#2 | Link |
Big Bit Savings Now !
If you want to reach the additional tracks via menu you got to extend the menus
Tools: tsmuxeR, BDEdit and Lowpro's brilliant thread. https://forum.doom9.org/showthread.php?t=182746
#3 | Link |
This is a very loaded question and no, I don't think there's a guide or tutorial available that walk you through how to do this. More information is needed on the Blu-ray in question. Someone with knowledge would need to look over the structure of the Blu-ray and the source files you'd like to add. Only then would feedback be able to be provided to you on the best course of action to take in order to accomplish what you want.
#5 | Link |
Inbetween you may want to run BDInfo on your folder.
If java is involved, well...a longer journey.
#6 | Link |
Hello!
I'm resurrecting this old thread as I have a similar problem. I'd like to get german language in to "Jumanji next level" which was only released in 3D in Australia. Maybe someone can give me a kickstarter in the right direction... or help me somehow? I already ripped the German BR and the Australian 3D-BR with the Fox... ... and it seems the videos differ in length. Also the menu structure is completely different. In other words: I have no clue what kind of possibilities I have now and what would be the best approach to get a "new" BR that contains the movie in 3D. Jumanji.png Jumanji_3D.png Last edited by fhw72; 28th March 2024 at 12:56. |
#7 | Link |
Hi "fhw72", first you need to disassemble the ISO file, then replace the track in TsMuxer and assemble in the Blu-ray folder tab and by setting the mpls and clpi numbers in the Blu-ray window you replace the original files. Then using "ExplorerFab" create miniso file and in AnyDVD build the edited ISO image.
#8 | Link | |
Which tools to use? How to manipulate the menu etc.? |
#9 | Link |
"fhw72"
For disassembly and subsequent assembly, ExplorerFab, tsMuxerGUI, AnyDVD are needed. To work with the IG menu; Adobe Photoshop, Scenarist Designer PS, BDedit or IGEditor. For Java menus; Adobe Photoshop, DJ Java Decompiler 3.12, JByteMod-1.8.2, luyten-0.5.4, Hex Editor Neo, Scenarist Safeguard. |
#10 | Link | |
| Tags |
| author blu-ray, remux |
| Display Modes | |
