Old 20th March 2022, 20:13   #2001  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Out of curiosity, what about propclearall() right after indexing?
Old 21st March 2022, 05:32   #2002  |  Link
Selur
Selur's Avatar
ClearAutoloadDirs()
LoadPlugin("I:\INNOIN~1\64bit\Avisynth\AVISYN~1\LSMASHSource.dll")
LoadPlugin("I:\INNOIN~1\64bit\Avisynth\AVISYN~1\MosquitoNR.dll")
LWLibavVideoSource("G:\TESTCL~1\test.avi",cache=false,dr=true,format="YUV420P8", prefer_hw=0)
propclearall()
MosquitoNR()
ConvertToRGB32(matrix="Rec601")
return last
also crashes at the initial invoke call and without the 'ConvertToRGB32' it crashes when 'ConvertToRGB32' is later called.
-> no change
Hybrid here in the forum, homepage, its own forum
Old 21st March 2022, 10:18   #2003  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Ok, so I've tried to test a bit:
ColorBars(848, 480, pixel_type="YV12")
MosquitoNR()
ConverttoRGB(matrix="Rec601")
works.
So I tried with a real video, an XDCAM-50 file and it works too:
FFVideoSource("\\mibctvan000.avid.mi.bc.sky.it\Ingest\MEDIA\temp\Test9_UCN_manual_QC_SubITA_DolbyE_DolbyE_PCM_PCM.mxf")
propClearAll()
MosquitoNR()
Last but not least, I've tried LWLibavVideoSource() which is the indexer you were trying to use and... it works:
LWLibavVideoSource("\\mibctvan000.avid.mi.bc.sky.it\Ingest\MEDIA\temp\Test9_UCN_manual_QC_SubITA_DolbyE_DolbyE_PCM_PCM.mxf")
propClearAll()
MosquitoNR()
and even your exact same command line:
Avisynth 3.7.2 Stable x64
Windows 11 x64
Out of curiosity, are you using this build of MosquitoNR? Link
Old 21st March 2022, 13:03   #2004  |  Link
Selur
Selur's Avatar
I know that it works in avspmod, problem is that it does not work in my code.
Yes, I do.
Cu Selur
Old 21st March 2022, 16:35   #2005  |  Link
pinterf
Originally Posted by Selur View Post
Using latest AviSynth+ 3.7.2
When I use:
my code crashes when loading the the file:
AVS_linkage = m_env->GetAVSLinkage();
    const char* infile = m_currentInput.toLocal8Bit(); //convert input name to char*
    std::cout << "Importing " << infile << std::endl;
    AVSValue arg(infile);
    m_res = m_env->Invoke("Import", AVSValue(&arg, 1)); // <- here it dies
see: https://github.com/Selur/avsViewer/b...iewer.cpp#L142
-> any idea?
Cu Selur
Just a faint guess. it is the first use of m_res. Maybe the crash is related to it.
In the avsViewer::avsViewer there is an initialization of AVSValue m_res in that initialization list. Here:
https://github.com/Selur/avsViewer/b...Viewer.cpp#L28
But the global variable const AVS_Linkage *AVS_linkage which is needed as a bridge to fill/initialize an AVSValue does not exist yet. I'd try to remove m_res from the initialization list. Otherwise your code seems to be correct: toLocal8Bit is providing a safe null-terminated buffer; I guess 'm_env' exists just fine, so GetAVSLinkage should work as well.
pinterf is offline   Reply With Quote
Old 21st March 2022, 17:07   #2006  |  Link
Selur
Selur's Avatar
Sadly, removing m_res from the initialization list doesn't help.
The strange thing is that if the .avs script doesn't include any "ConvertTo..." calls the loading of the script works fine, but then it crashes when I call ConvertToRGB32. :/
When I use:
bool avsViewer::invokeFunction(const QString& name)
  try {
    std::cout << "invoking " << qPrintable(name) << std::endl;
    const char* function = name.toLocal8Bit();
    if (!m_env->FunctionExists(function)) {
       m_env->ThrowError(name.toLocal8Bit() + " does not exist!");
    m_res = m_env->Invoke(function, AVSValue(&m_res, 1)); // invoking the function
    std::cerr << "invoked " << qPrintable(name) << std::endl;
    return true;
  } catch (AvisynthError err) { //catch AvisynthErrors
    std::cerr << "Avisynth error " << qPrintable(m_currentInput) << ": " << std::endl << err.msg << std::endl;
  } catch (...) { //catch the rest
    std::cerr << "Unknown C++ exception" << std::endl;
  return false;
I see:
Initializing the avisynth script environment,..
loaded avisynth dll,..(I:/workspace/avsViewer/release/AviSynth.dll)
loaded CreateScriptEnvironment definition from dll,..
Importing c:\Users\Selur\Desktop\test.avs
Color: YV12, Resolution: 640x352, Frame rate: 25 fps, Length: 429 frames, PRO
Current color space: YV12
invoking ConvertToRGB32
so it dies in
This is driving me nuts.
Cu Selur
Old 21st March 2022, 17:24   #2007  |  Link
Ceppo
I'm not in the right mind at the moment but:
Is assigning a value to m_res and to use it with a reference at the same time... legit??
