured_thresh=%in_thresh%:offset=%tg_offset%:linear=true:print_format=summary,
aresample=48000:resampler=soxr:precision=33 -c:a pcm_f32le -f wav - | "%qaac%" --tvbr 91 --ignorelength --no-delay --verbose - -o "audio.m4a"
And the final video one (edited for clarity):
set src=FILM_NAME.mkv
set out=FILM_NAME.mp4
set name=FILM_NAME
set crop=1920:816:0:132
set param_colour=-colorspace bt709 -color_primaries bt709 -color_trc bt709 -color_range tv
ffmpeg %param_colour% -i "%src%" -i "audio.m4a" -map 0:0 -map 1:a -map_metadata -1 -map_chapters -1 -metadata title="%name%"
-metadata:s:v language=und -disposition:v:0 default -metadata:s:a:0 language=eng -disposition:a:0 default
-vf crop=%crop% -c:v libx264 -profile:v high -level 4.1 -preset veryslow -tune film -aq-mode 3 -crf 23 -c:a copy "%out%"
Old 19th November 2024, 15:59   #48  |  Link
filler56789
SuperVirus
filler56789's Avatar
Originally Posted by filler56789 View Post
for the fresh binaries.
Within some days, I will check whether the newest MP4Box finally started supporting VC-1 video and DTS audio
Very-unlikely, I know, but anyway, it's always good to bash the GPAC devilopers
Well, "some days" became "some months" :-/ ,
but anyway:
Just confirming, after all these years, MP4Box still does not want to support VC-1 video nor DTS audio.
There is no "lack of time", there is just lack of interest.
https://sourceforge.net/p/gpac/discu...read/43881fa9/
As one of the GPAC devilopers told me in their GitHub page,
he already had all the code written. But what he didn't dare to say is this, they (GPAC) will not implement the improvements, unless they receive some big fat money in return. *THUMBS DOWN*
https://github.com/gpac/gpac/issues/536
«Your software patents have expired.»
filler56789 is offline   Reply With Quote
Old 20th November 2024, 05:56   #49  |  Link
Kurt.noise
muxing dts streams within mp4box works in fact...
General
Complete name : E:\Backup\Input.av1-muxed.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom)
File size : 107 MiB
Duration : 2 min 15 s
Overall bit rate mode : Variable
Overall bit rate : 6 592 kb/s
Frame rate : 24.000 FPS
Encoded date : 2024-11-20 04:50:36 UTC
Tagged date : 2024-11-20 04:50:36 UTC
Writing application : GPAC-2.5-DEV-rev707-g9c261926-master
Video
Format : AV1
Format/Info : AOMedia Video 1
Format profile : Main@L4.0
Codec ID : av01
Bit rate : 305 kb/s
Maximum bit rate : 987 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.006
Stream size : 4.95 MiB (5%)
Encoded date : 2024-10-26 16:39:29 UTC
Tagged date : 2024-11-20 04:50:37 UTC
Color range : Limited
Codec configuration box : av1C
Audio
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : dtsc
Bit rate mode : Variable
Bit rate : 6 283 kb/s
Maximum bit rate : 9 423 kb/s
Sampling rate : 48.0 kHz
Stream size : 102 MiB (95%)
Language : English
Default : Yes
Alternate group : 1
Kurt.noise is offline   Reply With Quote
Old 20th November 2024, 12:04   #50  |  Link
tebasuna51
tebasuna51's Avatar
How do you make that mux?
With mp4box from GPAC-2.5-DEV-rev707-g9c261926-master (like your MediaInfo) and with the last (2024-11-07) mp4box from GPAC-2.5-DEV-rev816-g1bc97198-ab-suite I always get a error:
[Importer] Error probing TestMA.dts
Failure while importing import: Filter not found for the desired type
Tested for dtsMA and dts standard (core)
BTW I can understand the lack of interest for this old, obsolete and not-free codec when can use AAC for lossy compression or ALAC and FLAC for lossless audio with better compression ratio and free use.
Old 20th November 2024, 13:45   #51  |  Link
Kurt.noise
1/ I took a win64 installer from there : https://gpac.io/downloads/gpac-nightly-builds/ & extract it into a folder.
