#3281 | Link |
Acid fr0g
What kind of script could be used as "synthetic benchmark" to measure AVS+ performance on different CPU/GPU/versions/compilers?
It could be useful to have a standard one including the major possible operations on a video / colorbar and heavy enough to show differences in meaningful terms. Thanks in advance for all your efforts.
@turment on Telegram |
#3282 | Link | |
I was launching x265 from a Powershell script using Windows PowerShell 5.x (W10 22H2), which had it's own issues with the é in the path and passing a viable command line to x265. I took the é out of the path, so the command line was correct/valid, but I got the error I posted. Installing PowerShell 7.5 and using it instead of 5.x seems to have fixed the script issues with the é in the path and now the same exact command line to jpsdr's x265 build works from PowerShell 7.5 (but didn't in 5.x) and x265 can open the .avs file
#3283 | Link |
pinterf,
Thank you very much for the official 3.7.4 release. I have two questions though.... What was the logic behind the resizers defaulting to center chroma placement when (as far as I know) all the other chroma placement aware functions in Avisynth+ such as ConvertToYUV420 default to left. I've also failed miserably to get either of the Intel 2025 ICX builds you uploaded here to work. I've tried them with Wine on Linux and Windows 11 in VirtualBox, but the result is the same either way and AvsPmod complains it can't find Avisynth.dll. I didn't have a problem with the Intel ICX version from r4246. For the record, I installed AviSynth+ 3.7.4 with vcredist.exe first, then replaced Avisynth.dll in the system32 folder. Thanks again! |
#3284 | Link |
![]() Join Date: Feb 2005
Please explain me that info:
"Use system installs of DevIL and SoundTouch on all platforms, remove in-tree binaries/code" 1) Avs+ 3.7.4 need DevIL.dll in system forder? Or Avs+ 3.7.4 not need it at all ? Because the Groucho Universal Avisynth Installer delete always devil.dll from system folder when uninstall, and show error when install a Avs version without a devil.dll file. 2) What about SoundTouch? In Avs+ there are always a TimeStretch.dll plugin, and it still are there, with the SoundTouch library. It is a info only to compile new versions, usseless for final users? |
#3285 | Link | |
https://gitlab.com/uvz/AviSynthPlus-Builds/
Main Systems:- 9970X on Gigabyte TRX50 AERO D 7970X on Asus Pro WS TRX50-Sage WiFi 9950X3D on MSI Carbon X670E 7950X on Gigabyte Aorus Elite B650 i9-13900KF on MSI Tomahawk B660 |
#3286 | Link | |
https://github.com/AviSynth/AviSynthPlus/releases The MX Linux archive manager reports an extraction error. 7-Zip on Windows is a bit more informative and reports an unsupported compression method, although in both cases it appears only to be the files in the arm64 folder that won't extract. Cheers. |
#3287 | Link | ||
Prior to that change it looked like this:
AviSynth.dll never needed DevIL.dll, at least as long as AviSynth+ has been around with ImageSource as a separate plugin. Look at the -filesonly package, and it should be immediately clear (DevIL.dll is shipped alongside ImageSeq.dll in the imageseq_xp-legacy directory, while the ImageSeq.dll in the main plugins area is significantly larger in size...because DevIL was linked into it statically). Having a DevIL.dll sitting around in system32 won't impact an ImageSeq that's been linked against a static build of DevIL. SoundTouch was different in that it wasn't a checked-in binary, it was vendored source code copied over from the actual SoundTouch repository. But it had the similar issue of having to be manually updated by us whenever the actual upstream version of SoundTouch changed, which often would not happen unless we were aware of it (in fact, there was a period where it was extremely out of date, shipping an old 1.x version of the source while upstream was well into the 2.1 or 2.2 area, but I can't remember when precisely that was). In either case, it means that having up-to-date versions of ImageSeq's and TimeStretch's dependencies don't rely on how things get committed into the AviSynth+ core source repository, and literally anyone building from source can do it. This also means the flexibility to build against either the DevIL SDK that ships as a dynamic .dll or building the entire thing as a static library and making ImageSeq.dll a monolithic file. The same is true of SoundTouch, but vendoring the source code means it was always static; now there is the option of building it as a .dll if you want. Quote:
7zip upstream does have standalone Linux binaries on their download page, if you'd rather get it directly from them instead of waiting. |
#3288 | Link | |
#3289 | Link | |
Alignment is 64, if the passed parameter (8) is smaller than that, it is ignored. |
#3290 | Link | |
#3292 | Link | |
If it is requested alignment and it can be > 64 - it will also make row length mod of alignment so plugin can at least make stream-store of several AVX512 64bytes datawords in a single burst up to the very end of row processing loop ? Last edited by DTL; 26th March 2025 at 16:25. |
#3293 | Link | |
#3294 | Link | |
#3296 | Link |
Has something changed in the Directshow plugins build settings ? I was able to build the plugin a while ago, now i have compiler errors i didn't have before (Windows 7 x86 environment)...
