Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 6th December 2023, 01:44   #1  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
microenc for Linux/BSD
microenc is a small Bash shell script for encoding directories with
audio files to other audio formats (mp3/aac/vorbis/opus/ac3/eac3/dts/flac/wav)
using FFmpeg as encoder.
It requires FFmpeg to be compiled with the following libraries:
* libmp3lame
* libfdk-aac
* libvorbis
* libopus
It copies metadata and, for mp3, flac and aac, cover art if any in
the input file(s). Optional audio resampling is also supported.
The only requirements are FFmpeg and ffprobe (part of FFmpeg)
https://sourceforge.net/projects/microenc/
Old 6th December 2023, 19:45   #2  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.1
* Add support for DTS encoding
Old 8th December 2023, 08:35   #3  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.2
* Merged the AC3/EAC3 and DTS bitrate code
Old 18th December 2023, 20:59   #4  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.3
* Added support for FLAC and WAV encoding
Old 22nd December 2023, 16:38   #5  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.4
* Support selecting the WAV/PCM bit depth
Old 24th December 2023, 16:30   #6  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.5
* Added support for ALAC encoding
Old 25th December 2023, 15:37   #7  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.6
* Added support for encoding to AIFF
* Moved moov atom to beginning for ALAC and removed unneeded $params variable
Old 27th December 2023, 04:41   #8  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.7
* Add common audio extensions
Old 28th December 2023, 06:05   #9  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.8
* Merged the aiff and wav code
* Added a few more audio extensions to the list
Old 29th December 2023, 06:57   #10  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 2.9
* Add dsf and wvc to the file extensions list
* Protect the $hertz var in the resample cmd
* Added support for wavpack encoding
Old 12th January 2024, 16:47   #11  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 3.0
* Add more file extensions to the list
Old 13th January 2024, 18:16   #12  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 3.1
* Use -bitexact instead of -flags +bitexact in the wav ffmpeg cmd
Old 30th January 2024, 20:49   #13  |  Link
microchip8
microchip8's Avatar
ChangeLog for microenc 3.2
* Add more audio extensions to the list
