Old 5th January 2026, 19:25   #3581  |  Link
pinterf
That's too old, see alsk the so-called mutex-crash, which I mentioned earlier, in 2024 the mutex ABI has been changed, but I expected it that the 14.38 was also crashing on that reason.
EDIT: my earlier finding on mutex crash incompatibility": machines with old redistibutable before 14.39.32551.0 would crash if VS is later than ~July 2024
Based on this: FranceBB had pre-14.39.32551 redist and when using 14.44 compiled avisynth dll --> crash (I bet it crashed on the infamous mutex lock).
pinterf is offline   Reply With Quote
Old 5th January 2026, 22:25   #3582  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
yeah I saw the posts, but I thought that installing Windows6.1-KB2999226-x64.msu from the link you were suggesting was gonna be enough.
Originally Posted by pinterf View Post
- Redistributable 14.44.35211 does work on Windows 7 if KB2999226 is installed:
https://support.microsoft.com/en-us/...5-287930f3560c
Unfortunately it wasn't. I'll try the AIO package from here https://github.com/abbodi1406/vcredist/releases on Windows Server 2008 R2 Standard x64 and see whether it actually updates the file in System32. If it does, I'll try again x64-win7-19.44.35221-17.14. In any case, x64-win7-19.38.33145-17.8 works even with an older version of the redistributable.
In the meantime, I've tested Avisynth_3.7.6_20260105_VS2026tst_r4430 on Windows XP Professional x86 and it works like a charm on the usual XP build.
Old 6th January 2026, 13:35   #3583  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Alright, so, take 2.
I've installed VisualCppRedist_AIO_x86_x64.exe which updated msvcp140.dll to 14.44.35211.0 on Windows Server 2008 R2.
I then tried Avisynth_3.7.6_20260105_VS2026tst_r4430 version x64-win7-19.44.35221-17.14
And sure enough this time it worked with this new version as well.
Log file created with: AVSMeter 3.0.9.0 (x64)
Command line switches: -Avsinfo -lf -log
[OS/Hardware info]
Operating system: Windows Server 2008 R2 (x64) Service Pack 1.0 (Build 7601)
CPU: Intel(R) Xeon(R) CPU X5570 @ 2.93GHz / Gainestown 8M (Xeon)
MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2
4 physical cores / 8 logical cores
[Avisynth info]
VersionString: AviSynth+ 3.7.5 (r4430, master, x86_64)
VersionNumber: 3.75
File / Product version: 3.7.5.0 / 3.7.5.0
Interface Version: 12
Multi-threading support: Yes
Avisynth.dll location: C:\windows\system32\avisynth.dll
Avisynth.dll time stamp: 2026-01-05, 12:26:24 (UTC)
PluginDir2_5 (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64
PluginDir+ (HKLM, x64): C:\Program Files (x86)\AviSynth+\plugins64+
Yep. Bingo. Now it works.
Old 7th January 2026, 19:44   #3584  |  Link
pinterf
FranceBB, thanks for testing it.
New build: Avisynth r4439
https://github.com/pinterf/AviSynthP...3.7.6pre-r4439
We have even more AVX512 resampler specializations, big thanks to DTL2020's innovation.
As usual, I include two main build types. Now the pack comes with a Win7 compatible build as well.
1.) XP builds (v141_xp toolset + special compile flags)
2.) modern (clang-cl - LLVM 20.1.8) well optimized builds. VS2026 v145 toolset
3.) a Windows 7 compatible - medium-modern build (x64 only) v143 toolset
Note for Windows 7 compatibility build:
- I used the usual VS2022 v143 toolset: 14.44.35221. (v143 is selectable from Visual Studio 2026 as well)
- Avisynth.dll requires an up-to-date Win7 compatible Visual C++ redistributable pack.
Pre-14.39 VC redistributable versions will crash with Access Violation ("mutex-lock" issue)
When in doubt which version you have, check your c:\windows\system32\msvcp140.dll properties.
Download 14.44.35221 from: https://github.com/abbodi1406/vcredi...es/tag/v0.92.0
Get the update from:
20260107 3.7.5.r4439 (pre 3.7.6)
  * add AVX512 code path (tuning by DTL2020)
    - 32-bit float resamplers, verticals; horizontals up to kernel size 16.