![]() I also don't understand why the VDub plugin is not showing anymore when i run cmake under my Windows 7 x86 environment (1) (VS2019 11.31) , but it appears magicaly under my Windows 7 x64 environment (VS2019 9.26 + last version of LLVM)... ![]() BAT file for (1) : Code:
@mkdir x64 @mkdir x86 @cd x86 G:\CMakex86\bin\cmake -G "Visual Studio 16" -A Win32 ../../../Visual_2010/AviSynthPlus -DENABLE_PLUGINS=ON -DBUILD_DIRECTSHOWSOURCE=ON -DENABLE_INTEL_SIMD=ON -DBUILD_SHARED_LIBS=ON -DENABLE_CUDA=OFF -DWINXP_SUPPORT=OFF -DCMAKE_CXX_FLAGS_RELEASE="/sdl- /MP /Ob2 /O2 /Oi /Ot /Oy /GT /GL /GF /GS- /Gy /Qpar /openmp /arch:SSE2 /MD" -DIL_LIBRARIES="F:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x86\Release\DevIL.lib" -DILU_LIBRARIES="F:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x86\Release\ILU.lib" -DCMAKE_PREFIX_PATH="F:\PRG\Visual_2019\AviSynth\Deps\Soundtouch\x86;F:\PRG\Visual_2019\AviSynth\Deps\DevIL" -DPKG_CONFIG_EXECUTABLE="G:\PKGConfig\pkg-config.exe" @cd ..\x64 G:\CMakex86\bin\cmake -G "Visual Studio 16" -A x64 ../../../Visual_2010/AviSynthPlus -DENABLE_PLUGINS=ON -DBUILD_DIRECTSHOWSOURCE=ON -DENABLE_INTEL_SIMD=ON -DBUILD_SHARED_LIBS=ON -DENABLE_CUDA=OFF -DWINXP_SUPPORT=OFF -DCMAKE_CXX_FLAGS_RELEASE="/sdl- /MP /Ob2 /O2 /Oi /Ot /Oy /GT /GL /GF /GS- /Gy /Qpar /openmp /arch:SSE2 /MD" -DIL_LIBRARIES="F:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x64\Release\DevIL.lib" -DILU_LIBRARIES="F:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x64\Release\ILU.lib" -DCMAKE_PREFIX_PATH="F:\PRG\Visual_2019\AviSynth\Deps\Soundtouch\x64;F:\PRG\Visual_2019\AviSynth\Deps\DevIL" -DPKG_CONFIG_EXECUTABLE="G:\PKGConfig\pkg-config.exe" pause Code:
@mkdir x64_Broadwell @mkdir x86_Broadwell @cd x86_Broadwell G:\CMakex64\bin\cmake -G "Visual Studio 16" -A Win32 ../../../Visual_2010/AviSynthPlus -DENABLE_PLUGINS=ON -DBUILD_DIRECTSHOWSOURCE=ON -DENABLE_INTEL_SIMD=ON -DBUILD_SHARED_LIBS=ON -DENABLE_CUDA=OFF -DWINXP_SUPPORT=OFF -DCMAKE_CXX_FLAGS_RELEASE="/sdl- /MP /Ob2 /Oi /Ot /Oy /GT /GL /GF /GS- /Gy /Qpar /arch:AVX2 /MD" -DIL_LIBRARIES="C:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x86\Release\DevIL.lib" -DILU_LIBRARIES="C:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x86\Release\ILU.lib" -DCMAKE_PREFIX_PATH="C:\PRG\Visual_2019\AviSynth\Deps\Soundtouch\x86;C:\PRG\Visual_2019\AviSynth\Deps\DevIL" -DPKG_CONFIG_EXECUTABLE="G:\PKGConfig\pkg-config.exe" @cd ..\x64_Broadwell G:\CMakex64\bin\cmake -G "Visual Studio 16" -A x64 ../../../Visual_2010/AviSynthPlus -DENABLE_PLUGINS=ON -DBUILD_DIRECTSHOWSOURCE=ON -DENABLE_INTEL_SIMD=ON -DBUILD_SHARED_LIBS=ON -DENABLE_CUDA=OFF -DWINXP_SUPPORT=OFF -DCMAKE_CXX_FLAGS_RELEASE="/sdl- /MP /Ob2 /Oi /Ot /Oy /GT /GL /GF /GS- /Gy /Qpar /arch:AVX2 /MD" -DIL_LIBRARIES="C:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x64\Release\DevIL.lib" -DILU_LIBRARIES="C:\PRG\Visual_2019\AviSynth\Deps\DevIL\lib\x64\Release\ILU.lib" -DCMAKE_PREFIX_PATH="C:\PRG\Visual_2019\AviSynth\Deps\Soundtouch\x64;C:\PRG\Visual_2019\AviSynth\Deps\DevIL" -DPKG_CONFIG_EXECUTABLE="G:\PKGConfig\pkg-config.exe" pause
My github. Last edited by jpsdr; 26th March 2025 at 19:29. |
#3297 | Link |
