Old 21st September 2020, 16:08   #1  |  Link
Losko
Modern x64 Avs+ compatible/friendly build of DGMPGDec/DGDecode take two
About this updated filter (https://github.com/Asd-g/MPEG2DecPlus), does anyone know whether an indexing application (even a CLI one) is being updated as well ?
Losko is offline   Reply With Quote
Old 21st September 2020, 19:36   #2  |  Link
l00t
Where's my loot?
What's the problem with the current version? Just use DGIndex 1.58 or DGIndex 1.58 mod for indexing and then use this filter from Asd-g to open the d2v file in avs+.
l00t is offline   Reply With Quote
Old 22nd September 2020, 15:18   #3  |  Link
Selur
Selur's Avatar
you could also use D2VWitch in case you don't want DGIndex for some reason.
Hybrid here in the forum, homepage, its own forum
Old 23rd September 2020, 11:08   #4  |  Link
Losko
None I'm aware of.
But, as a side note, I'm aware of is the very first problem of an unmaintained project, that is you don't know where to look in case of troubles - you can't even find a bugtracker.
Thank you both, I will keep using DGIndex 1.58 (which I appreciate indeed) through wine and look gladly at D2VWitch which also runs on command line and joins the growing team of not-only-Windows-native softwares leaded by avs+3.6