2/ Then, apply this command :
mp4box.exe -add input.mkv#trackID=1:fps=24000/1001 -add audio.dts#trackID=1:lang=eng -new output.mp4
Info from audio.dts :
General
Complete name                  : audio.dts
Format                         : DTS XLL
Commercial name                : DTS-HD Master Audio
File size                      : 51.4 MiB
Audio
Format                         : DTS XLL
Channel(s)                     : 6 channels
Channel layout                 : C L R Ls Rs LFE
Frame rate                     : 93.750 FPS (512 SPF)
Bit depth                      : 24 bits
Compression mode               : Lossless
Info from output.mp4 :
General
Complete name                  : output.mp4
Format                         : MPEG-4
Codec ID                       : isom (isom/avc1)
File size                      : 170 MiB
Duration                       : 3 min 25 s
Overall bit rate               : 6 935 kb/s
Frame rate                     : 23.976 FPS
Encoded date                   : 2024-11-20 12:35:15 UTC
Tagged date                    : 2024-11-20 12:35:15 UTC
Video
Format                         : AVC
Format/Info                    : Advanced Video Codec
Format profile                 : High@L4.1
Format settings                : CABAC / 4 Ref Frames
Format settings, CABAC         : Yes
Format settings, Reference fra : 4 frames
Codec ID                       : avc1
Codec ID/Info                  : Advanced Video Coding
Bit rate                       : 4 829 kb/s
Maximum bit rate               : 19.2 Mb/s
Frame rate mode                : Variable
Frame rate                     : 23.976 (24000/1001) FPS
Minimum frame rate             : 23.810 FPS
Maximum frame rate             : 24.390 FPS
Color space                    : RGB
Bit depth                      : 8 bits
Scan type                      : Progressive
Bits/(Pixel*Frame)             : 0.097
Stream size                    : 118 MiB (70%)
Title                          : Piste Vidéo
Writing library                : x264 core 146 r2538 121396c
Encoding settings              : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=15.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=20000 / vbv_bufsize=30000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Language                       : English
Tagged date                    : 2024-11-20 12:35:16 UTC
Matrix coefficients            : Identity
mdhd_Duration                  : 205202
ColorSpace_Original            : YUV
Codec configuration box        : avcC
Audio
Format                         : DTS
Codec ID                       : dtsc
Bit rate                       : 2 100 kb/s
Maximum bit rate               : 2 746 kb/s
Stream size                    : 51.4 MiB (30%)
Title                          : Piste Audio
Language                       : English
Default                        : Yes
Alternate group                : 1
Info from input.mkv :
General
Unique ID                      : 194964996866116433750323166388027802333 (0x92ACE47EA0A15008964FF4FED95642DD)
Complete name                  : input.mkv
Format                         : Matroska
Format version                 : Version 4
File size                      : 170 MiB
Overall bit rate               : 6 931 kb/s
Encoded date                   : 2015-04-06 09:49:53 UTC
Writing application            : mkvmerge v6.9.1 ('Blue Panther') 64bit built on Apr 18 2014 18:23:38
Writing library                : libebml v1.3.0 + libmatroska v1.4.1
Video
Format                         : AVC
Codec ID                       : V_MPEG4/ISO/AVC
Color space                    : YUV
Bit depth                      : 8 bits
Language                       : English
Default                        : Yes
Forced                         : No
Audio
Format                         : DTS XLL
Codec ID                       : A_DTS
Bit depth                      : 24 bits
Language                       : English
Default                        : Yes
Forced                         : No
All ffmpeg libraries from the installer are required in this case.
Old 20th November 2024, 14:17   #52  |  Link
tebasuna51
tebasuna51's Avatar
Maybe we need the full gpac package instead the standalone MP4Box.exe
EDIT: like you say in the edited post
Old 20th November 2024, 17:12   #53  |  Link
LigH
LigH's Avatar
If MP4Box built by M-AB-S is unable to multiplex dts, I wonder if that requires a specific configuration parameter or an additional patch to enable it.
In my MP4Box.exe I can find "DTS", "DTS-HD", "Coherent Acoustics" etc. being mentioned.
PS: It seems that MP4Box.exe is not able to print out a list of supported codecs; instead, gpac.exe from the same build does report some list. In my case:
dstc [O]:                     DTS Coherent Acoustics and Digital Surround Audio (audio/dts)
dtsh [O]:                     DTS-HD High Resolution Audio and DTS-Master Audio (audio/dts)
dstl [O]:                     DTS-HD Substream containing only XLLAudio (audio/dts)
dtse [O]:                     DTS Express low bit rate Audio (audio/dts)
dtsx [O]:                     DTS-X UHD Audio Profile 2 (audio/dts)
dtsy [O]:                     DTS-X UHD Audio Profile 3 (audio/dts)
Apparently, all the DTS formats are only supported for output, means demultiplexing, but not multiplexing...
PPS: Did you notice the typos in the FourCC's? gpac issue 3044 reported
And ... it's gone. At least the typos. Quick response.
Old 20th November 2024, 20:04   #54  |  Link
RBO
GPAC maintainer
Discovering this discussion thanks to @LigH bug report
I think VC-1 is supported now. Let us know politely if you see any issue.
By the way we've also been working on a GUI to help people visualize the processing pipeline. It includes the capability to add "templates". I had planned to post about it specifically, but let me know about your needs (in a specific topic if it makes more sense).
RBO is offline   Reply With Quote
Old 20th November 2024, 20:10   #55  |  Link
LigH
LigH's Avatar
Hello there
The typos got fixed quickly. Still open: The question why DTS is only supported as output in a self-compiled MP4Box, while it works in your distributed version as input too.
Old 20th November 2024, 20:34   #56  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Oh wow... That should help people like me
Old 20th November 2024, 21:05   #57  |  Link
filler56789
SuperVirus
DTS's D.C.A. is not more obsolete or less useful than the ultra-low-bitrate audio codecs from the 3GP era. GPAC's lack of interest is purely a matter of (bad) taste, there is no "technicality" involved.
Well, do not expect any "politeness" from me while you all don't buy and swallow some deciliters of HONESTY.
It's fine to say you will not do this or that because you don't want to do this or that.
But it's very bad to pretend that your non-activity is caused by "lack of time" or because "oh the real world issues (*) keep me busy 24x7"
(*) Hello Archie
Old 21st November 2024, 00:17   #58  |  Link
RBO
GPAC maintainer
Maybe a difference in FFmpeg support? What does "ffmpeg -codecs | grep -i dts" (or equivalent) give?
Old 21st November 2024, 06:32   #59  |  Link
GeoffreyA
Donor
New to MP4Box but noticed that there is no way to set a global title field or omit tagged date. Is that correct?
Old 21st November 2024, 10:52   #60  |  Link
LigH
LigH's Avatar
Does MP4Box (as part of GPAC) depend on ffmpeg? That would surprise me. Anyway:
ffmpeg -codecs
 DEAILS dts                  DCA (DTS Coherent Acoustics) (decoders: dca) (encoders: dca)
ffmpeg -formats
 DE  dts             raw DTS
 D   dtshd           raw DTS-HD
ffmpeg -muxers
  E  dts             raw DTS
ffmpeg -demuxers
 D   dts             raw DTS
 D   dtshd           raw DTS-HD