/I'mNotAProgrammer
Ceppo is offline   Reply With Quote
Old 21st March 2022, 17:40   #2008  |  Link
Selur
Selur's Avatar
Since the right side should be evaluated before the assignment I see no problem with it.
Cu Selur
Ps.: Can someone compile MosquitoNR with MVSC++ 2019?
Old 21st March 2022, 18:22   #2009  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
We should probably pop all this out into its own thread. But for now, I can confirm that
		temp = env->Invoke("colorbars", 1280); // how do you invoke a filter with no parameters?
		temp = env->Invoke("converttoyv12", AVSValue(&temp, 1));
		temp = env->Invoke("mosquitonr", AVSValue(&temp, 1));
		temp = env->Invoke("converttorgb32", AVSValue(&temp, 1));
crashes (MSVC2019, Avisynth+ 3.7.1), but doesn't crash if I remove the converttogrb32.
Yet putting ConvertToRGB32 directly in a script after MosquitoNR works fine. Very strange.
wonkey_monkey is offline   Reply With Quote
Old 21st March 2022, 18:43   #2010  |  Link
Reel.Deel
For x64 it would have to be with the Intel compiler since the source contains assembly.
On a side note, for anyone with the means to do it. The following plugins were all compiled with the Intel compiler as well. Downside is that they are compiled for the 2.5 interface and may be problematic as stated here: https://github.com/AviSynth/AviSynthPlus/issues/272
Originally Posted by pinterf
Not only unaware of frame props.
SmoothD2 is an AviSynth 2.5 plugin which can use hardcoded ("baked") code for frame manipulation instead of Avisynth interface calls. Behavior is uncontrolled and random.
  • Decomb
  • IT_YV12
  • MosquitoNR
  • SmoothD
  • SmoothD2
A 2.6 interface update for these plugins would be appreciated .
Old 21st March 2022, 19:02   #2011  |  Link
Selur
Selur's Avatar
Man I'm happy that this does not happen to just me.
hmm,.. I'm using 3.7.2 and there "putting ConvertToRGB32 directly in a script after MosquitoNR" does not work fine here. :/
Yup, that would be cool.
Cu Selur
Old 21st March 2022, 19:04   #2012  |  Link
wonkey_monkey
I'm trying to build 3.7.2 from source with MSVC 2019. I download the source, use "Open a local folder" and it imports everything fine. I then go to Manage Configurations... which gives me a GUI to make changes to CMakeSettings.json. I take out the default Debug build and replace it with x64-Release, and I change the Configuration type to Release.
When I try to build, I get a number of unresolved externals:
The funny thing is I can do the exact same thing on my work computer, and it works fine. But not at home. Does anyone know what's wrong with my setup? Am I missing some required part of MSVC?
Edit: I CAN successfully build an x64-Debug version. But not Release.
Old 21st March 2022, 19:10   #2013  |  Link
wonkey_monkey
Does your program still invoke ConvertToRGB32 when it is already in the script?
What worked for me was putting ConvertToRGB32 in a script and then running the script with AVSMeter64. If I try to load the script in my viewer - which invokes ConvertToRGB32 a further time, regardless of what type the script produces - it crashes.
Old 21st March 2022, 19:18   #2014  |  Link
Selur
Selur's Avatar
Nope, ConvertToRGB32 is only invoked if the input isn't already RGB32.
Old 21st March 2022, 19:57   #2015  |  Link
pinterf
I've never used cmake from Visual Studio GUI.
I'm using CMakeGUI and using it to generate the .sln solution for all projects and dlls in Avisynth+.
https://avisynthplus.readthedocs.io/...from-cmake-gui
Then I open the generated sln and can use both debug and release build from Visual Studio IDE.
Old 21st March 2022, 20:08   #2016  |  Link
Ceppo
Might be unrelated, but when I used invoke with vinverse, when passing directly the value in the invoke call I got the float converted to int for no reason, then I declared first the array and then I set the value of each index individually and the problem was gone, give it a shot, you got nothing to lose after all...
3 nights without sleeping
Old 21st March 2022, 20:16   #2017  |  Link
Selur
Selur's Avatar
On my way to bed, you mean like this?
AVSValue tmp[1] = { &m_res };
m_res = m_env->Invoke(function, tmp);
(will try tomorrow after work)
Old 21st March 2022, 20:36   #2018  |  Link
pinterf
Is it easy and straightforward to build and use avsviewer cloned from git? Does it have any prerequisites?
Old 21st March 2022, 20:47   #2019  |  Link
Ceppo
AVSValue tmp[1];
tmp[0] =  &m_res;
Old 22nd March 2022, 00:29   #2020  |  Link
Dogway
I wonder if frame props are broken? I expect frame properties assigned to frame 0 be retrieved outside a runtime environment.
ScriptClip( function[] () {
SelectEvery(1,-current_frame)
AverageLuma() > 98 ? propSet("_TestFP", 4) : propSet("_TestFP", 1)
SelectEvery(1, current_frame)
subtitle(string(AverageLuma()),align=8,y=100)
subtitle(string(propGetInt("_TestFP")),align=8)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread
