Old 10th January 2026, 19:20   #1641  |  Link
Rootdown4594
Originally Posted by Kuler087 View Post
Yes, don’t do that.
dovi_script does not support AV1 (I could add support eventually), but you can still use it to generate the FEL Baker AviSynth script and then encode to AV1 using a GUI like StaxRip.
1- Run 8-2-1 and cancel the process as soon as the encode starts.
2- Go to the dovi_script TEMP folder and import ''script.avs'' into StaxRip. From there, you can bake the FEL and encode directly to AV1.
*It’s also possible that StaxRip now supports FEL directly, but I haven’t followed its development recently.
I get this error when I drag and dop the scipt.avs file into Straxrip and select automatic:
Script Error
Python exception: name 'core' is not defined
Traceback (most recent call last):
File "src/cython/vapoursynth.pyx", line 3393, in vapoursynth._vpy_evaluate
File "src/cython/vapoursynth.pyx", line 3394, in vapoursynth._vpy_evaluate
File "D:\DoVi\DoVi.Scripts\temp.folder31\script.avs_temp\script_source.vpy", line 1, in <module>
clip = core.avisource.AVISource(r"D:\DoVi\DoVi.Scripts\temp.folder31\script.avs")
NameError: name 'core' is not defined
Rootdown4594 is offline   Reply With Quote
Old 10th January 2026, 19:30   #1642  |  Link
Kuler087
Kuler087's Avatar
You have to change your staxrip project to avisynth.
DoVi_Scripts //// Dolby Vision Stuff (more tabs below)
LG OLED G5 77'' + 7.2.4 Denon AVR + Ugoos AM6Bplus + Kaleidescape Strato E
Sorry for my English
Kuler087 is offline   Reply With Quote
Old 10th January 2026, 19:52   #1643  |  Link
Rootdown4594
Thank you
Old 13th January 2026, 20:30   #1644  |  Link
dkangel
hello
i'm trying to inject your L5 offsets data in the rpu of interstellar.
copy the text into a samename.json file
everything good except at the end, i've this message
01/13/2026/20:29:54.198000000 metafier: ERROR Illegal Per-frame Level Data: 5
Parsing RPU file...
Summary:
Frames: 243218
Profile: 8
DM version: 1 (CM v2.9)
Scene/shot count: 2358
RPU mastering display: 0.0050/4000 nits
RPU content light level (L1): MaxCLL: 3056.40 nits, MaxFALL: 588.84 nits
L6 metadata: Mastering display: 0.0050/4000 nits. MaxCLL: 0 nits, MaxFALL: 0 nits
L5 offsets: top=0..280, bottom=0..280, left=0, right=0
L2 trims: 100 nits
do you know what it is ? ERROR illegal per frame
thank you
dkangel is offline   Reply With Quote
Old 13th January 2026, 21:03   #1645  |  Link
Kuler087
Kuler087's Avatar
It means that some L5 change happens on a frame that is not a scene cut.
Is this the json edit you've used? I just checked my RPU, and everything is fine.
    "mode": 0,
    "active_area": {
        "presets": [
                "id": 0,
                "left": 0,
                "right": 0,
                "top": 280,
                "bottom": 281
                "id": 1,
                "left": 0,
                "right": 0,
                "top": 0,
                "bottom": 0
        "edits": {
            "0-2117": 0,
            "2118-2589": 1,
            "2590-4429": 0,
            "4430-4588": 1,
            "4589-4657": 0,
            "4658-4736": 1,
            "4737-9349": 0,
            "9350-12547": 1,
            "12548-20071": 0,
            "20072-20228": 1,
            "20229-26005": 0,
            "26006-27624": 1,
            "27625-29207": 0,
            "29208-29379": 1,
            "29380-32410": 0,
            "32411-33439": 1,
            "33440-52177": 0,
            "52178-52270": 1,
            "52271-59929": 0,
            "59930-61037": 1,
            "61038-61098": 0,
            "61099-61199": 1,
            "61200-61306": 0,
            "61307-61411": 1,
            "61412-62296": 0,
            "62297-62454": 1,
            "62455-62779": 0,
            "62780-62895": 1,
            "62896-62984": 0,
            "62985-63072": 1,
            "63073-63310": 0,
            "63311-63407": 1,
            "63408-65118": 0,
            "65119-65269": 1,
            "65270-65475": 0,
            "65476-65745": 1,
            "65746-65790": 0,
            "65791-65886": 1,
            "65887-65951": 0,
            "65952-66059": 1,
            "66060-66179": 0,
            "66180-66318": 1,
            "66319-66770": 0,
            "66771-66917": 1,
            "66918-67974": 0,
            "67975-68163": 1,
            "68164-69114": 0,
            "69115-69530": 1,
            "69531-69652": 0,
            "69653-69843": 1,
            "69844-70575": 0,
            "70576-70774": 1,
            "70775-71548": 0,
            "71549-71652": 1,
            "71653-71835": 0,
            "71836-71865": 1,
            "71866-71945": 0,
            "71946-72079": 1,
            "72080-72124": 0,
            "72125-72403": 1,
            "72404-76948": 0,
            "76949-77258": 1,
            "77259-78833": 0,
            "78834-79911": 1,
            "79912-82014": 0,
            "82015-82265": 1,
            "82266-82856": 0,
            "82857-82985": 1,
            "82986-83345": 0,
            "83346-83474": 1,
            "83475-84866": 0,
            "84867-84986": 1,
            "84987-85142": 0,
            "85143-85255": 1,
            "85256-85479": 0,
            "85480-85719": 1,
            "85720-85877": 0,
            "85878-86018": 1,
            "86019-86094": 0,
            "86095-86191": 1,
            "86192-86423": 0,
