Old 22nd October 2022, 17:54   #1  |  Link
smithjohny039
Banned
Free Video Editing Software
Can someone recommend me free video editing software? (one that is really free, and not just a free trial ) I just need to do some basic editing for my Mass S Zee Capcut Template, beat 5/5 anh capcut template and rara capcut template Basically, I'm creating a video clip that compiles excerpts from other video files. So I need software, that'll allow me to cut out bits and pieces from other files and put them together into one.
Cheers.
smithjohny039 is offline   Reply With Quote
Old 23rd October 2022, 09:35   #2  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Kdenlive is free https://kdenlive.org/en/
or
openshot https://www.openshot.org/
Mr_Khyron is offline   Reply With Quote
Old 23rd October 2022, 18:41   #3  |  Link
smithjohny039
Banned
I heared alot about Openshot, I'll give it a try
Old 23rd October 2022, 23:49   #4  |  Link
Mr_Khyron
Member
Mr_Khyron's Avatar
Openshot is a very basic NLE but if you only are putting various clip together it will be fine.
If you want to do more advance stuff like color corrections etc i recommend Kdenlive
Old 11th November 2022, 21:22   #5  |  Link
PatchWorKs
PatchWorKs's Avatar
Check in our VIDEO category \ Editors for a quite-wide list of open source alternatives.
Hybrid Multimedia Production Suite will be a platform-indipendent open source suite for advanced audio/video contents production.
Official git: https://forart.it/HyMPS
PatchWorKs is offline   Reply With Quote
Old 3rd August 2023, 12:38   #6  |  Link
RoyMoises
Yes capcut is good, I also used to make video shots and other graphic related work that I need for my laptops papa blog posts. Its easy to use, affective for those people who don't even have designing skills.
RoyMoises is offline   Reply With Quote
Old 20th October 2023, 15:48   #7  |  Link
Dmitry Vergheles
Dmitry Vergheles's Avatar
Cheers.
give a try to our SolveigM Online Video Editor- its simple but totally free, no ads even
Regards,
Dmitry Vergeles
Solveig Multimedia - Video Editing Software
Dmitry Vergheles is offline   Reply With Quote
Old 15th April 2025, 12:29   #8  |  Link
ABDO
If you only need to cut and combine clips, Openshot is a good starter. I've used it before while stitching some old travel clips. It does freeze sometimes, but it's straightforward and gets the job done if you're not doing anything complex.
If you ever end up working with different video formats like MOV and need an easy way to convert them, check out this MOV converter:https://www.movavi.com/video-convert...converter.html. It helped me greatly when I had to clean up random footage before editing.
ABDO is offline   Reply With Quote
Old 15th November 2025, 07:09   #9  |  Link
tmonster
Blender - no, really!
https://youtu.be/99ZdOuJMrao
tmonster is offline   Reply With Quote
