#81 | Link |
6.4.0.0
- Update and Folder View feature did not work on systems with restricted PowerShell execution policy.
#82 | Link |
#84 | Link |
Yes, I noticed it when I wanted to auto update the version that is included in staxrip, I will take a look.
#85 | Link |
Found the problem, could have happened when I back ported it from .NET Core to .NET Framework.
I changed the update routine using zip instead of 7z (same as mpv.net), uploaded 6.8, this has to be updated manually, from 6.8 to 6.9 it should work again. Again I changed the back color of the dark theme.
#87 | Link |
It's fixed in the last release 7.0.0.0.
#89 | Link |
Thanks for the note, I try to update it soon.
MediaInfo.NET much like mpv.net was originally built for staxrip and are very important for staxrip. .NET Core or as it's called today NET 5 is not yet part of the Windows OS. That's the main problem at the moment, but I'm really not sure if it's still true for the latest Windows build. And maybe more and more apps require .NET 5 and people start accepting it. I used .NET 5 for my dark voidtools Everything frontend, and it became surprisingly popular, it was like staxrip, mpv.net and Open with++ reviewed by www.ghacks.net and has 51 Stars on GitHub, it can be found here: https://github.com/stax76/Everything.NET It was built in only 3 days which is a lot less than MediaInfo.NET. Nobody has complained about the .NET 5 install requirements, that is good. But generally .NET Framework and .NET 5 are not compatible and applications have very different requirements, for many applications a port does not make sense, and for other it makes a lot of sense. There are many factors.
#90 | Link |
7.1.0.0
- MediaInfo 21.3 - Get-MediaInfo 3.7 - psy-rd moved to Analysis section
#93 | Link |
There was crash reported lately, so I tried to fix it and made a new release:
v7.2.0.0 - Next/Previous uses only known media file types as defined in the settings - Larger list of known media file types - Bit depth parameter is hidden for DTS - Rebuild of corrupted settings file - MediaInfo 22.03
| Display Modes | |
