Old 18th December 2023, 08:19   #1  |  Link
tmonster
Pinnacle DV 500 plus - Windows 2000 or XP in 2023?
Hello!
I have acquired a DV 500 Plus with breakout box and CDs from a nice person on EBay. I've tried to install it on Windows XP SP 3 and got no joy.
I've also tried to install it on Windows 2000 and the drivers I found on the internet actually bluescreened Windows 2000. Eeek!
There are posts describing how to install this beast but since those posts went live, Pinnacle has removed the source of the links to the correct drivers.
Does anyone have links to the correct drivers for the card in this day and age? My card came with a copy of Premier 6.0 and a version of Pinnacles own software. There is a DV 500 disk, but it only seems to have NT4 and 98 drivers.
Thanks for your help.
Attachments Pending Approval
File Type: jpg PXL_20231217_233450283.jpg
tmonster is offline   Reply With Quote
Old 18th December 2023, 08:21   #2  |  Link
tmonster
Forgot System specs:
Dell Dimension 3100
Windows 2000 SP4 /Windows XP SP3
Old 18th December 2023, 19:36   #3  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
https://de.comp.tv-video.narkive.com...pinnacle-dv500
Pinnacle Systems DV500 DVD V. 4.5
Pinnacle Systems DV500 will not support Windows XP SP2.
(It might have worked under WinXP SP1, I gather)
Old 21st December 2023, 23:59   #4  |  Link
tmonster
OK, thanks. I'll try that. I also tried it on 2000 and got the same result.
Old 23rd December 2023, 03:02   #5  |  Link
tmonster
Do you have a link to a known-good set of drivers?
Old 29th December 2023, 10:15   #6  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Try asking on MSFN in the Windows XP section.
There's a very active XP diehard community there with people who are far more familiar with drivers, INF modding etc than me and I'm sure they're gonna help you.
Old 30th December 2023, 13:18   #7  |  Link
tmonster
Thank you!
Old 5th January 2024, 17:34   #8  |  Link
vitesseindo
The blue screen I remember from a long time ago is that when driver for Pinnacle DV500 was installed for Pinnacle Studio Deluxe version, but not the other way around 1. Later version of DV500 PCI card look similar to Pinnacle Studio Deluxe and they sometimes could get mixed up. You can try using the Pinnacle Studio Driver version 1 from https://cdn.pinnaclesys.com/SupportF...readmeHW10.htm to see if it can be properly installed without yellow exclamation or blue screen.
vitesseindo is offline   Reply With Quote
Old 12th February 2024, 17:10   #9  |  Link
ReinerSchweinlin
Maybe this archived version of the old webpage helps ?
https://web.archive.org/web/20060110...uestions+here_