There was something strange with DSS during the release process, but when I looked at the commit history either nothing had touched that part of the code or it wasn't immediately obvious it had anything to do with the errors I was seeing. For whatever reason, only v141_xp/WINXP_SUPPORT=ON is able to build DirectShowSource. Regular v141 as well as the current VS2019 toolset (v142 or v143, not sure which it is) was not able to. It was erroring out over problems in the baseclasses headers which hadn't been touched (something about {dtor}), as well as some const array things in DSS itself that I figured were probably failing only because of the baseclasses error. If it was something in DSS itself that caused it, the only thing recent enough to have modified anything deeper than just some boilerplate was when the utf8 parameter support was added in late 2023; but I don't see how that would still compile with v141_xp and not with the others.
So yeah, due to that, the DirectShowSource.dll in all of the x86/x64 variants is actually the XP one, because that's the only one that would build. My guess is that it's something in VS2019 itself, because it was fine when I built the release for 3.7.3. With VDubFilter, that's probably due to the architecture check at https://github.com/AviSynth/AviSynth...eLists.txt#L57 ; that seems to be a partial mistake, as it can recognize AMD64 but it doesn't recognize X86, even though I thought the value of CMAKE_SYSTEM_PROCESSOR derives from what the system's PROCESSOR_ARCHITECTURE variable sets, not what exists in, for example, TargetArch.cmake. Change that from X86 to i386 and see if it builds on 32-bit.
AviSynth+ native Linux/macOS/BSD support | AviSynth+ utilities and plugins for non-Windows and non-x86(-64) Last edited by qyot27; 26th March 2025 at 20:20. |
#3298 | Link |
Quick question about new resamplers : if using default settings for new parameters/features, is the output identical to previous version ?
=> Or said otherwise, is the result of same script/same video with 3.7.3 and with 3.7.4 identical ? EDIT: Tried i386 but didn't solve the issue, but removing the processor check solved it... ![]() I thought it could be a cmake issue, so i tested 3.31.[6 to 2] versions and also 3.30.8, but issue was the same.
My github. Last edited by jpsdr; 27th March 2025 at 20:22. |
#3299 | Link |
"if using default settings for new parameters/features, is the output identical to previous version ?"
Expected no. At least with some kernels/sources combinations. The edges issues were solved so result is now different at least at the edges of frame (at distance about filter_support from edge samples). See example - https://forum.doom9.org/showthread.p...95#post2016395 Center area of the frame may be identical. Though at some ways of computing (SSE ?) pinterf also noted about skipping old lower precision SIMD method (with integer 8 and 16 bit samples formats ?). And even center area of the frame may have different result. Expected higher precision. https://github.com/AviSynth/AviSynth...ent-2733718649 - significant code simplification is in progress (finally!) by dropping some SSSE3 and SSE4.1 8-bit resizer variants, which sacrificed accuracy for a slightly quicker mulhrs. I believe this was a mid-2000s hack. I retained SSE2, which is correct. Similarly, the AVX2 version was rewritten to avoid using mulhrs. I came across these while looking into the old resizer sources. Last edited by DTL; 28th March 2025 at 10:21. |
#3300 | Link |
Thanks, DTL, for summarizing the changes that jpsdr would meet. So, no, the results of 8-bit resamplers would not be bit identical. At other bit depths, I believe nothing has changed (except for the edge handling; you can surely expect differences there). Chroma results would also be different unless you specify the placement as "center" manually.
| Display Modes | |