    - 8-16-bit horizontal resamplers,
      - kernel size <= 4 and specific ratios; 300%+ !!
      - kernel sizes up to 8 and 16 and specific ratios.
    - 8-16-bit vertical resamplers
For online documentation, please check https://avisynthplus.readthedocs.io/en/latest/
Full change log:
https://avisynthplus.readthedocs.io/...gelist376.html
Old 8th January 2026, 19:31   #3585  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
No problem, it's literally the least I can do, master Ferenc.
Works on Windows XP Professional x86
Works on Windows Server 2008 R2 Standard x64
Old 9th January 2026, 04:04   #3586  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
jpsdr, many thanks ! Your builds saved the day for my Win7 rigs.
I've added Avs+ on my github with Windows 7 compatible builds.
The oldest Win7U64 i940XM 8GB from 2010:
Both your builds r4449 x86 and x64 run well, just a quick test. AvsPmod 2.7.9.5 with the christmas script.
Two newer Win7U64 i7-4960X 32GB from 2014 are in the dock under repair, to be tested later.
Old 9th January 2026, 16:06   #3587  |  Link
manolito
manolito's Avatar
Quick request for clarification:
I am under Win7 64, so far I use the latest stable version of AVS+ Avisynth 3.7.5 (20250420)
I only use the 32bit version of AVS+, I have no use for the 64bit version. This probably means that Option 3.) will not work for me, because I only use 32bit plagins. Is this assumption correct?
Cheers
manolto
Old 9th January 2026, 16:31   #3588  |  Link
pinterf
Cheers
manolto
Omitting the win7 32-bit was just a time-saving option for me, since assembling such a release pack is ~3 hours, I was in short of time.
At least it turned out that someone is still using 32 bit. Next time, you can expect such a test build.
Old 9th January 2026, 18:57   #3589  |  Link
jpsdr
Nice it was usefull for someone.
As it takes hours for me to make all these builds, don't expect frequent updates...
My github.
Old 10th January 2026, 21:56   #3590  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
option 1 will work just fine as the XP x86 builds work on everything else as well, so Vista, 7, 8, 8.1 and 10 x86 will all happily run those.
Old 11th January 2026, 15:55   #3591  |  Link
manolito
manolito's Avatar
Thanks FranceBB, this makes it perfectly clear...
OTOH I am unsure why I should upgrade from version 3.7.5 at all. I will certainly not abandon Win7 64, so I wonder which real advantages the upcoming new version will offer under Win7 for the 32bit version of AVS+. Let's wait and see...
Cheers
manolito
Old 11th January 2026, 18:22   #3592  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Well, the changelog is currently here https://avisynthplus.readthedocs.io/...gelist376.html
I still think you should keep it updated once it comes out as "Stable" and is released by Stephen and Master Ferenc as it's always a nice thing.
Sure, older systems and CPUs won't benefit from things like the AVX512 assembly speed bump for the resizers (and the same goes for other architectures like ARM which have their own intrinsics in NEON, DOTPROD and CPUF), but every system still benefits from the updated core and the improvements and fixes the come with it.
I'm talking about things like "add" and "subtract" in Overlay to support 32bit float, utf8 parameter for AddAutoLoadDir, AddAutoLoadDir, LoadPlugin, DumpFilterGraph, L2 cache size being displayed when using Info(), as well as a bunch of bug fixes like "reverse" properly handling 24bit audio or the one for Animate and 64bit double that caused StainlessS Christmas celebration to be ruined (I'm joking, I'm joking XD) and so on.
In other words, it's always a nice thing to keep the frameserver updated, but ultimately it's for you to decide, just look at the changelogs and see if there's something that makes you consider the release worth upgrading once the stable version is available.
Old 13th January 2026, 11:41   #3593  |  Link
manolito
manolito's Avatar
Thanks FranceBB for your suggestions...
Especially the link to the changelog is very helpful. But for my use cases I cannot find any new features which would make my life easier. Of course I may have overlooked something.
After my stroke about 4 years ago I did switch from the old standard Avisynth to Avisynth+ for the only reason to be able to use DGHDRToSDR. Works much better for me than the FFmpeg based options I have (My hardware cannot use LibPlacebo). But I did not install the 64bit version of Avisynth+, simply because I was very happy with my proven and trusted 32bit plugins, and because I did not want to have 2 completely different Avisynth installations on my machine (with all the switching between the different versions).