            "86424-86551": 1,
            "86552-86615": 0,
            "86616-86700": 1,
            "86701-86840": 0,
            "86841-86893": 1,
            "86894-87014": 0,
            "87015-87113": 1,
            "87114-87457": 0,
            "87458-87556": 1,
            "87557-88210": 0,
            "88211-88456": 1,
            "88457-88841": 0,
            "88842-89377": 1,
            "89378-94039": 0,
            "94040-94168": 1,
            "94169-94328": 0,
            "94329-94490": 1,
            "94491-94574": 0,
            "94575-94638": 1,
            "94639-95152": 0,
            "95153-95210": 1,
            "95211-95399": 0,
            "95400-95516": 1,
            "95517-96608": 0,
            "96609-96705": 1,
            "96706-96820": 0,
            "96821-96911": 1,
            "96912-96953": 0,
            "96954-97019": 1,
            "97020-97372": 0,
            "97373-97397": 1,
            "97398-97441": 0,
            "97442-97491": 1,
            "97492-97540": 0,
            "97541-97620": 1,
            "97621-97663": 0,
            "97664-97727": 1,
            "97728-97770": 0,
            "97771-97869": 1,
            "97870-97918": 0,
            "97919-98070": 1,
            "98071-98112": 0,
            "98113-98203": 1,
            "98204-98607": 0,
            "98608-105200": 1,
            "105201-110488": 0,
            "110489-110578": 1,
            "110579-110783": 0,
            "110784-110833": 1,
            "110834-110870": 0,
            "110871-110910": 1,
            "110911-110956": 0,
            "110957-111007": 1,
            "111008-111039": 0,
            "111040-111106": 1,
            "111107-111135": 0,
            "111136-111158": 1,
            "111159-111181": 0,
            "111182-111443": 1,
            "111444-128219": 0,
            "128220-129099": 1,
            "129100-130228": 0,
            "130229-130512": 1,
            "130513-135990": 0,
            "135991-137775": 1,
            "137776-142345": 0,
            "142346-142941": 1,
            "142942-150171": 0,
            "150172-151096": 1,
            "151097-154631": 0,
            "154632-156627": 1,
            "156628-156817": 0,
            "156818-157207": 1,
            "157208-157847": 0,
            "157848-159661": 1,
            "159662-159951": 0,
            "159952-161259": 1,
            "161260-161479": 0,
            "161480-162074": 1,
            "162075-162476": 0,
            "162477-163947": 1,
            "163948-165059": 0,
            "165060-170806": 1,
            "170807-170925": 0,
            "170926-175489": 1,
            "175490-175689": 0,
            "175690-176841": 1,
            "176842-177228": 0,
            "177229-200823": 1,
            "200824-201104": 0,
            "201105-204170": 1,
            "204171-204414": 0,
            "204415-204477": 1,
            "204478-204553": 0,
            "204554-204700": 1,
            "204701-204873": 0,
            "204874-205839": 1,
            "205840-206259": 0,
            "206260-206443": 1,
            "206444-206504": 0,
            "206505-206829": 1,
            "206830-206849": 0,
            "206850-206892": 1,
            "206893-207033": 0,
            "207034-207082": 1,
            "207083-207172": 0,
            "207173-207243": 1,
            "207244-207302": 0,
            "207303-207343": 1,
            "207344-207380": 0,
            "207381-207621": 1,
            "207622-207637": 0,
            "207638-207790": 1,
            "207791-207882": 0,
            "207883-208172": 1,
            "208173-208290": 0,
            "208291-208976": 1,
            "208977-209112": 0,
            "209113-209376": 1,
            "209377-209558": 0,
            "209559-210406": 1,
            "210407-210990": 0,
            "210991-212925": 1,
            "212926-213076": 0,
            "213077-214127": 1,
            "214128-214235": 0,
            "214236-214672": 1,
            "214673-214762": 0,
            "214763-214840": 1,
            "214841-215120": 0,
            "215121-215403": 1,
            "215404-215498": 0,
            "215499-215613": 1,
            "215614-215687": 0,
            "215688-217571": 1,
            "217572-217634": 0,
            "217635-217691": 1,
            "217692-217781": 0,
            "217782-217977": 1,
            "217978-218091": 0,
            "218092-218575": 1,
            "218576-218628": 0,
            "218629-218697": 1,
            "218698-218858": 0,
            "218859-222520": 1,
            "222521-222594": 0,
            "222595-222722": 1,
            "222723-222737": 0,
            "222738-223265": 1,
            "223266-225789": 0,
            "225790-227094": 1,
            "227095-229653": 0,
            "229654-229822": 1,
            "229823-233190": 0,
            "233191-235847": 1,
            "235848-243202": 0
Old 13th January 2026, 21:18   #1646  |  Link
dkangel
it's this one
https://justpaste.it/bhv73 from your excell sheet
my last frame is 243218
EDIT : ok if i change the last line with "235848-243217": 0
Old 13th January 2026, 21:33   #1647  |  Link
Kuler087
Kuler087's Avatar
Yeah, my RPU frame count comes from the WEB-DL before it’s injected into the Blu-ray remux, which automatically duplicates frames at the end to match the video length.
