Old 21st May 2020, 15:55   #1  |  Link
Stereodude
Modern x64 Avs+ compatible/friendly build of DGMPGDec/DGDecode
Is it possible to get a modern up to date x64 build of DGMPGDec/DGDecode? There's a 10 year old x64 build, but it returns a green screen when used with the Avs+ version of MP_Pipeline.
Stereodude is offline
Old 21st May 2020, 18:20   #2  |  Link
videoh
Useful n00b
DGDecNV is your ticket.
videoh is offline
Old 21st May 2020, 18:57   #3  |  Link
stax76
stax76's Avatar
https://github.com/chikuzen/MPEG2DecPlus
https://github.com/dwbuiten/d2vsource
stax76 is offline
Old 21st May 2020, 19:03   #4  |  Link
Stax, MPEG2DecPlus is v2.6 colorspace compatible, eg YV24, and I'm guessing that not Avs+ HBD compatible, yes ?
StainlessS is offline
Old 21st May 2020, 19:35   #5  |  Link
stax76
stax76's Avatar
You mean high bit depth? Are there any MPEG2 files with high bit depth?
stax76 is offline
Old 21st May 2020, 19:43   #6  |  Link
videoh
Useful n00b
None that I know of.
videoh is offline
Old 21st May 2020, 19:53   #7  |  Link
Stereodude
I have that and have been using it for years with VC1 & H264. I thought the MPEG-2 handling wasn't as robust in DGDecNV as DGMPGDec/DGDecode. That's what I remember reading some years ago, so my default for MPEG-2 has been DGMPGDec/DGDecode.
Old 21st May 2020, 19:54   #8  |  Link
sorry, daft question.
Old 21st May 2020, 20:40   #9  |  Link
Reel.Deel
Originally Posted by stax76 View Post
Update: https://github.com/Asd-g/MPEG2DecPlus
Documentation: http://avisynth.nl/index.php/MPEG2DecPlus
Reel.Deel is offline
Old 21st May 2020, 20:47   #10  |  Link
videoh
Useful n00b
Tell me, what is not robust about it?
videoh is offline
Old 21st May 2020, 20:54   #11  |  Link
stax76
stax76's Avatar
Originally Posted by Reel.Deel View Post
Thanks, I will update it.
stax76 is offline
Old 21st May 2020, 22:39   #12  |  Link
Stereodude
You read something! What a bunch of nonsense. Tell me, what is not robust about it?
Well according to your own post it doesn't support 4:2:2 color whereas the other does, so there's one.
https://forum.doom9.org/showpost.php...58&postcount=5
Do I have to keep finding your own posts and showing them to you?
Old 22nd May 2020, 00:29   #13  |  Link
videoh
Useful n00b
That's not a matter of robustness.
videoh is offline
Old 22nd May 2020, 01:47   #14  |  Link
poisondeathray
That's not a matter of robustness. Do I have to give you the definition?
It's actually one of the definitions of "robust"
"capable of performing without failure under a wide range of conditions"
The example given is "robust software"
https://www.merriam-webster.com/dictionary/robust
Definition of robust
d: capable of performing without failure under a wide range of conditions
//robust software
You could argue that 8bit 4:2:2 MPEG2 falls under a "wide range of conditions." It's actually very common in broadcast scenarios as XDCAMHD422
poisondeathray is offline
Old 22nd May 2020, 12:04   #15  |  Link
videoh
Useful n00b
Eh? DGDecNV absolutely does "perform without failure under a wide range of conditions". It's irrelevant that it does not support some single condition. If you want to take it to the limit you'd have to say that DGMPGDec is not robust because it does not open MKV, or other video types. In fact you'd have to say all software is not robust because it doesn't support everything.
videoh is offline
Old 22nd May 2020, 16:30   #16  |  Link
Stereodude
Dude, take a breath and chill... Not everyone who has a different opinion from you is out to get you or suffers from "DG derangement".
There are perfectly valid reasons why someone might want a modern x64 build of DGMPGDec/DGDecode. MPEG2DecPlus has some of the functionality of DGMPGDec/DGDecode stripped out. DGDecNV does not supersede DGMPGDec/DGDecode in every way nor does every PC have a Nvidia graphics card in it.
If you don't want to make such a build (for whatever reason), just say so without all the theatrics and drama.
Old 22nd May 2020, 17:03   #17  |  Link
jpsdr
https://github.com/299792458m/DGIndex_mod
Don't which one is "better" between this one and MPEG2DecPlus.
My github.
jpsdr is offline
Old 22nd May 2020, 17:34   #18  |  Link
videoh
Useful n00b
You're the one who claimed DGDecNV is not robust. Now you are deflecting from that by attributing all kinds of nonsense to me. I only objected to you calling DGDecNV not robust. Everything else is your own creation.
videoh is offline
Old 22nd May 2020, 19:29   #19  |  Link
Stereodude
Shove it, pal. You're the one who claimed DGDecNV is not robust. You are desperately trying to deflect from that by attributing all kinds of nonsense to me. I only ever objected to you calling DGDecNV not robust. Everything else you spout is your own despicable DG-deranged fantasy.
It was not as robust when I tested it against DGMPGDec/DGDecode in terms of handling damaged MPEG-2 stream from OTA HDTV recordings about 10 years ago and I believe others posted similar findings. I'm sorry that your fragile ego can't handle that some people might think that DGDecNV is not perfect and better than DGMPGDec/DGDecode in every regard .
I'm sure you'll be demanding samples and receipts in short order.
Old 22nd May 2020, 19:58   #20  |  Link
amichaelt
Posts: n/a
It's also funny in light of the hypocrisy of his statement when a large number of his posts in many threads these days is simply trolling and sh*tposting.