So for me it will be Avisynth+ 32bit exclusively, and so far I have not missed a 64bit version. Since my stroke I mainly use FFmpeg for most of my conversion needs. Luckily my old Thinkpad T530 (running Win7 64bit) is still happy with the special FFmpeg versions made by autodidact. I still have a love-hate relationship with FFmpeg, but over time I mostly got used to it, and I know how to work around FFmpeg's limitations.
So thanks again for your help. I guess we will talk again after the stable version 3.7.6 comes out.
Cheers
manolito
Old 13th January 2026, 23:34   #3594  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Wow it's been 4 years already...! I remember when you showed as offline for a while and we were all a bit concerned 'cause unlike real life, when online people disappear there's often no way of knowing what happened. Obviously I hope that they just got tired and wanted to enjoy life, so I'm glad when I see them come back every once in a while to say hi (like Didée, vcmohan, Chikuzen etc), but I always wonder "what if". For instance, I still remember when Groucho left and every time I open AVSMeter to test a script or to test the plugins on a new server etc I keep wondering...
Anyway, let me just say that we're all glad to see you around and still encoding.
Old 17th January 2026, 19:20   #3595  |  Link
v0lt
I have a question about the names of the changed functions in the plugins.
The MPC-BE project includes VSFilter, which is also a plugin for AviSynth 2.5 and later. The plugin implements four functions.
In the original VSFilter, the functions were described as follows:
VobSub (clip, string)
TextSub (clip, string "file", int "charset", float "fps", string "vfr")
TextSubSwapUV (bool)
MaskSub (string "file", int "width", int "height", float "fps", int "length", int "charset", string "vfr", string "pixel_type")
But currently, "charset" has been replaced with "defcodepage."
Am I correct in thinking that in this case, TextSub and MaskSub should be renamed? For example, adding the number 2 to the function names.
v0lt is offline   Reply With Quote
Old 22nd January 2026, 14:38   #3596  |  Link
pinterf
I checked xy-VSFilter which I used to maintain, it has "charset" in both functions. I don't know the rest of VSFilter history.
Old 22nd January 2026, 18:10   #3597  |  Link
v0lt
The replacement of "charset" with "defcodepage" occurred only in VSFilter (MPC-BE project).
Old 23rd January 2026, 03:38   #3598  |  Link
qyot27
qyot27's Avatar
VSFilter_VSFilter(<options>, charset="")
VSFilterBE_VSFilter(<options>, defcodepage="")
would work inside of the same script so long as the .dll filenames are different (per the example, VSFilter.dll and VSFilterBE.dll). AviSynth's pseudo-namespacing ability isn't something that's brought up regularly (most famously it usually gets mentioned in tandem with the variety of plugins providing a function named MPEG2Source), but it's existed since probably sometime in the 2.5 series at least, if not earlier.
Ultimately, it's up to you whether it's important enough of a difference to iterate the function names the MPC-BE VSFilter.dll provides.
Old 26th January 2026, 17:51   #3599  |  Link
v0lt
Okay. I renamed it to VSFilterBE.dll. I've left the function names the same for now.
Old 29th January 2026, 12:22   #3600  |  Link
DTL
It looks documentation for ConvertToPlanarRGB missed chromaresample params:
https://avisynthplus.readthedocs.io/...s/convert.html
RGB planar
ConvertToPlanarRGB(clip, [ string matrix, bool interlaced,
string ChromaInPlacement,
string chromaresample ] )
ConvertToPlanarRGBA(clip, [ string matrix, bool interlaced,
string chromaresample,
float param1, float param2, float param3 ] )
But sources for ConvertToPlanarRGB also lists param1,2,3 - https://github.com/AviSynth/AviSynth...onvert.cpp#L72
{ "ConvertToPlanarRGB", BUILTIN_FUNC_PREFIX, "c[matrix]s[interlaced]b[ChromaInPlacement]s[chromaresample]s[param1]f[param2]f[param3]f", ConvertToRGB::Create, (void *)-1 },
{ "ConvertToPlanarRGBA", BUILTIN_FUNC_PREFIX, "c[matrix]s[interlaced]b[ChromaInPlacement]s[chromaresample]s[param1]f[param2]f[param3]f", ConvertToRGB::Create, (void *)-2 },