Other than that, there’s no difference with that JSON, so you shouldn’t be getting a Metafier error. Are you using an older version of DoVi_meta.exe? I know that a while ago, it had an issue when converting RPU to XML, which caused this kind of error in Metafier.
Old 13th January 2026, 21:41   #1648  |  Link
dkangel
no everything is up to date, dovi script 3.1.0 with last tools directory
it seems ok now with changing the number of the last frame
if i put 243217
01/13/2026/21:43:58.811000000 metafier: INFO No issues found in the Metadata
Parsing RPU file...
Summary:
Frames: 243218
Profile: 8
Scene/shot count: 2335
L2 trims: 100 nits
Old 13th January 2026, 21:49   #1649  |  Link
Kuler087
Kuler087's Avatar
This movie trim pass is useless, FYI. You'll get better quality if you generate new CMV4.0 metadata.
Old 13th January 2026, 21:52   #1650  |  Link
dkangel
ok i will do that with resolve, is it possible to import your l5 metadata in resolve to avoid all the cuting stuff ?
Old 13th January 2026, 22:01   #1651  |  Link
Kuler087
Kuler087's Avatar
No. You can only import the scene cuts, but not L5.
You can use my Resolve project:
with homemade trims: https://drive.google.com/file/d/1M1t...usp=drive_link
without trims: https://drive.google.com/file/d/1Vrm...usp=drive_link
Old 13th January 2026, 22:03   #1652  |  Link
dkangel
ok i'll try this tomorrow, thank you for your time
Old 14th January 2026, 17:33   #1653  |  Link
dkangel
i've import your project with my mov file, scene cuts are ok and so L5 changes seems synchro too, i'm analysing for dv and give a try on my tv
but i think it will be ok
Old 14th January 2026, 23:21   #1654  |  Link
prudentavocado
Right, on a 5000-nits TV, there is no advantage to converting HDR10 to Dolby Vision in 3-1(or resolve).
For a native DV Blu-ray rip, some FEL titles do restore a brighter master, but that benefit is lost once they are converted to Profile 8. You need a device like the Ugoos Am6B+ to get that brighter DV from FEL playback.
Baking in the FEL properly to get a p8 is still lower on the picture quality scale than a Web p5 (due to the color space), correct?
prudentavocado is offline   Reply With Quote
Old 15th January 2026, 03:08   #1655  |  Link
Kuler087
Kuler087's Avatar
yes but streaming DV5 has worse hevc compression due to the lower bitrate
Old 15th January 2026, 05:45   #1656  |  Link
prudentavocado
Damn, so what do you choose? I suppose whatever looks pleasing to the eyes on your display?
I guess p8 remux > p5 > p8 encode
Old 15th January 2026, 14:12   #1657  |  Link
Kuler087
Kuler087's Avatar
When compressed properly, a P8 encode will be better than streaming DV5.
remux > p8 encode > P5
Old 16th January 2026, 00:06   #1658  |  Link
prudentavocado
No kidding, does that mean if the p8 encode and p5 are identical bitrate you'd go with the p8?
Thanks in advance.
Old 16th January 2026, 00:41   #1659  |  Link
Kuler087
Kuler087's Avatar
If the P8 encode comes from the UHD Blu-ray and I compressed it myself, yes.
Streaming compression is subpar. iTunes is DNR garbage, MA has a lot of compression noise and introduces visible artifacts with grain-heavy content, Disney’s and Fandango bitrate is too low, and Amazon’s HEVC compression is horrible.
Old 18th January 2026, 01:56   #1660  |  Link
prudentavocado
Interesting note about MA, everything else I've read about it is exceptional and potentially equal/better than the UHD disks.
batch scripts, dolby vision processing, dovi_scripts
